OyarzoPablo
Wifi config product-like
Wed May 16, 2018 11:05 pm
I'm making a product based on the RPi3, is there a tool that facilitates the connection between the RPi and the local wifi network?
Like hosting a website with the wifi networks available and so on... Something like the omega2 does out of the box. I would also appreciate if you tell me if this has a name.
Re: Wifi config product-like
Thu May 17, 2018 8:59 pm
The Google ChromeCast works like this and the Gemina2 seems similar:
Chromecast fires up, puts out a Wi-Fi signal as an unsecured Access Point.
You connect to this unsecured open Wi-Fi via the Google Home App.
You tell Chromecast the logon credentials of your Wi-Fi.
The chromecast disables the Access Point and and logs onto the Home Wi-Fi.
You will likely have to write your own software "glue" to undertake a similar function in whatever Operating System you intend to install.....
adieu
My other Computer is an Asus CS10 ChromeBit
Paul Hutch
Thu May 24, 2018 6:10 pm
The Mozzilla IoT Things Gateway for Raspberry Pi3B boots up as an AP to allow WiFi setup. Note you do not need to have a radio dongle to try out the feature, also the source code is open source.
https://hacks.mozilla.org/2018/02/how-t ... s-gateway/
https://iot.mozilla.org/gateway/
Return to “Advanced users”
