Piminiuser
Raspi 2 Voltage Measurement
Fri Feb 13, 2015 11:50 am
How to measure the voltage on the pi 2? The old one had TP1 and TP2 points to measure on it. But the pi 2 don't have the TP1 and TP2 point.
klricks
Re: Raspi 2 Voltage Measurement
Fri Feb 13, 2015 2:58 pm
Use test points on bottom of board near the micro USB.
PP1 or PP2 or F1 side closest to the edge of the board = 5V from micro USB (Before the fuse).
PP3 or PP5 = Ground. Or any of the metal shields on USB, RJ45 etc.
Piminiuser
Fri Feb 13, 2015 5:00 pm
Thnx!
is it also possible to measure after the fuse?
klricks wrote:Use test points on bottom of board near the micro USB.
klricks
Fri Feb 13, 2015 6:11 pm
Piminiuser wrote:Thnx!
That is PP7 on B+ but haven't verified on the RPi2.
You can measure after the fuse at F1 side closest center of board or GPIO header pin 2 or 4.
claudioita
Fri Oct 06, 2017 2:56 pm
is it possible ot measure via software?
FTrevorGowen
Fri Oct 06, 2017 6:22 pm
claudioita wrote:is it possible ot measure via software?
No, or at least not without additional circuitry, including a (calibrated) A/D converter. (A Pi doesn't have any "analogue" inputs). However it is possible to check whether a low-voltage trigger has happened (via the mechanism used to trigger the display of the low-voltage icon).
Trev.
