bhatcher
RPi USB Compliance
Sat Feb 20, 2021 12:11 am
Have any RPi products gone through the USB-IF compliance process? For example I see on the RPi Zero W page:
Compliance
The Raspberry Pi Zero W has undergone extensive compliance testing, and meets the following European standards:
  • Electromagnetic Compatibility Directive (EMC) 2014/30/EU
  • Restriction of Hazardous Substances (RoHS) Directive 2011/65/EU
View and download global compliance certificates for Raspberry Pi products.
However I don't see anything about USB compliance. I know the RPi 4 originally was non-compliant on its USB-C interface, so this implies that RPi does not pass USB-IF compliance before releasing products.
I realize there is some distinction between being merely USB compliant as in "it adheres to the spec" vs being "capital C" compliant and going through the testing process through USB-IF.
Also, is anyone aware of any products based on the RPi that have sought out USB-IF compliance?
W. H. Heydt
Re: RPi USB Compliance
Sat Feb 20, 2021 1:41 am
The "non-compliance" of the USB-C *power* connector (which can be used as a USB 2 device) was strictly a matter of not working with PD PSUs and e-marked cables.
However, I will assert with some confidence that the USB ports on B-series Pis are *not* compliant as a Pi can't guarantee to supply the specified current to downstream USB devices. The most any Pi can provide to the 4 USB ports is 1.2A. For the Pis with 4 USB ports, the spec would require a combined 2A and for the Pi4B, with 2 USB 2 and 2USB 3, it would have to supply 2.8A.
As for compliance with RF emissions standards...that's what the RPT has them tested for.
LTolledo
Sat Feb 20, 2021 9:56 am
is this another "witch hunt"? :shock:
Some people be like:
Sat Feb 20, 2021 10:32 am
Don't think so.
We've never claimed that we passed this particular testing; we are happy that on the whole, the USB just works!
LTolledo
Sat Feb 20, 2021 10:42 am
....we are happy that on the whole, the USB just works!
and that is most important....
W. H. Heydt
Sat Feb 20, 2021 5:47 pm
Don't think so.
So am I, given the early teething problems. And I'm sure that the Pi USB ports *are* in compliance when it comes to RF emissions, and that's the important part.
bhatcher
Mon Feb 22, 2021 6:16 pm
Don't think so.
Not suggesting it's been claimed, just curious! USB-IF has a "certification by similarity" program which allows products similar to existing compliant ones to streamline the compliance process. If people used the RPi as the basis for a commercial product, it would make that process a lot easier. Thanks for confirming my suspicions!
jdb
Tue Feb 23, 2021 12:32 pm
There is basically no such thing as a "compliant" USB device (or controller). The enormous numbers of workarounds, quirks, special-cases, fudges and straight up hacks in every part of the USB driver stack in Linux is a testament to this fact.
Even if you had a mystical "compliant" USB host, it would fail interop with a good portion of unusual devices.
The best you can hope for is a maximal set of interoperable devices if you are a host, and a maximal compatibility with host controllers if you are a device.
Rockets are loud.
https://astro-pi.org
W. H. Heydt
Tue Feb 23, 2021 5:34 pm
Fair enough...and--so far--my experience is that Pis do quite well in those areas.
I read the OP as being concerned with RF interference compliance (in that there shouldn't be any outside legal limits) and I have every confidence in you folks that that is tested and does meet standards.
bhatcher
Tue Mar 02, 2021 12:27 am
I'm not asking if a device functions perfectly with all USB devices ever made. I'm referring to certification for compliance by the USB-IF.
Return to “Advanced users”
