jones5112
Toggling WiFi via hardware
Sat May 18, 2019 12:35 pm
Hi guys,
I've done a fair bit of googling but I can't seem to find a solid answer.
I want to add a switch to my Pi3b and Pi zero that turns the wifi on and off, similar to what was on older style laptops.
My pi runs headless and I'd like the ability to connect to it without it broadcasting a wifi network all the time
Can this be done with a dt-overlay style command?
All the articles and sites I find talk about permanently disabling wifi, I just need to be able to toggle it.
bensimmo
Re: Toggling WiFi via hardware
Sat May 18, 2019 1:56 pm
Try rfkill with block/unblock to soft block it
Which is what I think desktop taskbar icon does.
klricks
Sat May 18, 2019 3:13 pm
Turn WIFI off:
wpa_cli -i wlan0 disconnect
Turn WIFI back on:
wpa_cli -i wlan0 reconnect
Also this may be useful:
wpa_cli -i wlan0 status
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
klricks
Sat May 18, 2019 4:33 pm
FYI the commands for rfkill are:
WIFI:
rfkill block 0
rfkill unblock 0
For BT:
rfkill block 1
rfkill unblock 1
Status:
rfkill list
jones5112
Sat May 18, 2019 9:44 pm
Thanks All I'll see what I can come up with!
jones5112
Wed Jun 26, 2019 1:27 am
Okay think I've sorted this out.
So I've got a python script running, I tried it with the rfkill commands and that worked okay for the Wifi signal. However it did not always restart the Access point, the main reason why I needed this.
So my script now simply starts and stops the hostapd service
#!/usr/local/bin/python
import sys
import time
import os
import RPi.GPIO as IO
IO.setmode(38, IO.IN, pull_up_down=IO.PUD_UP)
try:
		while True:
				button_state=IO.input(38)
				if button_state==False:
					os.system('systemctl start hostapd')
					time.sleep(2)
				else:
					os.system('systemctl stop hostapd')
					time.sleep(2)
except:
	IO.cleanup()
Seems to work fine for me, apologies for my poor coding skills but hopefully this might help someone.
Return to “Advanced users”
