mezinster
Booting from USB on Pi2
Wed Sep 13, 2017 11:16 am
Is that article related to Pi2 also?
https://www.raspberrypi.org/documentati ... des/msd.md
drgeoff
Re: Booting from USB on Pi2
Wed Sep 13, 2017 6:14 pm
Definitely not possible for original RPI2 which has BCM2836 chip.
Possibly possible for version 2 which has the BCM2837 chip (same as RPi3).
RonR
Wed Sep 13, 2017 8:37 pm
Booting from USB is easy on a Pi1, Pi2, or Pi3:
1. Write the latest Raspbian image to an SD card and boot it.
2. Write the latest Raspbian image to a USB drive and plug it into the Pi.
3. Run blkid to determine the PARTUUID of the USB drive.
4. Edit /boot/cmdline.txt and change root=PARTUUID=xxxxxxxx to match the PARTUUID of the USB drive.
5. Reboot. The Pi should be running from the USB drive.
If you ever need to boot from a different USB drive or from the SD card, it's necessary to FIRST mount the boot partition of the SD card (/dev/mmcblk0p1) and edit the boot partition's cmdline.txt so that root=PARTUUID=xxxxxxxx matches the device you wish to boot from.
B.Goode
Wed Sep 13, 2017 8:51 pm
That depends on interpretation of what "Booting from USB " means.
Some difficult and demanding users might object that you are describing a system which boots initially from a microSD card and transfers control to a system installed on a usb device.
RonR
Wed Sep 13, 2017 9:09 pm
What do you propose for a Pi1 or Pi2?
rpdom
Wed Sep 13, 2017 9:13 pm
The only option for a Pi1 or Pi2 is to use the SD card to boot.
RonR
Wed Sep 13, 2017 9:25 pm
Apparently B.Goode has a better way. :)
I'm always open to learning, but not to arguing over semantics.
Wed Sep 13, 2017 9:26 pm
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
Wed Sep 13, 2017 9:27 pm
That still is SD Card Booting........
https://www.raspberrypi.org/documentati ... bootmodes/
RonR
Wed Sep 13, 2017 10:05 pm
Using just bootcode.bin, I don't see any way to select which USB device boots in the case of multiple bootable USB devices being present. I assume it simply boots the one that comes ready first.
RonR
Wed Sep 13, 2017 11:51 pm
It appears to be worse than I thought. bootcode.bin appears to only boot from the first device (/dev/sda). I use two USB drives, one a bootable Raspbian image and the other formatted NTFS. If the NTFS drive comes up first, it doesn't ignore it and go on to the Raspbian drive.
Thanks, but I'll stick with the method outlined above which has been working reliably for more than 3 years.
asandford
Thu Sep 14, 2017 12:16 am
I think you either misread or misinterpreted what he wrote.
Perhaps the title should be "Booting without an SDcard on Pi2"
Strictly speaking, even an NFS/iSCSI boot is USB boot
drgeoff
Thu Sep 14, 2017 7:40 am
It is quite clear from the link in the first post that the OP is not asking about booting from a SD card and then running from an USB device.
mezinster
Thu Sep 14, 2017 10:11 am
Guys! I believe i've got the answer on my question :)
Pi2 DOES NOT BOOT over USB (except the case with newer Chip as in Pi3)
asandford
Fri Sep 15, 2017 12:37 am
It's clear to most of us perhaps, there appears to be an exception
drgeoff
Fri Sep 15, 2017 6:37 am
There is always one. :)
But it gets annoying when the one is always the same one. :(
Return to “Advanced users”
Who is online
Users browsing this forum: No registered users and 20 guests
