null0bject
High frequency Generation on rpi 4b
Wed May 12, 2021 10:16 am
There is a way to generate on a gpio (no matter the gpio) a square signal stable with a 50 kHz ?
At the moment, I try it using the bcm2835 lib on a raspberry pi 4B to control the gpios and timerfd to manage delays but the result is very bad, the frequency is not precise and unstable.
the delay function :
void DelayMicrosecondsNoSleep (int delay_us)
	long int start_time;
	long int time_difference;
	struct timespec gettime_now;
	clock_gettime(CLOCK_REALTIME, &gettime_now);
	start_time = gettime_now.tv_nsec;		            // Get nS value
	while (1)
		time_difference = gettime_now.tv_nsec - start_time;
		if (time_difference < 0)
			time_difference += 1000000000;				// (Rolls over every 1 second)
		if (time_difference > (delay_us * 1000))		// Delay for # nS
			break;
the blink code (main loop) :
int main()
    // gpio
    if(!bcm2835_init())
        return 1;
    bcm2835_gpio_fsel(PIN, BCM2835_GPIO_FSEL_OUTP);
    while(1)
		bcm2835_gpio_write(PIN, 0);
		DelayMicrosecondsNoSleep(10);
		bcm2835_gpio_write(PIN, 1);
    return 0;
Thanks,
null0bject
sometimes the frequency decreases
the accuracy problem (10.8 us and not 10 us)
joan
Re: High frequency Generation on rpi 4b
Wed May 12, 2021 11:49 am
Yes, using a pigpio wave. You can switch one or more GPIO on or off with 1 microsecond resolution.
LTolledo
Wed May 12, 2021 1:15 pm
why do you want to generate that kind of square wave?
Some people be like:
RamaSpaceShip
Wed May 12, 2021 5:08 pm
You need to reserve a core for the thread that generate the signal by using isolcpus in /boot/cmdline.txt
You need to run this thread at realtime priority, schedfifo with its affinity set to the reserved core.
I think there is uncertainty in your delay function.
For the same purpose, I use the following code (in Ada):
         Period := To_Nanoseconds (Timer.Cycle) ;
         Result := Clock_Get_Time (CLOCK_MONOTONIC, Date) ;
         Cycles:
         loop
            Inc (Date, Period) ;
            while Clock_Nano_Sleep (CLOCK_MONOTONIC, TIMER_ABSTIME, Date, Remain) /= 0
            loop
               null ;
            end loop ;
            -- execute cyclic job, a false result indicates to end the cycles
            exit Cycles when not Timer.Expired ; -- Timer.Expired is the callback to execute at each cycle
         end loop Cycles ;
This gave me a square signal on the GPIO pins, with a deviation less than 100ns measured with a PicoScope 3500D sampling at 100Mhz.
joan
Wed May 12, 2021 5:23 pm
50 kHz square wave on GPIO X.
sudo pigpiod
X=23
pigs m $X w
pigs wvag $((1<<X)) 0 10 0 $((1<<X)) 10
pigs wvcre
pigs wvtxr 0
null0bject
Mon May 17, 2021 9:39 am
Hello, thanks for the answer.
I need to generate a signal at maximum 50 Khz but in reality it can be lower than 50 Khz and also it can just be a simple pulse.
I tried the nanopulse.c viewtopic.php?t=270197 (I put the good base addresses) but doesn't work for me.
Currently, I'm trying this but seems to not work :
#include <stdio.h>
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <unistd.h>
#include <fcntl.h>
/* others definitions */
#define BLOCK_SIZE 		         (4*1024)
/* PWM0 registers */
#define PWM0_BASE_ADDRESS        0x7E20C000
#define PWM0_CTL                 (PWM0_BASE_ADDRESS + 0x00)
#define PWM0_STA                 (PWM0_BASE_ADDRESS + 0x04)
#define PWM0_DMAC                (PWM0_BASE_ADDRESS + 0x08)
#define PWM0_RNG1                (PWM0_BASE_ADDRESS + 0x10)
#define PWM0_DAT1                (PWM0_BASE_ADDRESS + 0x14)
#define PWM0_FIF1                (PWM0_BASE_ADDRESS + 0x18)
#define PWM0_RNG2                (PWM0_BASE_ADDRESS + 0x20)
#define PWM0_DAT2                (PWM0_BASE_ADDRESS + 0x24)
/* gpio registers */
#define GPIO_PULSE               12                               // broche physique 32
#define ALT_FUNC0                0x04                             // b0100
#define GPIO_BASE_ADDRESS        0x7E200000
#define GPFSEL1                  (GPIO_BASE_ADDRESS + 0x04)
#define GPFSEL1_GPIO_PULSE_MASK  (0x000001C0)                     // b0000 0000 0000 0000 0000 0001 1100 0000
#define GPSET0                   (GPIO_BASE_ADDRESS + 0x1C)
#define GPCLR0                   (GPIO_BASE_ADDRESS + 0x28)
struct bcm2711_peripheral
    unsigned long addr_p;
    int mem_fd;
    void *map;
    volatile unsigned int *addr;
struct bcm2711_peripheral gpio = {GPIO_BASE_ADDRESS};
/* macros definitions */
#define INP_GPIO(g)   *(gpio.addr + ((g)/10)) &= ~(7<<(((g)%10)*3))
#define OUT_GPIO(g)   *(gpio.addr + ((g)/10)) |=  (1<<(((g)%10)*3))
#define SET_GPIO_ALT(g,a) *(gpio.addr + (((g)/10))) |= (((a)<=3?(a) + 4:(a)==4?3:2)<<(((g)%10)*3))
#define GPIO_SET  *(gpio.addr + 7)
#define GPIO_CLR  *(gpio.addr + 10)
#define GPIO_READ(g)  *(gpio.addr + 13) &= (1<<(g))
// Exposes the physical address defined in the passed structure using mmap on /dev/mem
int map_peripheral(struct bcm2711_peripheral *p)
   // Open /dev/mem
   if ((p->mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0)
      printf("Failed to open /dev/mem, try using sudo.\n");
      return -1;
   p->map = mmap(
      NULL,
      BLOCK_SIZE,
      PROT_READ|PROT_WRITE,
      MAP_SHARED,
      p->mem_fd,      // File descriptor to physical memory virtual file '/dev/mem'
      p->addr_p       // Address in physical map that we want this memory block to expose
   if (p->map == MAP_FAILED)
        perror("mmap");
        return -1;
   p->addr = (volatile unsigned int *) p->map;
   return 0;
void unmap_peripheral(struct bcm2711_peripheral *p)
    munmap(p->map, BLOCK_SIZE);
    close(p->mem_fd);
int main()
   /* initialisations */
   // check if gpio are usable
   if(map_peripheral(&gpio) == -1)
      printf("Failed to map the physical GPIO registers into the virtual memory space.\n");
      return -1;
   // define PULSE_PIN as output
   INP_GPIO(GPIO_PULSE);
   OUT_GPIO(GPIO_PULSE);
   while(1)
    GPIO_SET = 1 << GPIO_PULSE;
    sleep(1);
    GPIO_CLR = 1 << GPIO_PULSE;
    sleep(1);
   return 0;
I will try your proposals.
Return to “Advanced users”
