theodop
ALSA audio 3.5mm playing mono only
Wed May 15, 2019 3:58 am
Raspberry Pi 3
Ubuntu MATE 1.20.1 / Ubuntu 18.04.2
Kernel 4.15.0-1032-raspi2
I am attempting to use the 3.5mm audio jack for stereo playback but the playback device only ever shows up as mono.
[email protected]:~/Code$ amixer
Simple mixer control 'PCM',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback -10239 - 400
Mono: Playback -2563 [72%] [-25.63dB] [on]
speaker-text -c2 only plays audio in the "left" phase of the test (but it is played in the center, i.e. both channels).
Audio controls within MATE only show mono also, so I don't think the problem is limited to ALSA, but I only need ALSA audio.
Other posts ( https://www.raspberrypi.org/forums/view ... hp?t=18755 ) indicate that while the ALSA controls only adjust the volume in mono, playback should be in stereo. I have not found this to be the case.
epoch1970
Re: ALSA audio 3.5mm playing mono only
Wed May 15, 2019 9:47 am
Last time I've checked I've also seen the device reported as mono, but with "-c 2" you could hear "left" and "right" fine.
Is the audio cable fully pushed in the plug?
theodop
Wed May 15, 2019 10:33 am
I've been unplugging and plugging it in all day but if this is the fix for it I will leave tech forever and walk into the ocean
epoch1970
Wed May 15, 2019 11:19 am
:D
I meant socket, sorry. Anyways, I think it has happened to me more than once.
You can also try with another cable/headset; just in case the plug is somehow not compatible.
theodop
Wed May 15, 2019 10:36 pm
Alas, that doesn't seem to be the issue. I've brought in another pair of headphones to test with as well - no improvement. The plug seems to be mating well with the socket.
I think I'll try another RPi today with my SD card, and another image with my RPi, if I can track it all down.
theodop
Thu May 16, 2019 8:50 am
The plot thickens - through a HDMI screen, I get sound - but only mono still :(
theodop
Thu May 16, 2019 8:51 am
To be clear, I have headphones plugged into the screen and the sound output from both ALSA and other applications (such as YouTube) is only mono.
Thu May 16, 2019 9:14 am
So you are not plugging in directly to the Raspberry Pi ?
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Stretch.
theodop
Thu May 16, 2019 9:16 am
Alright, so I don't have a fix for the user environment in Ubuntu, but I DO have a fix for ALSA: the default sound device doesn't work, but plughw:CARD=ALSA,DEV=0 does!
So this:
speaker-test -D plughw:CARD=ALSA,DEV=0 -c2
produces two beautiful earfuls of static.
This is now testing over HDMI, so once I work up the nerve to possibly break it again, I'll test with the 3.5mm jack.
theodop
Thu May 16, 2019 9:17 am
"So you are not plugging in directly to the Raspberry Pi ?"
I WAS plugged in to the 3.5mm jack, but moved to HDMI to try and eliminate variables. I will test again with the 3.5mm jack soon.
Thu May 16, 2019 9:43 am
The supported by Raspberry Pi Foundation Operating System is Raspbian, maybe best to try Raspbian to ensure it is not a Ubuntu issue.
adieu
theodop
Thu May 16, 2019 11:51 am
Maybe on the holidays I'll chase this one up. Unfortunately using Raspbian at this stage is not an option as Ubuntu is the supported (read: documented) distro for Intel RealSense.
Return to “Advanced users”
