Is the Model A+ capable enough for my project?
Posted: Mon Feb 09, 2015 9:55 am
by ant_thomas
I've got a project in place currently using a Model A+ that controls my central heating system.
It currently has a small LCD connected over SPI using the notro FBTFT modules.
On boot it loads Midori and a webpage which is essentially an info page for the central heating.
I'm using a USB ethernet adapter.
It seems to be getting low on free memory, Midori looks to hog quite a lot of resources which I think is causing some instability.
Should the A+ be up to the job of running Midori 24/7 in Kiosk/Fullscreen mode? Realisitcally the actual central heating scripts don't cause any issues because they are very simple and have very little impact on resources.
I originally used Chromium but that really does use resources like it's going out of fashion.
Is it best I just use a 512MB model (or RPi2?)
Re: Is the Model A+ capable enough for my project?
Posted: Mon Feb 09, 2015 10:01 am
by RaTTuS
depends on your memeory usage
why not dispense with the GUI webbrower and use elinks or do a curses display
by DougieLawson
You may be able to get some RAM back by lowering
gpu_mem=128
to the bare minimal value needed to get Xwindows to start. You're not using the GPU with a TFT.
Also look at switching to G√ľnter Kreidl's kweb3 kiosk browser rather than your Midori memory hog.
http://www.raspberrypi.org/forums/viewtopic.php?t=40860
Posted: Mon Feb 09, 2015 12:14 pm
by ant_thomas
Thanks for the replies.
I want to keep a "full-featured" browser so I'll give kweb3 kiosk browser a go.
It's not displaying much though!
