There are "A1" app performance rated micro SD cards, and those would be the fastest solution if you intend to use only SD card storage. Don't bother with "A2" rated cards, as those only work properly on A2 compliant devices, which there are very few of (the Raspberry Pi is not).
For your relatively small storage needs a SanDisk Ultra A1 micro SD card would be a good option. I have several Pi computers running from those, and they make a noticeable improvement in performance.
The Pi 4B has USB 3.0, so you have USB 3.0 SSD as another option (or a fast USB 3.0 stick/thumb/flash drive). The Pi4 currently won't boot directly from USB, but that will be added in a future firmware update. You can either boot from SD card and use the SSD as fast storage, or start the boot process from SD card, then load and run the OS from USB/SSD.
BeauSlim wrote: ↑Tue Dec 03, 2019 10:24 pm
It's not quite that simple. There are some SSD-USB adapters/enclosures that work better with Raspbian, so you'll want to search these forums for recommendations. You'll want working UAS at a minimum, and also TRIM and SMART support if at all possible.
Yup, this is true. This should get better over time with improvements to firmware, but if you want something now, I'd suggest SATA-III SSD with a USB 3.0 adapter, since you can easily replacing the adapter if you run into problems.
Don't bother with NVMe, it will cost much more but make little difference on the Raspberry Pi (NVMe to USB 3.0 is a massive bottleneck, and even more on the Pi4, where all 4 USB ports share a single 4Gbps PCIe lane).
