ankur_r
Assigning an IP to Respbarry Pi 2 Model B1.1
Wed Dec 06, 2017 1:09 pm
Hi All,
My setup -
Laptop : Full specification https://support.hp.com/za-en/document/c05562632
Board : Respbarry Pi 2 Model B1.1with VNC Client, Putty installed.
OS On laptop : Ubuntu 12.04.5 LTS
Kernel : 3.11.0-26-generic
Network Cable, HDMI Cable, Samsung Galaxy OnPro5 Android Mobile Charger, USB Keyboard, Mouse
Card : Fat32 Formatted and Prepared via command sudo dd if=2017-09-07-raspbian-stretch.img of=/dev/sdb1 bs=1M
Card OS: https://www.raspberrypi.org/downloads/raspbian/
Information Card OS: Version: November 2017
Release date: 2017-11-29
Kernel version: 4.9
Release notes: Link
LInks Studied :
viewtopic.php?f=91&t=197980&e=1&view=unread#unread
https://www.raspberrypi.org/blog/get-ba ... c-connect/
http://www.instructables.com/id/Connect ... ux-Laptop/
https://www.raspberrypi.org/blog/a-secu ... ian-pixel/
https://pihw.wordpress.com/guides/direc ... onnection/
https://wiki.openwrt.org/toh/raspberry_ ... spberry_pi
viewtopic.php?f=29&t=197689
Issue : Not able to see what is happening on board i.e. Raspberry Pi 2 ? Absolutely None display either on Putty nor on VNC Client.
Technically Not able to assign IP to Raspberry Pi2 Board, as instead of preparing the SD Card nothing able to do, as none of the interface is displaying over the laptop.
I am struggling with this issue since long. I will be too much thankful if someone can help here ?
Regards All.
Ankur
SurferTim
Re: Assigning an IP to Respbarry Pi 2 Model B1.1
Wed Dec 06, 2017 1:33 pm
Are both devices connected to a router? What are the network settings you are using on the laptop and the RPi?
ankur_r
Wed Dec 06, 2017 4:37 pm
No Router in between... Direct connection from rpi board to laptop via network cable...or i tried with HDMI cable too...but as everywhere Network cable/wireless is recommended,..... so i used network cable...even i bought new one...previously i tried with old one....ending the possibility of damaged cable... i buy brand new...
can you or anyone help here ?
Regards.
Ankur
SurferTim
Wed Dec 06, 2017 5:24 pm
Probably your network settings are not correct.
ankur_r
Wed Dec 06, 2017 5:54 pm
Thanks for helping me....
I set ip address at eth0 and set same ip at putty as host ...protocol ssh...
kindly suggest correct setting...if you feel... I am wrong somewhere...
Regards.
Ankur
ankur_r
Wed Dec 06, 2017 6:00 pm
ip of laptop eth0 = 192.168.3.100 ...but what would be the host ip in putty or in vnc viewer...its the challenge ...i cant set...and what is is taking internally...i m not able to decide......NO ROUTE FOUND error has been displayed....so what u r saying...seems right....but how to identify the ip of rpi board ...can u kindly suggest ??
Regards.
Ankur
drgeoff
Wed Dec 06, 2017 9:25 pm
That is writing the image to a partition, not the whole card. Your RPi will not boot. Change sdb1 to sdb.
How much time have you wasted because you did not read carefully?
And as you have not mentioned a monitor, what is the HDMi cable for?
BTW it is not necessary to format a card before writing an image to it.
ankur_r
Thu Dec 07, 2017 7:11 am
I have done following as suggested
sudo dd if=2017-09-07-raspbian-stretch.img of=/dev/sdb bs=1M
sudo ifconfig eth0 192.168.3.200 netmask 255.255.255.0 up
In putty host = 192.168.3.200 port = 22
But no display...connection time out.. even on 192.168.3.100 ..same result... :(
Pl help...
drgeoff
Thu Dec 07, 2017 9:44 am
Pl help...
Where are you running that ifconfig command? If running it on the laptop then it is (attempting to) set the IP address of the laptop to 192/168.3.200. And if running the putty host line on the laptop, that is telling putty on the laptop to connect to the laptop.
Is your RPi actually booting. Read the "not booting" sticky, especially the section under "Check the ACT LED to determine if the Pi is booting" in the Troubleshooting part of the forum.
The post at viewtopic.php?f=29&t=173514#p1109425 tells you how to enable ssh on the RPi and how to give it a known static IP address. Give it an address on the same subnet that you are giving the laptop, eg 192.168.3.201
Connect laptop and RPi with an ethernet cable, boot the RPi and in a terminal window on the laptop type The password is raspberry.
For more, read https://www.raspberrypi.org/documentati ... te-access/
ankur_r
Thu Dec 07, 2017 11:01 am
Thanks for all help...but still I am not able to get connected ...
One thing I noticed that after setting the ip with ifconfig command..when I am connecting the rpi board...after few second laptop lost is static ip...which in turn come with no ip assigned .... when enquiring about ip of eth0 via ifconfig command.
On ssh [email protected] .. No route found
Below says in rpi ...to save hacking ..they have disabled its ssh ...if so then how i can enable it ??
https://raspberrypi.stackexchange.com/q ... lapt/58913
https://raspberrypi.stackexchange.com/q ... te-to-host
The output of route -n is :
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.43.1 0.0.0.0 UG 0 0 0 wlan0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 wlan0
192.168.3.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.43.0 0.0.0.0 255.255.255.0 U 2 0 0 wlan0
After which I tried
#ping 192.168.3.201
PING 192.168.3.201 (192.168.3.201) 56(84) bytes of data.
^C
--- 192.168.3.201 ping statistics ---
376 packets transmitted, 0 received, 100% packet loss, time 375494ms
[email protected]:~$ sudo raspi-config
sudo: raspi-config: command not found
Can anyone come with once exact setting of rpi2 putty ssh and other side/laptop network setting....?? I feel some network setting issue or ssh disabling issue stopping the display...as the ip is erasing ..it confirm the rpi is booting...as the both (green and orange ) network socket LED are blinking... and after powering up...initially for few secong green led of rpi board is blinking afterward few seconds (10-20) ..only red led is continuously glowing....
So I feel both side exact setting possibly will resolve the issue...ONe thig more I am running parallel normal wi-fi for internet surfing also...can this make an issue ??
Pl help..
Thanks..
SurferTim
Thu Dec 07, 2017 11:41 am
Sounds like you are still having problems with your network settings.
I presume the computer is a Linux based OS. Post the output of ifconfig on both the computer and the RPi.
ankur_r
Thu Dec 07, 2017 12:21 pm
Computer Output :
#ifconfig
eth0 Link encap:Ethernet HWaddr f4:30:b9:d9:24:14
inet6 addr: fe80::f630:b9ff:fed9:2414/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:1706 errors:0 dropped:0 overruns:0 frame:0
TX packets:1510 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:130538 (130.5 KB) TX bytes:314102 (314.1 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:28075 errors:0 dropped:0 overruns:0 frame:0
TX packets:28075 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2549614 (2.5 MB) TX bytes:2549614 (2.5 MB)
wlan0 Link encap:Ethernet HWaddr 64:70:02:21:47:41
inet addr:192.168.10.112 Bcast:192.168.10.255 Mask:255.255.255.0
inet6 addr: fe80::6670:2ff:fe21:4741/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:75655 errors:0 dropped:0 overruns:0 frame:0
TX packets:72174 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:51691058 (51.6 MB) TX bytes:12482819 (12.4 MB)
On RPI2 I am not able to perform any operation as I am not able to see its interface..in absense of which Not able to perform any operation...
the whole exercise is just to get rpi interface ...
Pl help..
Thanks...
SurferTim
Thu Dec 07, 2017 12:26 pm
Your computer doesn't have network settings on eth0. This is not an RPi problem.
klricks
Thu Dec 07, 2017 12:55 pm
....or i tried with HDMI cable too......
The HDMI port on 99.9% of all laptops is output only so attempting to connect that is pointless.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
Thu Dec 07, 2017 1:32 pm
It does have some network settings. It has a valid IPv6 FE80::/64 address. It has also moved some data since the counters were last reset.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
SurferTim
Thu Dec 07, 2017 1:37 pm
OK, let me reword that. The computer does not have ipv4 network settings. The RPi is set with ipv4 network settings.
ankur_r
Thu Dec 07, 2017 3:14 pm
Taking your words on action...
Method : Manual
IP Address : 192.168.3.100
Netmask : 255.255.255.0
Gateway : 192.168.3.1
DNS Server : 2.2.2.2
The series of action and their output are provided below -
[email protected]:~$ traceroute 192.168.3.201
traceroute to 192.168.3.201 (192.168.3.201), 30 hops max, 60 byte packets
1 dlinkrouter.local (192.168.10.1) 6.988 ms 10.160 ms 10.059 ms
2 10.249.0.1 (10.249.0.1) 12.594 ms 12.479 ms 12.360 ms
3 broadband.actcorp.in (202.83.20.173) 12.090 ms 11.987 ms 12.182 ms
4 broadband.actcorp.in (202.83.20.181) 12.070 ms 12.628 ms 12.997 ms
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *^C
[email protected]:~$ ssh [email protected]
^C
[email protected]:~$ ping 192.168.3.201
^X^C
7 packets transmitted, 0 received, 100% packet loss, time 6046ms
[email protected]:~$ ifconfig
RX packets:2611 errors:0 dropped:0 overruns:0 frame:0
TX packets:2266 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:195296 (195.2 KB) TX bytes:436008 (436.0 KB)
RX packets:35563 errors:0 dropped:0 overruns:0 frame:0
TX packets:35563 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3284914 (3.2 MB) TX bytes:3284914 (3.2 MB)
RX packets:3371 errors:0 dropped:0 overruns:0 frame:0
TX packets:2953 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3664102 (3.6 MB) TX bytes:401421 (401.4 KB)
inet addr:192.168.3.100 Bcast:192.168.3.255 Mask:255.255.255.0
RX packets:2622 errors:0 dropped:0 overruns:0 frame:0
TX packets:2307 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:195956 (195.9 KB) TX bytes:443590 (443.5 KB)
RX packets:35641 errors:0 dropped:0 overruns:0 frame:0
TX packets:35641 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3292791 (3.2 MB) TX bytes:3292791 (3.2 MB)
RX packets:3576 errors:0 dropped:0 overruns:0 frame:0
TX packets:3129 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3695530 (3.6 MB) TX bytes:437710 (437.7 KB)
ssh: connect to host 192.168.3.201 port 22: No route to host
From 192.168.3.100 icmp_seq=1 Destination Host Unreachable
From 192.168.3.100 icmp_seq=2 Destination Host Unreachable
From 192.168.3.100 icmp_seq=3 Destination Host Unreachable
From 192.168.3.100 icmp_seq=4 Destination Host Unreachable
From 192.168.3.100 icmp_seq=5 Destination Host Unreachable
From 192.168.3.100 icmp_seq=6 Destination Host Unreachable
^C
7 packets transmitted, 0 received, +6 errors, 100% packet loss, time 6033ms
pipe 3
On putty : No display with finally No route found.
Now please do suggest further what I must do to get its output...
Thanks for all continuous help..
Regards.
Ankur
SurferTim
Thu Dec 07, 2017 6:59 pm
What happened between this...
...and this?
First has no ipv4 settings, and the second does. ??
drgeoff
Thu Dec 07, 2017 7:14 pm
My last post contained a link about that. And about setting a static IP on the RPi.
Or a search engine will find you lots of info on enabling ssh and setting the RPI's IP from the cmdline.txt file.
ankur_r
Thu Dec 07, 2017 10:35 pm
Yes exactly....
But again the result is -
RX packets:6 errors:0 dropped:0 overruns:0 frame:0
TX packets:21 errors:0 dropped:47 overruns:0 carrier:0
RX bytes:684 (684.0 B) TX bytes:980 (980.0 B)
RX packets:88 errors:0 dropped:0 overruns:0 frame:0
TX packets:88 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7026 (7.0 KB) TX bytes:7026 (7.0 KB)
[email protected]:~$ route -n
0.0.0.0 192.168.3.1 0.0.0.0 UG 0 0 0 eth0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 eth0
192.168.3.0 0.0.0.0 255.255.255.0 U 1 0 0 eth0
1 ankur-ubuntu.local (192.168.3.100) 2999.234 ms !H 2999.199 ms !H 2999.207 ms !H
Whats further ? :roll: :?: :cry:
SurferTim
Thu Dec 07, 2017 10:54 pm
Run ifconfig on the RPi.
drgeoff
Thu Dec 07, 2017 11:49 pm
AIUI he cannot. He has no means to interact with the RPi. No input and no output. That's where this whole saga started.
drgeoff
Thu Dec 07, 2017 11:53 pm
Have you given the RPi a known IP address? If yes, what is the IP address? Have you enabled the ssh server on the RPi? Are you able to ssh from the laptop to the RPi?
SurferTim
Thu Dec 07, 2017 11:54 pm
From the OP:
Maybe I misunderstood, but HDMI cable, mouse and keyboard indicate there is communication with the RPi.
drgeoff
Thu Dec 07, 2017 11:56 pm
From the OP:
I think you misunderstood. There has been no mention of a display on the end of the HDMI cable.
Return to “Advanced users”
