caknizar
Etimedout / get twin message error when connecting Raspberry-Pi to Azure IoT
Wed Oct 04, 2017 7:35 am
I am trying to use this tutorial Connect Raspberry Pi to Azure IoT Hub (Node.js) https://docs.microsoft.com/en-us/azure/ ... et-started
It is about connecting from Raspberry-Pi to Azure IoT.
But I found error like this:
[email protected]:~/iot-hub-node-raspberrypi-client-app $ sudo node index.js 'HostName=IOTHeatSensor.azure-devices.net;DeviceId=new-device;SharedAccessKey=a3TjHZ40udjd....zToGnUQY='
{[Error: ETIMEDOUT, Connection timed out] errno: 110, code: 'ETIMEDOUT', syscall: 'writeByte'}
Maybe someone knows how to make it right? How to make the tutorial works? Thank you very much before
mahjongg
Re: Etimedout / get twin message error when connecting Raspberry-Pi to Azure IoT
Fri Oct 06, 2017 11:02 pm
censored out (part of) private key, be careful not to publish details like that.
Sat Oct 07, 2017 7:04 am
The "errno 110" means IOTHeatSensor.azure-devices.net can't be reached or IOTHeatSensor.azure-devices.net is not listening for connections.
So get the results from the following commands
ip addr show
ip link show
ip route
ping -c3 $(ip route | awk '/default/ {print $3}')
ping -c3 8.8.8.8
ping -c3 google.com
ping -c3 IOTHeatSensor.azure-devices.net
And we can tell you where your networking is broken.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
caknizar
Sat Oct 07, 2017 2:28 pm
yeah that is why put it some dots (....). anyway, do you know why?
Sat Oct 07, 2017 3:04 pm
Go and ask the very nice folks who are running that internet server for you. Nothing I can fix.
MQTT Evangelist
mahjongg
Mon Oct 09, 2017 12:04 am
you mean your friendly moderator tried to keep you safe by replacing a part of the key with those "...." dots.
there was no need to publish the full SharedAccessKey anyway, not for understanding the problem....
Return to “Advanced users”
Who is online
Users browsing this forum: No registered users and 18 guests
