gurnarok
[SOLVED] RPi 3 MPG2 code not activating
Sat Jan 13, 2018 5:57 pm
I am having problems with MPEG 2 codec. I am running DietPi v159.
[email protected]:~# vcgencmd get_config str
decode_MPG2=0xeedc5d33
[email protected]:~# cat /proc/cpuinfo
processor       : 0
model name      : ARMv7 Processor rev 4 (v7l)
BogoMIPS        : 38.40
Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 1
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 2
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 3
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
Hardware        : BCM2835
Revision        : a02082
Serial          : 00000000d3a27ac2
[email protected]:~# vcgencmd version
Jan 11 2018 19:21:47
Copyright (c) 2012 Broadcom
version 0deb3d4e5956807bc641565696eeace31e3903c0 (clean) (release)
[email protected]:~# vcgencmd codec_enabled MPG2
MPG2=disabled
[email protected]:~# rpi-update
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
 *** Your firmware is already up to date
Code was purchased from Raspberry Pi store. Still can't understand why the code doesn't work. Checked for the fourth time that the serial I gave when purchasing, is correct.
So, what can I do?
B.Goode
Re: RPi 3 MPG2 code not activating
Sat Jan 13, 2018 6:23 pm
So, what can I do?
As a comparison for troubleshooting purposes, I suggest installing a standard version of the Raspberry Pi Foundation recommended and supported Raspbian Operating System, and check whether your problem can be replicated on that platform.
asavah
Sat Jan 13, 2018 7:45 pm
Dumb question: did you reboot the pi after adding the code?
rpdom
Sat Jan 13, 2018 8:09 pm
How much memory is allocated to the GPU? vcgencmd get_mem gpu
It needs to be about 64MB or higher for the codec to activate.
gurnarok
Sat Jan 13, 2018 8:11 pm
Yes, I did reboot.
So, what can I do?
Ok, I made a normal raspbian installation, it seems to work in that. I might need to contact the Dietpi creator and ask about it.
B.Goode
Sat Jan 13, 2018 8:18 pm
Before you do, retry your DietPi-based system.
I think I am correct in saying that enabling the licence is now a once-only operation that sets a bit in the OTP registers. You seem to have proved that bit has been set. The previous apparent failure with DietPi might have been in either updating or retrieving that setting. It might be that now Raspbian has set the bit that DietPi will retrieve and honour it?
Either way, you will have additional debug information to pass on to @fourdee.
Edit: and @rpdom's suggestion that your memory split may vary across systems is worth considering.
gurnarok
Sat Jan 13, 2018 8:21 pm
Ok, that helped. I had 16MB set on it. After setting it to 128MB, it is now activated.
Thank you.
Return to “Advanced users”
Who is online
Users browsing this forum: Bing [Bot], R-A and 14 guests
