paulv
Is this the correct way to install the watchdog package?
Mon May 09, 2016 9:52 am
I'm working on a post to show various ways to make sure applications or the kernel runs through issues. Required when you run a server application, security camera or network related devices.
Update 1-nov-2017:
After all this time, I finally got a reply from the kernel folks. They have closed my bug reports.
Here is a link to an updated description for Raspbian: viewtopic.php?t=147501&p=972709
Note that in the text it says to activate the watchdog with 20seconds. This does not work on the RPi, and is related to a hardware timer limitation. The maximum is 10 seconds.
If you're interested in the application level support, read on, I have an example using Python.
To get the watchdog started on the RPi, you need to do this:
In /boot/config.txt add/change:
watchdog=on
In /etc/systemd/systemd.conf, change #RuntimeWatchdogSec= to:
RuntimeWatchdogSec=10s
[Edited]
After realizing that I was mixing two watchdog approaches, one using the watchdog package, and inadvertently also activating the systemd watchdog feature while getting things to work. I decided to completely redo this post. I know, I know, it's confusing, but in order to make it more clear, I have now tried to completely split the two approaches.
In this post I'm showing the steps to make the "traditional" software watchdog package work with the hardware watchdog the RPi provides.
The lowest level of using the BCM hardware watchdog is to watch out for kernel related issues. ie. a hung operating system. It can do more, but let's keep it simple.
I have used the hardware watchdog in the past, but as with so many other things that worked pre-Jessie (and or pre-systemd), they now don't, or require a different approach. Sadly, documentation is sorely lacking or outdated, and the software keeps on changing.
I have been able to make it work, but I still question the validity of my approach, which is a collection of steps I found all over the place. If this is the right way, it seems overly complex and half-baked to me. If my method is not correct, help me to get it right. I'll do my best to publish it for others to use.
Here is what I did on a clean install (on a blanc SD card) of Jessie Lite ( 2016-03-18), and after the usual update/upgrade/dist-upgrade.
Activating the BCM hardware watchdog:
[UPDATE]
The goal post has suddenly been moved again:
After an update/upgrade, we are now at :
Linux raspi-svr 4.4.9+ #884 Fri May 6 17:25:37 BST 2016 armv6l GNU/Linux
The name of the watchdog module has now changed from bcm2708_wdog to bcm2835-wdt
While I was searching for the solution to the error message that bcm2708 was missing, I also found out that the activation method has changed from using modprobe to adding "dtparam=watchdog=on" in /boot/config.txt. This probably happened a while ago, although I did not find it in the mostly outdated information available to us.
To activate the watchdog, edit the system config file :
sudo nano /boot/config.txt
And add this at the end of the file :
# activating the hardware watchdog
dtparam=watchdog=on
At this point you need to reboot the RPi to activate the hardware watchdog. After the reboot you can check that there are two devices called watchdog in /dev :
pi@raspi-tst:~ $ ls -al /dev/watchdog*
crw------- 1 root root  10, 130 May 19 07:09 /dev/watchdog
crw------- 1 root root 253,   0 May 19 07:09 /dev/watchdog0
I was not able to use watchdog0, but they seemed linked. If you use one of the watchdog's, trying to use the other one gives you a permission error. Bottom line, there was and is only one hardware watchdog provided.
Install the software watchdog module:
sudo apt-get install watchdog
This installation produces a few cryptic lines:
/run/udev or .udevdb or .udev presence implies active udev. Aborting MAKEDEV invocation.
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Hmm, very cryptic and certainly not very helpful. It could say "use systemd" to run it instead.
The installation installs scripts in the init.d (systemV) system, as before, but also adds this for systemd support:
ls -l /lib/systemd/system/ :
watchdog.service
wd_keepalive.service
Looks prepared and converted for use with systemd.
The previous configuration file used with the modprobe method (/etc/modprobe.d/watchdog.conf) is not longer usable. There is an additional configuration file:
ls -al /etc/default/watchdog
It contains the following :
# Start watchdog at boot time? 0 or 1
run_watchdog=1
# Start wd_keepalive after stopping watchdog? 0 or 1
run_wd_keepalive=1
# Load module before starting watchdog
watchdog_module="none"
# Specify additional watchdog options here (see manpage).
Where is says to see the "manpage", I assume man watchdog.conf is meant. Unfortunately I was unable to get the several parameters I tried, to work, so I left this file alone.
To set some of the parameters the watchdog daemon should watch :
nano /etc/watchdog.conf
For the fork bomb test (below) I took away the "#" marks from the following lines:
# this is an optional test by pinging my router
ping=192.168.1.1
max-load-1 = 24
min-memory = 1
watchdog-device = /dev/watchdog
# I added the following command to get rid of a pesky error message
watchdog-timeout=15
This is the pesky error message that will turn up if you ask for a status :
cannot set timeout 60 (errno = 22 = 'Invalid argument')
This seems to be a default that is set somewhere, which is plain wrong! The maximum timeout for the RPi BMC is 15 seconds. This is a bug, and it let many people astray (google for it), myself included.
Starting watchdog:
Here is where things are different from the systemV way. This no longer works as before.
We'll be using the systemd method to start, stop and ask for a status report.
sudo systemctl start watchdog
Now ask for a status report
sudo systemctl status watchdog
You should get something like this:
pi@raspi-server:~ $ sudo systemctl status watchdog
● watchdog.service - watchdog daemon
Loaded: loaded (/lib/systemd/system/watchdog.service; static)
Active: active (running) since Thu 2016-05-19 21:04:47 CEST; 33min ago
Process: 627 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS)
Process: 623 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS)
Main PID: 632 (watchdog)
CGroup: /system.slice/watchdog.service
└─632 /usr/sbin/watchdog
May 19 21:04:47 raspi-server watchdog[632]: int=1s realtime=yes sync=no soft=no mla=24 mem=1
May 19 21:04:47 raspi-server watchdog[632]: ping: 192.168.1.1
May 19 21:04:47 raspi-server watchdog[632]: file: no file to check
May 19 21:04:47 raspi-server watchdog[632]: pidfile: no server process to check
May 19 21:04:47 raspi-server watchdog[632]: interface: no interface to check
May 19 21:04:47 raspi-server watchdog[632]: temperature: no sensors to check
May 19 21:04:47 raspi-server watchdog[632]: test=none(0) repair=none(0) alive=/dev/watchdog heartbeat=none to=roo...ce=no
May 19 21:04:47 raspi-server watchdog[632]: watchdog now set to 15 seconds
May 19 21:04:47 raspi-server watchdog[632]: hardware watchdog identity: Broadcom BCM2835 Watchdog timer
May 19 21:04:47 raspi-server systemd[1]: Started watchdog daemon.
Hint: Some lines were ellipsized, use -l to show in full.
You can stop the watchdog with
sudo systemctl stop watchdog
And change the configuration parameters in the configuration file to test it again.
I tried it with my two fork bombs (below) and it worked correctly and as advertised. The system reboots in about 15 seconds.
Great, so now that it works, we can install it in the boot sequence now.
The correct systemd way of doing that is to use :
sudo systemctl enable watchdog
Watch this:
Synchronizing state for watchdog.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d watchdog defaults
Executing /usr/sbin/update-rc.d watchdog enable
The unit files have no [Install] section. They are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
1) A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
2) A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
3) A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
Hmmm, what the heck is the developer trying to tell us and what does that all mean???? I don't have much of a clue! I understand 1,2,3, but that is way to general. However "informative" this is supposed to be, it is no help whatsoever (for me) to point to a solution to get it installed at boot time.
Notice this though:
It looks to me that systemd invoked the systemV method. OK, seems plausible, but what about this :
The unit files have no [Install] section. They are not meant to be enabled using systemctl. ???? What exactly does "not meant to be" mean? Not yet or not ever? No clue is given how to do it otherwise, or how to make it work. Is it just a warning and did it work anyway? If you google long enough, as I did, you see a myriad of people having issues, and trying workarounds by changing the watchdog.service file.
But did it work? No!
I tried every which way to get the watchdog daemon started the old (systemV) way, and by using systemd, to no avail. It starts by hand, but does not install after a reboot. You need to make changes to make it work and there is no information that tells you how to do it. That is not very RPi user friendly folks!
To stay with the "traditional" approach as much as possible, and not mess with systemd service files, I tried two well known kludges to make it work. One is to use /etc/rc.local and the other is to use cron.
sudo nano /etc/rc.local
Add these two lines just before the exit 0 like this :
printf "Starting software Watchdog"
/usr/sbin/service watchdog start &
exit 0
Notice the "&" to put it in the background. If you don't, the console will hang.
You can also use cron if you like that better :
crontab -e
And add this :
@reboot sudo /usr/sbin/service watchdog start
With either of those methods, the watchdog package is installed at boot time. You can verify that with "dmesg | grep watchdog" or use "cat /var/log/syslog | grep watchdog"
I tried this setup with two fork bombs. One using the shell :
#!/bin/bash
echo "Starting shell fork bomb"
# prevent swapping to the SD card!
sudo systemctl stop dphys-swapfile.service
# start the bomb
And one using Python :
#!/usr/bin/python
# Name:        fork.bomb
# Purpose:
# Author:      paulv
# Created:     09-05-2016
# Copyright:   (c) paulv 2016
# Licence:     <your licence>
import os
import subprocess
def main():
    print "fork bomb starting"
    subprocess.call(['sudo systemctl stop dphys-swapfile.service'], shell=True, \
        stdout=subprocess.PIPE, stderr=subprocess.PIPE)
    while True:
        os.fork()
if __name__ == '__main__':
    main()
Both worked fine.
The Pi rebooted after about 15 seconds.
So as a minimum, we have a working system again.
If however, you have a better method, please chime in!
In the follow-up posts I will show how I got the systemd software watchdog to work, and also how to add extra support for your own application by using the systemd framework.
paulv
Re: Is this the correct way to install the BCM watchdog?
Thu May 12, 2016 8:50 am
[updated]
Now that Jessie embraces the systemd system, let's see what else that can bring to the ball game.
Systemd has a philosophy behind protection against hang-ups embedded in the system. It supports a, rather simple, software watchdog system. It does not have all the bells and whistles of the watchdog package I used above, but it is sufficient in many cases.
Let's set that up on a clean Jessie installation.
(if you used the watchdog package on this installation before, you need to disable the activation or remove that package all together : sudo apt-get remove watchdog. You can only run one or the other, not both) The reason is that the hardware watchdog device is single user only and you'll get access issues
Activate the systemd software watchdog:
NOTE
When you activate the systemd (software) watchdog, it automatically activates the BCM hardware watchdog. There is no need to activate it in the /boot/config.txt file. It does not seem to harm if you have already activated it that way though.
Follow these steps to activate and setup the software watchdog.
sudo nano /etc/systemd/system.conf
And change these two lines from:
#RuntimeWatchdogSec=20
#ShutdownWatchdogSec=10min
To :
The first line is all that is needed to activate the watchdog, I also decided to activate another safety measure as well. The default Runtime value of 20 (seconds) is halved and so the hardware watchdog device is actually "pinged" every 10 seconds. For this test I used 10 seconds, so the ping is every 5 seconds and if there is no activity within a 10 second period, the RPI is rebooted. Note that the default of 20 seconds is wrong (I think this is a bug) for the RPi. [NOTE: this has been fixed, the default now is 0]
The maximum is 15 seconds, and is set by the SOC counter. If you leave the original setting, you'll get a rather cryptic error message. The Shutdown setting is used to force a reboot if the shutdown process takes longer than 10 minutes (default), to prevent a hang in that process.
So all you need to do to start the systemd watchdog is to activate the "RuntimeWatchdogSec" setting, and optionally activate the "ShutdownWatchdogSec" option. That's all there is to it.
After setting this up, reboot the RPi to make the watchdog settings active.
First check the activation of the hardware watchdog by running:
It should return something like this :
May 20 08:33:43 raspi-server kernel: [ 10.362509] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
May 20 08:33:43 raspi-server systemd[1]: Hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0
May 20 08:33:43 raspi-server systemd[1]: Set hardware watchdog to 10s.
The first two lines show that the hardware watchdog device is activated. The third line shows that the software watchdog loaded our 10 sec. parameter.
A simple test to see if this protection works is by issuing a
sudo poweroff
When you have a console attached to the RPi, you can see what is going on. The Pi will go through the shutdown process, and seems to crash with a Kernel panic, but that is normal behavior. The last message on the console will tell you that it will reboot in 10 seconds, and so it does.
Now use one of the fork-bombs from the previous post to verify that the system works when there is a lack of response (no more pinging of the watchdog).
My RPi [Model (1) B] rebooted in about 15 seconds, unfortunately, there is not much showing on the console this time, other than some causes of the fork bomb.
So, with these simple steps we can add a minimum level of protection for systemd level hang-ups and kernel panics, to address what I call the "lowest level" protection.
When you have installed this method, how do you now cut the power to the Pi? It won't halt anymore either (sudo halt). Well, you have 10 seconds to pull the power plug at the end of the shutdown procedure.
As you will have realized by now, this method is perfect for embedded applications, servers, security camera's etc., to keep them running at all time, or reboot if they don't. Not so much for desktop applications, where you have much more control through a keyboard and console.
Although this does not offer the same variety of protection options the watchdog package offers, but wait, there's more that systemd has to offer.
The next step is to configure protection for the next level "up", the user application level, (or services in systemd speak) by using the systemd software watchdog interface system. I'll get to that in a next post.
Please chime in if you feel you can contribute.
paulv
Fri May 13, 2016 7:59 am
This is a follow-up to the first post.
There is a third solution to get the software watchdog package installed across a reboot.
I wanted to address that separate from the /etc/rc.local and crontab solution in the first post, because this solution makes a change to the package installation that may have consequences I cannot oversee.
In the first post I showed that the software watchdog refuses to install in the boot process by following the old and proven installation routine.
If you try to install the software watchdog package into the boot sequence the systemd way, with
you get this :
using systemctl.
I think this is confusing and not very helpful information for the typical RPi users. The last three items on this list deal with the absence of the [Install] section of the service file, but that is very general information and not much help for what we want to do.
Here is what is in the watchdog.service file that is located in /lib/systemd/system/
[Unit]
Description=watchdog daemon
Conflicts=wd_keepalive.service
After=multi-user.target
OnFailure=wd_keepalive.service
[Service]
Type=forking
EnvironmentFile=/etc/default/watchdog
ExecStartPre=/bin/sh -c '[ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module
ExecStart=/bin/sh -c '[ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options'
ExecStopPost=/bin/sh -c '[ $run_wd_keepalive != 1 ] || false'
[Install]
So the enable complaint "The unit files have no [Install] section. They are not meant to be enabled using systemctl." is factually incorrect, because there is an Install section, but it's empty. The statement "They are not meant to be enabled using systemctl" is misleading, and the rest is very general, but not helpful. In any case, the net-net is that systemd does not know when to install it in the boot sequence. It would be very helpful for the typical RPi audience if the text could be changed to give a pointer on what to do to make it active. Or by a comment in the .service file.
To help systemd to install the software watchdog in the boot process (enable it), all we need to do is to tell it when we want to have it installed. The most simple method is to wait until the system switches to the multi-user level, which is pretty much at the end of the boot process. If you look in the [Unit] section, you see that there is another hint that this is indeed the correct point in time:
This is how you do that:
1. Quick and Dirty Method:
Modify the original file.
sudo nano /lib/systemd/system/watchdog.service
And add this line after the [Install] section :
WantedBy=multi-user.target
That's all. However, you may loose this setting when you do an update/upgrade.
2. Preserve the Settings:
First copy the file from the original location to a place where user defined service files are to be located.
sudo cp /lib/systemd/system/watchdog.service /etc/systemd/system/
And make the change in this file. If systemd finds a file in this directory it is loaded instead of the original service file.
3. The Recommended Systemd Method
Create a so called "drop in" file that only adds or changes the settings you want. To create this drop-in file location, do this:
sudo mkdir /etc/systemd/system/watchdog.service.d
Then create a config file with only the changed or new parameters, in our case only the install section.
sudo nano /etc/systemd/system/watchdog.service.d/local.conf
Add this to the open editor:
[Install]
Save and close the editor.
Try that by updating the daemon setup files:
sudo systemctl daemon-reload
And then
Now you only get this :
insserv: warning: current start runlevel(s) (empty) of script `watchdog' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `watchdog' overrides LSB defaults (0 1 6).
Let's ask for a status report:
And you get this :
Loaded: loaded (/lib/systemd/system/watchdog.service; enabled)
Active: inactive (dead)
OK, ready for action. Let's start it now to test it.
And ask for a status report again
sudo systemctl -l status watchdog
(note the -l flag to avoid truncation) Now we get this :
Active: active (running) since Fri 2016-05-20 09:33:02 CEST; 1min 14s ago
Process: 705 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS)
Process: 702 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS)
Main PID: 707 (watchdog)
└─707 /usr/sbin/watchdog
May 20 09:33:02 raspi-server watchdog[707]: int=1s realtime=yes sync=no soft=no mla=24 mem=1
May 20 09:33:02 raspi-server watchdog[707]: ping: 192.168.1.1
May 20 09:33:02 raspi-server watchdog[707]: file: no file to check
May 20 09:33:02 raspi-server watchdog[707]: pidfile: no server process to check
May 20 09:33:02 raspi-server watchdog[707]: interface: no interface to check
May 20 09:33:02 raspi-server watchdog[707]: temperature: no sensors to check
May 20 09:33:02 raspi-server watchdog[707]: test=none(0) repair=none(0) alive=/dev/watchdog heartbeat=none to=root no_act=no force=no
May 20 09:33:02 raspi-server watchdog[707]: watchdog now set to 15 seconds
May 20 09:33:02 raspi-server watchdog[707]: hardware watchdog identity: Broadcom BCM2835 Watchdog timer
May 20 09:33:02 raspi-server systemd[1]: Started watchdog daemon.
Ok, while we're at it, try the fork bomb to force a reboot.
After the reboot, check the status again to see if it indeed loaded and is active:
So although it seems to be working, I'm not sure if this is the right way or the intended way to activate the software watchdog package. It seems overly vague and even misleading. Why does the watchdog.service file not have a complete [Install] section? That would really solve the problems, so is this a bug (oversight) or a feature? Or do we have it completely wrong?
If you know more about the "correct" way to install the software watchdog, please chime in.
paulv
Fri May 13, 2016 2:25 pm
If you want to use the systemd method of using a software watchdog to add control to your own application program, you can use the following method to implement that.
As I showed in an earlier post, you use the hardware BMC watchdog system to reboot the RPi when the kernel gets unresponsive, or when systemd is no longer operational.
A higher level of control can be added by a software watchdog. Systemd provides that, plus an interface to implement that.
The combination of the two provide the Supervisor chain (in systemd speak).
Ok, so what do you need to do.
There are two steps.
1. You need to provide a service configuration file for systemd to instruct it what to do.
2. You need to add a few things to your own application to make it all work in this environment.
In essence, you ask systemd to initiate a software watchdog, and your application needs to "ping" it at regular intervals. If the application fails to do that, systemd will take action.
I wrote a service file that will let you test a number of elements.
# This service installs a python test program that allows us to test the
# systemd software watchdog. This watchdog can be used to protect from hangups.
# On top of that, when the service crashes, it is automatically restarted.
# If it crashes too many times, it will be forced to fail, or you can let systemd reboot
[Unit]
Description=Installing Python test script for a systemd s/w watchdog
Requires=basic.target
[Service]
Type=notify
WatchdogSec=10s
ExecStart=/usr/bin/python /home/pi/systemd-test.py
Restart=always
# The number of times the service is restarted within a time period can be set
# If that condition is met, the RPi can be rebooted
StartLimitBurst=4
StartLimitInterval=180s
# actions can be none|reboot|reboot-force|reboot-immidiate
StartLimitAction=none
# The following are defined the /etc/systemd/system.conf file and are
# global for all services
#DefaultTimeoutStartSec=90s
#DefaultTimeoutStopSec=90s
# They can also be set on a per process here:
# if they are not defined here, they fall back to the system.conf values
TimeoutStartSec=2s
TimeoutStopSec=2s
[Install]
Details can be found if you look for systemd.service(5)
I also wrote a Python script that lets you play with this system and experiment to you hearts delight.
#!/usr/bin/python2.7
# Name:        systemd daemon & watchdog test file
# Purpose:
# Author:      paulv
# Created:     07-05-2016
import sys
import os
from time import sleep
import signal
import subprocess
import socket
init = True
def sd_notify(unset_environment, s_cmd):
    Notify service manager about start-up completion and to kick the watchdog.
    https://github.com/kirelagin/pysystemd-daemon/blob/master/sddaemon/__init__.py
    This is a reimplementation of systemd's reference sd_notify().
    sd_notify() should be used to notify the systemd manager about the
    completion of the initialization of the application program.
    It is also used to send watchdog ping information.
    global init
    sock = None
    try:
        if not s_cmd:
            sys.stderr.write("error : missing s_cmd\n")
            return(1)
        s_adr = os.environ.get('NOTIFY_SOCKET', None)
        if init : # report this only one time
            sys.stderr.write("Notify socket = " + str(s_adr) + "\n")
            # this will normally return : /run/systemd/notify
            init = False
        if not s_adr:
            sys.stderr.write("error : missing socket\n")
            return(1)
        sock = socket.socket(socket.AF_UNIX, socket.SOCK_DGRAM)
        sock.sendto(s_cmd, s_adr)
        # sendto() returns number of bytes send
        # in the original code, the return was tested against > 0 ???
        if sock.sendto(s_cmd, s_adr) == 0:
            sys.stderr.write("error : incorrect sock.sendto  return value\n")
            return(1)
    except e:
        pass
    finally:
        # terminate the socket connection
        if sock:
            sock.close()
        if unset_environment:
            if 'NOTIFY_SOCKET' in os.environ:
                del os.environ['NOTIFY_SOCKET']
    return(0) # OK
def sig_handler (signum=None, frame = None):
    This function will catch the most important system signals, but NOT a shutdown!
    During testing, you can use this code to see what termination methods are used or filter
    some out.
    This handler catches the following signals from the OS:
        SIGHUB = (1) SSH Terminal logout
        SIGINT = (2) Ctrl-C
        SIGQUIT = (3) ctrl-\
        IOerror = (5) when terminating the SSH connection (input/output error)
        SIGTERM = (15) Deamon terminate (deamon --stop): is coming from deamon manager
    However, it cannot catch SIGKILL = (9), the kill -9 or the shutdown procedure
    try:
        print "\nSignal handler called with signal : {0}".format(signum)
        if signum == 1 :
            sys.stderr.write("Sighandler: ignoring SIGHUB signal : " + str(signum) + "\n")
            return # ignore SSH logout termination
        sys.stderr.write("terminating : python test script\n")
        sys.exit(1)
    except Exception as e: # IOerror 005 when terminating the SSH connection
        sys.stderr.write("Unexpected Exception in sig_handler() : "+ str(e) + "\n")
        subprocess.call(['logger "Unexpected Exception in sig_handler()"'], shell=True)
        return
def main():
    # setup a catch for the following termination signals: (signal.SIGINT = ctrl-c)
    for sig in (signal.SIGTERM, signal.SIGINT, signal.SIGHUP, signal.SIGQUIT):
        signal.signal(sig, sig_handler)
    # get the timeout period from the systemd-test.service file
    wd_usec = os.environ.get('WATCHDOG_USEC', None)
    if wd_usec == None or wd_usec == 0:
        sys.stderr.write("terminating : incorrect watchdog interval sequence\n")
        exit(1)
    wd_usec = int(wd_usec)
    # use half the time-out value in seconds for the kick-the-dog routine to
    # account for Linux housekeeping chores
    wd_kick = wd_usec / 1000000 / 2
    sys.stderr.write("watchdog kick interval = " + str(wd_kick) + "\n")
    try:
        sys.stderr.write("starting : python daemon watchdog and fail test script started\n")
        # notify systemd that we've started
        retval = sd_notify(0, "READY=1")
        if retval <> 0:
            sys.stderr.write("terminating : fatal sd_notify() error for script start\n")
            exit(1)
        # after the init, ping the watchdog and check for errors
        retval = sd_notify(0, "WATCHDOG=1")
        if retval <> 0:
            sys.stderr.write("terminating : fatal sd_notify() error for watchdog ping\n")
            exit(1)
        ctr = 0 # setup a counter to initiate a watchdog fail
        while True :
            if ctr > 5 :
                sys.stderr.write("forcing watchdog fail, restarting service\n")
                sleep(20)
            sleep(wd_kick)
            sys.stderr.write("kicking the watchdog : ctr = " + str(ctr) + "\n")
            ctr += 1
    except KeyboardInterrupt:
        print "\nTerminating by Ctrl-C"
        exit(0)
    main()
The comments should give you an idea of what is needed. In a nutshell, the application needs to signal systemd that it has finished the initialization. At regular intervals, the software watchdog is updated. There is a fail condition in the code that will mimic a hung application.
Here is how you install and test this all.
Open an editor:
nano systemd-test.service
Copy and paste the service code above into the editor. Save the file and close the editor. Copy this file into the systemd structure with :
sudo cp systemd-test.service /etc/systemd/system
Open an editor again:
nano systemd-test.py
Copy and paste the Python code above into the editor. Save the file and close the editor. Make the python script executable :
chmod +x systemd-test.py
Run the service script in the systemd environment :
sudo systemctl start systemd-test
Watch what is going on with
tail -f /var/log/syslog
After 4 failures and automatic restarts of the python script, systemd declares it a failed state. You can also let the RPi reboot when this happens and all you need to do is to change StartLimitAction=none to StartLimitAction=reboot in the systemd-test.service file.
If you would like to test the application within the boot process, run this :
sudo systemctl enable systemd-test
After a reboot, you can again watch it all by using the above tail command again.
If you decide to change the Python script, you can do that while the system is running. At the next restart, the new code is automatically loaded and executed. If you want to change parameters in the .service file, you can do that too, but you need to activate and reload those changes. You do that with
and then
sudo systemctl restart systemd-test
I had great fun to discover all the possibilities systemd now offers me to add better control to my own scripts.
Please chime in if you have improvements or suggestions!
Enjoy!
paulv
Re: Is this the correct way to install the watchdog package?
Wed May 18, 2016 7:55 pm
I have not received any comments or replies to this post, nor on a request on stackoverflow.
http://stackoverflow.com/questions/3714 ... th-systemd
I filed a bug report hoping that will lead to a solution or clarification.
https://bugs.launchpad.net/raspbian/+bug/1582707
sskn
Sun Jun 05, 2016 5:20 am
Thanks a lot!
I successfully activated the watchdog timer with simple way (2nd post).
I was confused because I couldn't install and activate the watchdog package using the way for old version of raspbian.
ejolson
Mon Jun 06, 2016 8:08 am
paulv wrote:I have not received any comments or replies to this post, nor on a request on stackoverflow.
This is a very interesting post. While reading the first part one starts to sympathize with the graybeards who who claim systemd is trying to take over the world and ruin it. The second post then points out how nicely systemd directly interfaces with the watchdog hardware.
Eric Raymond said, "...it looks like Plan 9 failed simply because it fell short of being a compelling enough improvement on Unix to displace its ancestor." At this point in time systemd has replaced the System V init deamon in almost all major Linux distributions. Hopefully the resulting improvement will be worth the hardships caused.
torekk
Contact: ICQ
Tue Jun 07, 2016 6:09 pm
Thank you for this.
However I noticed that when I shutdown the Pi manually, it doesn't reboots itself after 10 seconds? Or is that what the Shutdown setting is for, seeing as that's set so 10minutes?
Anyways that's actually what I wanted, watchdog to reboot the Pi once it freezes, but not if I shut it down manually.
onefastt997
Sat Sep 03, 2016 1:53 am
Thanks for this. It doesn't power back up when I do sudo poweroff but it definitely recovers from the fork bombs.
Samweis
Mon Sep 26, 2016 8:21 am
Thanks for this!
For whatever reason the file /etc/systemd/system/watchdog.service.d/local.conf did not work for me,
but
ln -s /lib/systemd/system/watchdog.service /etc/systemd/system/multi-user.target.wants/
did the trick.
paulv
Mon Sep 26, 2016 5:21 pm
Hi Samweis,
This is most likely the appropriate way of getting the watchdog to behave with systemd.
I found that out using another package, so this is probably the way to go.
Thanks for contributing!
Paul
shalvan
Sun Oct 02, 2016 5:25 am
Hello there,
I have a problem witch watchdog on Raspberry pi b+ 512mb with fresh jessie install.
I did everything like You, but when i run command:
nothing happens
When i was using Wheezy watchdog worked like charm, and now it donst :(
paulv
Sun Oct 02, 2016 12:50 pm
shalvan,
You're not very specific.
What does the status report tell you? Can you post that?
shalvan
Sun Oct 02, 2016 1:02 pm
this is my status:
pi@RasPi:~ $ sudo systemctl status watchdog
  Drop-In: /etc/systemd/system/watchdog.service.d
           └─local.conf
when i start with :
all i see is blinking cursor one line below my command and nothing else happens. Just like the command is trying to do something but still nothing.
paulv
Sun Oct 02, 2016 1:14 pm
Are you on the same software version that I used to report my post?
If you are on a newer version, you can thank the powers to be for yet another change of the goalposts, and I can't help you at this moment. Maybe somebody else already knows what changed this time...
Note that nobody from the Foundation chimed in to help with my post or clarify what is going on. :(
Good luck!
shalvan
Sun Oct 02, 2016 1:23 pm
My version is:
Linux RasPi 4.4.17+ #902 Mon Aug 15 12:17:32 BST 2016 armv6l GNU/Linux
but i am experiencing this problem from febuary, it was then when i switched to Jessie.
gkoper
Tue Oct 11, 2016 5:19 pm
Dear paulv
Thanks for your extensive description of the results of your research. Impressive!
I did some tests on a more recent version of Rasbian, the version is Jessie Lite
Linux TestPi2 4.4.21+ #911 Thu Sep 15 14:17:52 BST 2016 armv6l GNU/Linux
As you already surmised, things would be different for later versions and indeed they are!
First of all, the watchdog device is already loaded from the start, although there is no entry in the /boot/config.txt file.
I had a preference for the second method using the systemd. The entries could indeed be set in system.conf file and after booting one could find the watchdog records in the syslog. So far so good. However, neither the simple test involving poweroff nor a fork bomb would make the watchdog bark and cause a reboot! I did find out, that the /dev/watchdog was allocated after setting a nonzero RuntimeWatchdogSec in system.conf though: apparently something had happened! Since I did not have a clue how to proceed, I left this issue alone.
I briefly turned to the first option, using the watchdog package but I stopped as it would not serve my purpose. I would like to monitor a program I wrote to continuously send weather reports to wunderground.com. It already runs for weeks without problems. However, sometimes Rasbian causes a problem that hangs the program or there is a hardware issue. Both are typically resolved by rebooting but that so far had to be done manually.
I found out that the method (http://binerry.de/post/28263824530/rasp ... hdog-timer) described by Binerry actually can be used still despite being 4 years old. The only requirement is to have free access to /dev/watchdog so that means that in system.conf the parameter RuntimeWatchdogSec should be set to zero.
Noting your success to get more information on Raspbian issues added up to my own ("this may be resolved in a later version ...") I think on the short run the Binerry method is the preferred one. Nevertheless, I would like to know how to deal properly with the "second" method involving the systemd. This is the standard Linux method of dealing with the watchdog but maybe it is still under construction? Hope this invites some useful comments.
gkoper
paulv
Tue Oct 11, 2016 7:02 pm
Hi gkoper,
Thanks for contributing to this post.
My own experience, after several years of working with the RPi's, is that the RPi environment is still very much a work in progress (no, that's a bit too generous, let's call it process). As other users regularly comment, the goal posts seem to get moved just about every update. What works with one release may not work with the next, and the forums are full of users that are left dangling.
Alas, back to the topic. I have found, through another project of mine, that the watchdog is initiated automatically by systemd as soon as you invoke the following in a service setup, as an example:
[Service]
# Add restart options
Restart=always
RestartSec=5
StartLimitBurst=4
# Add optional rebooting options:
This makes sense, but unfortunately, this is not mentioned anywhere, at least not as far as I could find, but that's not much of a guarantee either.
I guess we have to wait until the fog clears, or when enough users start to complain to raise the issue.
If that sounds skeptical, it is caused by the growing frustration of working with the RPi's for several years now and contribution many posts and designs that continuously need tweaking, fixing and updating. As a result, I switched platforms and interest levels and so the Pi has taken a back-seat.
Good luck!
gkoper
Wed Oct 12, 2016 7:43 am
Thanks paulv
I will have a look later.
Regarding any support, please note that upon startup Raspbian says:
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
In other words, no promises made.
gkoper
no3rpi
Fri Mar 31, 2017 12:12 pm
paulv I want to thank you for investigating and solving this really important issue with watchdog ( at least for me ).
I am using rpi3 as private email server and cctv monitor, headless in a remote location and unfortunately until now in 2 years I had several incidents when it stop respond to any network traffic ( ssh, tcp, udp ....) and had to be hard reset - restarted by hand, despite using monit and other redundant solution to allow me to remote access it.
Today after last incident I implemented your solution from second post and I want to confirm that until now it seems to work ok for this raspberry pi 3:
uname -a:
Linux rpi3 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
/opt/vc/bin/vcgencmd version:
Mar  3 2017 13:43:37
Copyright (c) 2012 Broadcom
version 9ae30f71c7ef4239e9d5b56346c0842f3ef56736 (clean) (release)
I edited:
/etc/systemd/system.conf with:
reboot and tested: cat /var/log/syslog | grep watchdog
Mar 30 11:17:05 rpi3 kernel: [    8.096998] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Mar 31 10:06:52 rpi3 kernel: [    6.056467] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Mar 31 10:06:52 rpi3 systemd[1]: Hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0
Mar 31 10:06:52 rpi3 systemd[1]: Set hardware watchdog to 10s.
Mar 31 10:06:53 rpi3 systemd[1]: Hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0
Mar 31 10:06:53 rpi3 systemd[1]: Set hardware watchdog to 10s.
Mar 31 10:06:53 rpi3 kernel: [    6.797667] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
tested with your bomb script and rpi3 is restarting ok;
for the moment I did not tested if at "shutdown -h now" it will be restarted automatically or not.
I hope watchdog solution will solve hang out problem from now on...
thank you.
paulv
Fri May 19, 2017 3:10 pm
As was almost to be expected, the description I wrote above no longer works.
The proverbial goal posts have been move once again by the powers in the tower.
Is there anybody that can shed some light on this obscure procedure?
A few pointers.
The hardware watchdog devices are now always listed, regardless of the dt setting in config.txt
The dt setting is required to "really" activate these devices. - There is no entry in the syslog that the watchdog is activated, the entry in systlog does not change if you add the activation - this seems an oversight or a bug.
The watchdog service file (/lib/systemd/system/watchdog.service) is no longer there.
Syslog no longer reports the activation of the systemd watchdog settings - this seems to be a bug to me.
There is no more termination information going to the console anymore if systemd or the watchdog terminates. There is a console reset and a new boot. This also seems to be a bug to me.
It looks like it is no longer possible to cause an automatic reboot after a shutdown/halt/poweroff, like before. - This is either an intentional "fix", without any documentation, or a bug, or a new method is required, and that needs documentation - please.
What still works:
If the watchdog is activated in config.txt and the systemd watchdog is activated in the /etc/systemd/system.conf file, the forkbomb still reboots the Rpi.
Installing a systemd service that watches over a user script, using the notify option, as I showed in an earlier post still works and all that activity is (still) reported in the syslog.
Help!
no3rpi
Fri May 19, 2017 3:49 pm
Yes it is true and really bad news.
uname -a
Linux rpi3 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
nothing to display from log... $#&!
no3rpi
Mon May 22, 2017 1:41 pm
@paulv
editing a previous post is not a good idea if you add new / update info because there is no notification for users flowing this thread.
At least please add a last message with what post is updated if something important you discovered/changed.
By chance I re-read all this thread today and I found that I also need to have watchdog activated also in config.txt beside /etc/systemd/system.conf file I only used until now...
now I can see in log:
cat syslog | grep watchdog
May 22 16:20:58 rpi3 kernel: [    0.813864] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
thank you.
brunohpg
Sat Jun 03, 2017 11:12 pm
Thanks @paulv for your research and for posting the results.
I was able to start the watchdog successfully. But now I have some (new) problems.
First, I did all the tests in the version:
Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
Almost everything worked as expected. Message were logged and fork bomb performs reboot. I thought: Great! I have the solution!
So I've been enable watchdog systemd on:
Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
Following these steps:
1º Configure /boot/config.conf by adding:
dtparam=watchdog=on
2º Configure /etc/systemd/system.conf by changing:
ShutdownWatchdogSec=5min
Only that! It works. At least partially.
But not all things worked as expected.
The messages are no longer logged. There is only one message in the log:
Jun  3 18:48:46 raspberrypi kernel: [    0.831289] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
The system keeps restarting with fork bomb, but it is lazy.
When fork bomb is run by root, the system reboot (properly).
When fork bomb is run by pi user, the watchdog does not catch. I get a lot of messages like:
./forkbomb.sh: fork: Cannot allocate memory
./forkbomb.sh: xmalloc: .././array.c:581: cannot allocate 24 bytes (40960 bytes
The system restarted after a few minutes. But I'm afraid it will not always work.
These messages are also displayed using the watchdog package. However, I believe the watchdog package memory limit test will reboot the device first.
So I went to install the watchdog package. With the steps:
1º Enabling watchdog in /boot/config.txt by adding:
dtparam=watchdog=on
2º Installing the watchdog package:
3º Modifying the /etc/watchdog.conf (others lines remaing not changed):
max-load-1              = 24
min-memory              = 1
watchdog-timeout=15
4º Linked the service to start on boot (thanks to @Samweis):
5º Reboot the raspberry pi.
That is it!
And now I have:
root@raspberrypi:/home/pi# ps -Af | grep watchdog
root        36     2  0 19:45 ?        00:00:00 [watchdogd]
root       822     1  0 19:45 ?        00:00:00 /usr/sbin/watchdog
root       902   884  0 19:46 pts/1    00:00:00 grep watchdog
And...
root@raspberrypi:/home/pi# sudo systemctl status watchdog
   Active: active (running) since Sáb 2017-06-03 19:45:26 -03; 3min 30s ago
  Process: 820 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS)
  Process: 815 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS)
 Main PID: 822 (watchdog)
           └─822 /usr/sbin/watchdog
Jun 03 19:45:26 raspberrypi watchdog[822]: int=1s realtime=yes sync=no soft=no mla=24 mem=1
Jun 03 19:45:26 raspberrypi watchdog[822]: ping: no machine to check
Jun 03 19:45:26 raspberrypi watchdog[822]: file: no file to check
Jun 03 19:45:26 raspberrypi watchdog[822]: pidfile: no server process to check
Jun 03 19:45:26 raspberrypi watchdog[822]: interface: no interface to check
Jun 03 19:45:26 raspberrypi watchdog[822]: temperature: no sensors to check
Jun 03 19:45:26 raspberrypi watchdog[822]: test=none(0) repair=none(0) alive=/dev/watchdog heartbeat=none to=root no_act=no force=no
Jun 03 19:45:26 raspberrypi watchdog[822]: watchdog now set to 15 seconds
Jun 03 19:45:26 raspberrypi watchdog[822]: hardware watchdog identity: Broadcom BCM2835 Watchdog timer
Jun 03 19:45:26 raspberrypi systemd[1]: Started watchdog daemon.
Fork bomb now reboot the device in a few seconds.
I believe it's better than the systemd watchdog. :D
I do not think there's anything really new here. Just a few considerations and a step by step to start the watchdog in the newer versions of the kernel.
I 'm using Raspberry PI 3.
paulv
Sun Jun 04, 2017 6:57 pm
Hi brunohpg,
Thanks for taking the time to report your findings.
I can concur with your systemd findings, mine are exactly the same.
Something got broken somewhere, and it seems the watchdog package still works.
I hope a fix can be found and communicated.
Let me point out to others reading this post that the two systems are not compatible. The hardware watchdog device is strictly single user, and it cannot be shared among the native systemd method and the watchdog package. They are different systems.
Return to “Advanced users”
Who is online
Users browsing this forum: No registered users and 4 guests
