Mettauk
Pi2 B and Pi-Pan (ServoBlaster)
Sat Feb 07, 2015 10:08 pm
I'm trying to install and run pi-pan on a Pi2 B without sucsess.
wget http://openelectrons.com/files/documents/pi-pan.tar.gz
unzip
tar -zxvf pi-pan.tar.gz
Install ServoBlaster in your init scripts by following command:
sudo ./install-pi-pan.bash
It freezes on install with the message "update-rc.d: using dependency based boot sequencing"
On one occasion it did seem to install but testing with
cd pi-pan
sudo python demo-pi-pan.py
does not work??
Not at all sure why?
Tried with and without all updates to raspbain in dist-upgrade all fail??
Anyone?
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
DirkS
Re: Pi2 B and Pi-Pan (ServoBlaster)
Sat Feb 07, 2015 10:20 pm
Pi2B uses kernel 3.18 with device trees.
Maybe http://www.raspberrypi.org/forums/viewt ... 28&t=97314 is relevant for you
joan
Sat Feb 07, 2015 10:32 pm
Anything which uses userland DMA will require updating above and beyond the peripheral base address move (0x20000000 -> 0x3F00000) to work on the Pi 2.
A partial list of affected software includes servoblaster, pi-blaster, RPIO.GPIO, and my own pigpio.
Mettauk
Sat Feb 07, 2015 11:11 pm
Will a fix be issued by the respective designers of all the drivers or will the foundation resolve this "mess" ?!
joan
Sat Feb 07, 2015 11:24 pm
Mettauk wrote:Will a fix be issued by the respective designers of all the drivers or will the foundation resolve this "mess" ?!
This is all third party software, nothing to do with the charity. It'll be up to the third parties to update their software if they want to maintain compatibility with the Pi 2.
Mettauk
Sat Feb 07, 2015 11:54 pm
Hmm, so the changes in hardware are not just "4 cores and more ram"! Most add on hardware will no longer work without complex updates and changes to software which are well beyond most users! :evil: :twisted:
Lesson.... moan, groan and then patience.... learning....
joan
Sat Feb 07, 2015 11:59 pm
You are being unduly pessimistic. I doubt it is most add on hardware. I'd have thought that little add on hardware would be relying on userland DMA - it's pretty esoteric.
Mettauk
Sun Feb 08, 2015 12:46 am
I was referring to GPIO stuff rather than USB etc.
Possibly pessimistic, but even temp sensors seem to be giving odd readings "with" updated Pi2 software. Led to beleive backwards compatable. Turns out not to be quite true... for now.
Paul Webster
Contact: Twitter
Sun Feb 08, 2015 9:13 am
joan wrote:A partial list of affected software includes servoblaster, pi-blaster, RPIO.GPIO, and my own pigpio.
plus LCDproc - for which I have submitted a patch to their Sourceforge page - but no response yet.
gardav
Sun Feb 08, 2015 1:54 pm
80% of our robots have pan/tilt servos driven by servoblaster which doesn't work now. So basically we are unable to ship product until this "esoteric" issue is resolved. jasmesh says it is a 1 line fix, but doesn't give details?
Paul Webster
Contact: Twitter
Sun Feb 08, 2015 6:07 pm
People have started working ion Servoblaster - but it will be more than 1 line.
Looks like there are quite a few memory references that will have to change.
https://github.com/richardghirst/PiBits/issues
Sun Feb 08, 2015 6:21 pm
gardav wrote:80% of our robots have pan/tilt servos driven by servoblaster which doesn't work now. So basically we are unable to ship product until this "esoteric" issue is resolved. jasmesh says it is a 1 line fix, but doesn't give details?
Sorry, it's been pointed out that there are other issues than he one I was aware of (thanks Joan). The peripheral base address is a one line change, but userland DMA is still an issue (if you use it). I'm going to prompt Dom and Phil at the Foundation to try and help out, as that's out of my knowledge zone.
For the moment, stick with B+ if you need to ship right now, and give the P2 a couple of weeks to settle down.
Mon Feb 09, 2015 10:08 am
So, after a chat with Dom,
there are two new functions to recover the peri base address and the SD ram address. This second is what you should need for userland DMA. If I understand correctly.
unsigned bcm_host_get_sdram_address(void);
All in this commit
https://github.com/raspberrypi/userland ... 2ca631f0e9
PiGraham
Mon Feb 09, 2015 10:13 am
Good advice for any product update. Don't switch your product line to the latest release the week it comes out.
joan
Mon Feb 09, 2015 11:23 am
jamesh wrote:So, after a chat with Dom,
All in this commit
Unfortunately those are the two changes I initially made to pigpio for the Pi 2. They are not sufficient. The symptoms are exactly the same as the ones I originally had with userland DMA. There is a difference between the DMA view of memory and the userland view of memory.
The effect is that a userland write to memory appears to be held in cache for a random time before being committed to memory.
Similarly userland reads seem to be getting a cached view of memory rather than the value transferred by DMA.
The fundamental change seems to be the inability to mmap addresses in the 0xC0000000 region. On earlier Pi models it was possible to mmap addresses in the then used 0x40000000 region.
The result of trying to mmap 0xC0000000 is a Pi 2 hang. I'm not sure at the moment if the hang is caused by the mmap or a later attempt to access the mmap'd memory.
joan
Mon Feb 09, 2015 12:05 pm
Two examples.
Firstly mmap'ing memory in the 0x00000000 region (L1/L2 cached) which works but causes timing problems during initialisation.
[email protected] /ram $ sudo ./x_pigpio
rev=10489921 pb=3F000000 ba=C0000000 bc=0
2015-02-09 11:41:12 initZaps: dmaV1=76e1c000 dmaV2=76DE7000 dmaP=3369B000 bm=3369B000
2015-02-09 11:41:12 initZaps: write 13171923, read=13171923
2015-02-09 11:41:12 initZaps: dmaV1=76e1c000 dmaV2=76DE8000 dmaP=35104000 bm=35104000
2015-02-09 11:41:12 initZaps: dmaV1=76e1c000 dmaV2=76DE9000 dmaP=33395000 bm=33395000
elided
initing DMA
Version.
pigpio version 28.
Hardware revision 10489921.
Mode/PUD/read/write tests.
TEST  1.1  PASS (set mode, get mode: 0)
TEST  1.2  PASS (set pull up down, read: 1)
TEST  1.3  PASS (set pull up down, read: 0)
TEST  1.4  PASS (write, get mode: 1)
TEST  1.5  PASS (read: 0)
TEST  1.6  PASS (write, read: 1)
PWM dutycycle/range/frequency tests.
TEST  2.1  PASS (set PWM range, set/get PWM frequency: 10)
TEST  2.2  PASS (get PWM dutycycle: 0)
TEST  2.3  PASS (set PWM dutycycle, callback: 0)
TEST  2.4  PASS (get PWM dutycycle: 128)
TEST  2.5  PASS (set PWM dutycycle, callback: 40)
TEST  2.6  PASS (set/get PWM frequency: 100)
TEST  2.7  PASS (callback: 400)
TEST  2.8  PASS (set/get PWM frequency: 1000)
TEST  2.9  PASS (callback: 4000)
TEST  2.10 PASS (get PWM range: 255)
TEST  2.11 PASS (get PWM real range: 200)
TEST  2.12 PASS (set/get PWM range: 2000)
TEST  2.13 PASS (get PWM real range: 200)
PWM/Servo pulse accuracy tests.
TEST  3.1  PASS (get servo pulsewidth: 500)
^C2015-02-09 11:41:32 sigHandler: Unhandled signal 2, terminating
micros=5
samples 4563 maxSamples 2 maxEmit 0 emitFrags 0
cb time 11028, calls 10755 alert ticks 10231
        0         0         0         0         0         0         0         0         1         0         0         0         1         0         0         0         1         0         0         0         0         0         0         1      2019     73458      2044         0         0         0         0         0         0         0         1         0         0         0         1         0         0         0         1         0         0         0         0         0         0         0
Secondly mmap'ing memory in the 0xC0000000 region (direct uncached).
The mmap succeeds but writes are read back as 0. The Pi 2 hangs at some currently undetermined later stage.
rev=10489921 pb=3F000000 ba=C0000000 bc=C0000000
2015-02-09 11:43:43 initZaps: dmaV1=76d81000 dmaV2=76D4C000 dmaP=34F64000 bm=F4F64000
2015-02-09 11:43:43 initZaps: write 13171923, read=0
2015-02-09 11:43:43 initZaps: dmaV1=76d81000 dmaV2=76D4D000 dmaP=36BB0000 bm=F6BB0000
2015-02-09 11:43:43 initZaps: dmaV1=76d81000 dmaV2=76D4E000 dmaP=36524000 bm=F6524000
2015-02-09 11:43:43 initZaps: dmaV1=76d81000 dmaV2=76D4F000 dmaP=3602F000 bm=F602F000
elided
HANG
Mon Feb 09, 2015 1:33 pm
Thanks Joan, am passing this data on to Dom/PhilE. It's wildly outside my level of expertise...sadly.
joan
Mon Feb 09, 2015 1:39 pm
jamesh wrote:Thanks Joan, am passing this data on to Dom/PhilE. It's wildly outside my level of expertise...sadly.
...and mine, sadly.
irknowles
Mon Feb 09, 2015 1:51 pm
I am all but a beginner on this. I am using pigpiod (which is brilliant) - have a new Pi2 and trying to get the new board running my system. I am intrigued to ask, before the Hang has the DMA debug register been read to determine if there was an error. Looking at the data sheet for BCM2835 (0_DEBUG 1_DEBUG 2_DEBUG 3_DEBUG 4_DEBUG 5_DEBUG 6_DEBUG Register) - Perhaps this holds a clue ? Also, is there a Datasheet for BCM2836, which may offer a definitive insight to what has changed ?
I also read that the protection must be added when DMA is used to keep byte-order (memory write/read barrier) - Could this be causing the Hang - i.e DMA returning out of order data ?
Mon Feb 09, 2015 1:58 pm
That whooshing noise is the sound of what you just wrote flying over my head.
No data sheet yet, but it almost identical to the 2835, except, it seems, for this bit...
gadgetoid
Mon Feb 09, 2015 2:06 pm
I must admit, I'm here lurking in the sidelines hoping the resolution to this problem is what I need to get Unicorn HAT up and running on the Pi 2 and wondering if it's relevant to this line of code here: https://github.com/pimoroni/UnicornHat/ ... RPi.c#L576
There's definitely been a consistent whooshing sound over my head for the last week, but I'm starting to understand bits and pieces.
I've a suspicion that my problem is more to do with pwm on Pin 18, and something conflicting with it, than DMA though.
PhilE
Mon Feb 09, 2015 2:49 pm
joan, do you have a self-contained test I can download and try?
joan
Mon Feb 09, 2015 2:53 pm
gadgetoid wrote:I must admit, I'm here lurking in the sidelines hoping the resolution to this problem is what I need to get Unicorn HAT up and running on the Pi 2 and wondering if it's relevant to this line of code here: https://github.com/pimoroni/UnicornHat/ ... RPi.c#L576
That line should be changed to or in 0xC0000000 rather than 0x40000000. Anything DMA related which adds or ors a constant of 0x40000000 on earlier models should be changed to 0xC0000000 on the Pi 2. With one exception (I think) if it is DMA related and it is a parameter to a mmap call change 0x40000000 to 0x0.
dom
Mon Feb 09, 2015 3:01 pm
joan wrote:The fundamental change seems to be the inability to mmap addresses in the 0xC0000000 region. On earlier Pi models it was possible to mmap addresses in the then used 0x40000000 region.
mmap takes arm physical addresses, so they should lie between 0 and 1G - never 0xC0000000 (which is a bus address).
All arm accesses go through the VC MMU which will map 0x00000000 -> 0x40000000 (GPU L2 cached on Pi1) or 0xC0000000 (GPU L2 uncached on Pi2)
It turns out the mmap-ing 0x40000000 on Pi1 was wrong, but didn't immediately die. The corresponding bug of mmap-ing 0xC0000000 on Pi2 is fatal.
Check out this fix.
joan
Mon Feb 09, 2015 3:05 pm
PhilE wrote:joan, do you have a self-contained test I can download and try?
To demonstrate what?
The version (27) of pigpio at http://abyz.co.uk/rpi/pigpio/pigpio.zip has been altered to reflect the new changes but will hang.
I attach a copy of userland servoblaster which is more self contained. However you'd need to have some LEDs or servos attached to gpios to see if it is functioning properly.
servoblaster Makefile
.PHONY: all install uninstall
all:	servod
servod:	servod.c
	gcc -Wall -g -O2 -o servod servod.c -lm
install: servod
	[ "`id -u`" = "0" ] || { echo "Must be run as root"; exit 1; }
	cp -f servod /usr/local/sbin
	cp -f init-script /etc/init.d/servoblaster
	chmod 755 /etc/init.d/servoblaster
	update-rc.d servoblaster defaults 92 08
	/etc/init.d/servoblaster start
uninstall:
	[ -e /etc/init.d/servoblaster ] && /etc/init.d/servoblaster stop || :
	update-rc.d servoblaster remove
	rm -f /usr/local/sbin/servod
	rm -f /etc/init.d/servoblaster
clean:
	rm -f servod
servoblaster servod.c
I have changed references to 0x20xxxxxx to 0x3Fxxxxxx.
The DMA related stuff is where the following constants are used.
#define BUS_OFFSET_1 0xC0000000
#define BUS_OFFSET_2 0x00000000
It's the BUS_OFFSET_2 part which is not working (the mmap call). I believe the proper value should be as BUS_OFFSET_1.
 * servod.c Multiple Servo Driver for the RaspberryPi
 * Copyright (c) 2013 Richard Hirst <[email protected]>
 * This program provides very similar functionality to servoblaster, except
 * that rather than implementing it as a kernel module, servod implements
 * the functionality as a usr space daemon.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
/* TODO: Separate idle timeout handling from genuine set-to-zero requests */
/* TODO: Add ability to specify time frame over which an adjustment should be made */
/* TODO: Add servoctl utility to set and query servo positions, etc */
/* TODO: Add slow-start option */
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
#include <stdarg.h>
#include <stdint.h>
#include <signal.h>
#include <time.h>
#include <sys/time.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <getopt.h>
#include <math.h>
#define DMY	255	// Used to represent an invalid P1 pin, or unmapped servo
#define NUM_P1PINS	26
#define NUM_P5PINS	8
#define MAX_SERVOS	32	/* Only 21 really, but this lets you map servo IDs
				 * to P1 pins, if you want to
#define MAX_MEMORY_USAGE	(16*1024*1024)	/* Somewhat arbitrary limit of 16MB */
#define DEFAULT_CYCLE_TIME_US	20000
#define DEFAULT_STEP_TIME_US	10
#define DEFAULT_SERVO_MIN_US	500
#define DEFAULT_SERVO_MAX_US	2500
#define DEVFILE			"/dev/servoblaster"
#define CFGFILE			"/dev/servoblaster-cfg"
#define PAGE_SIZE		4096
#define PAGE_SHIFT		12
#define DMA_CHAN_SIZE		0x100
#define DMA_CHAN_MIN		0
#define DMA_CHAN_MAX		14
#define DMA_CHAN_DEFAULT	14
#define DMA_BASE		0x3F007000
#define DMA_LEN			DMA_CHAN_SIZE * (DMA_CHAN_MAX+1)
#define PWM_BASE		0x3F20C000
#define PWM_LEN			0x28
#define CLK_BASE	        0x3F101000
#define CLK_LEN			0xA8
#define GPIO_BASE		0x3F200000
#define GPIO_LEN		0x100
#define PCM_BASE		0x3F203000
#define PCM_LEN			0x24
#define DMA_NO_WIDE_BURSTS	(1<<26)
#define DMA_WAIT_RESP		(1<<3)
#define DMA_D_DREQ		(1<<6)
#define DMA_PER_MAP(x)		((x)<<16)
#define DMA_END			(1<<1)
#define DMA_RESET		(1<<31)
#define DMA_INT			(1<<2)
#define DMA_CS			(0x00/4)
#define DMA_CONBLK_AD		(0x04/4)
#define DMA_DEBUG		(0x20/4)
#define GPIO_FSEL0		(0x00/4)
#define GPIO_SET0		(0x1c/4)
#define GPIO_CLR0		(0x28/4)
#define GPIO_LEV0		(0x34/4)
#define GPIO_PULLEN		(0x94/4)
#define GPIO_PULLCLK		(0x98/4)
#define GPIO_MODE_IN		0
#define GPIO_MODE_OUT		1
#define PWM_CTL			(0x00/4)
#define PWM_DMAC		(0x08/4)
#define PWM_RNG1		(0x10/4)
#define PWM_FIFO		(0x18/4)
#define PWMCLK_CNTL		40
#define PWMCLK_DIV		41
#define PWMCTL_MODE1		(1<<1)
#define PWMCTL_PWEN1		(1<<0)
#define PWMCTL_CLRF		(1<<6)
#define PWMCTL_USEF1		(1<<5)
#define PWMDMAC_ENAB		(1<<31)
#define PWMDMAC_THRSHLD		((15<<8)|(15<<0))
#define PCM_CS_A		(0x00/4)
#define PCM_FIFO_A		(0x04/4)
#define PCM_MODE_A		(0x08/4)
#define PCM_RXC_A		(0x0c/4)
#define PCM_TXC_A		(0x10/4)
#define PCM_DREQ_A		(0x14/4)
#define PCM_INTEN_A		(0x18/4)
#define PCM_INT_STC_A		(0x1c/4)
#define PCM_GRAY		(0x20/4)
#define PCMCLK_CNTL		38
#define PCMCLK_DIV		39
#define DELAY_VIA_PWM		0
#define DELAY_VIA_PCM		1
#define ROUNDUP(val, blksz)	(((val)+((blksz)-1)) & ~(blksz-1))
typedef struct {
	uint32_t info, src, dst, length,
		 stride, next, pad[2];
} dma_cb_t;
typedef struct {
	uint32_t physaddr;
} page_map_t;
/* Define which P1 header pins to use by default.  These are the eight standard
 * GPIO pins (those coloured green in the diagram on this page:
 *    http://elinux.org/Rpi_Low-level_peripherals
 * Which P1 header pins are actually used can be overridden via command line
 * parameter '--p1pins=...'.
static char *default_p1_pins = "7,11,12,13,15,16,18,22";
static char *default_p5_pins = "";
static uint8_t rev1_p1pin2gpio_map[] = {
	DMY,	// P1-1   3v3
	DMY,	// P1-2   5v
	0,	// P1-3   GPIO 0 (SDA)
	DMY,	// P1-4   5v
	1,	// P1-5   GPIO 1 (SCL)
	DMY,	// P1-6   Ground
	4,	// P1-7   GPIO 4 (GPCLK0)
	14,	// P1-8   GPIO 14 (TXD)
	DMY,	// P1-9   Ground
	15,	// P1-10  GPIO 15 (RXD)
	17,	// P1-11  GPIO 17
	18,	// P1-12  GPIO 18 (PCM_CLK)
	21,	// P1-13  GPIO 21
	DMY,	// P1-14  Ground
	22,	// P1-15  GPIO 22
	23,	// P1-16  GPIO 23
	DMY,	// P1-17  3v3
	24,	// P1-18  GPIO 24
	10,	// P1-19  GPIO 10 (MOSI)
	DMY,	// P1-20  Ground
	9,	// P1-21  GPIO 9 (MISO)
	25,	// P1-22  GPIO 25
	11,	// P1-23  GPIO 11 (SCLK)
	8,	// P1-24  GPIO 8 (CE0)
	DMY,	// P1-25  Ground
	7,	// P1-26  GPIO 7 (CE1)
static uint8_t rev1_p5pin2gpio_map[] = {
	DMY,	// (P5-1 on rev 2 boards)
	DMY,	// (P5-2 on rev 2 boards)
	DMY,	// (P5-3 on rev 2 boards)
	DMY,	// (P5-4 on rev 2 boards)
	DMY,	// (P5-5 on rev 2 boards)
	DMY,	// (P5-6 on rev 2 boards)
	DMY,	// (P5-7 on rev 2 boards)
	DMY,	// (P5-8 on rev 2 boards)
static uint8_t rev2_p1pin2gpio_map[] = {
	DMY,	// P1-1   3v3
	DMY,	// P1-2   5v
	2,	// P1-3   GPIO 2 (SDA)
	DMY,	// P1-4   5v
	3,	// P1-5   GPIO 3 (SCL)
	DMY,	// P1-6   Ground
	DMY,	// P1-9   Ground
	27,	// P1-13  GPIO 27
	DMY,	// P1-17  3v3
static uint8_t rev2_p5pin2gpio_map[] = {
	DMY,	// P5-1   5v0
	DMY,	// P5-2   3v3
	28,	// P5-3   GPIO 28 (I2C0_SDA)
	29,	// P5-4   GPIO 29 (I2C0_SCL)
	30,	// P5-5   GPIO 30
	31,	// P5-6   GPIO 31
	DMY,	// P5-7   Ground
	DMY,	// P5-8   Ground
// cycle_time_us is the pulse cycle time per servo, in microseconds.
// Typically it should be 20ms, or 20000us.
// step_time_us is the pulse width increment granularity, again in microseconds.
// Setting step_time_us too low will likely cause problems as the DMA controller
// will use too much memory bandwidth.  10us is a good value, though you
// might be ok setting it as low as 2us.
static int cycle_time_us;
static int step_time_us;
static uint8_t servo2gpio[MAX_SERVOS];
static uint8_t p1pin2servo[NUM_P1PINS+1];
static uint8_t p5pin2servo[NUM_P5PINS+1];
static int servostart[MAX_SERVOS];
static int servowidth[MAX_SERVOS];
static int num_servos;
static uint32_t gpiomode[MAX_SERVOS];
static int restore_gpio_modes;
page_map_t *page_map;
static uint8_t *virtbase;
static uint8_t *virtcached;
static volatile uint32_t *pwm_reg;
static volatile uint32_t *pcm_reg;
static volatile uint32_t *clk_reg;
static volatile uint32_t *dma_reg;
static volatile uint32_t *gpio_reg;
static int delay_hw = DELAY_VIA_PWM;
static struct timeval *servo_kill_time;
static int dma_chan;
static int idle_timeout;
static int invert = 0;
static int servo_min_ticks;
static int servo_max_ticks;
static int num_samples;
static int num_cbs;
static int num_pages;
static uint32_t *turnoff_mask;
static uint32_t *turnon_mask;
static dma_cb_t *cb_base;
static void set_servo(int servo, int width);
static void set_servo_idle(int servo);
static void gpio_set_mode(uint32_t gpio, uint32_t mode);
static char *gpio2pinname(uint8_t gpio);
static void
udelay(int us)
	struct timespec ts = { 0, us * 1000 };
	nanosleep(&ts, NULL);
static void
terminate(int dummy)
	int i;
	if (dma_reg && virtbase) {
		for (i = 0; i < MAX_SERVOS; i++) {
			if (servo2gpio[i] != DMY)
				set_servo(i, 0);
		udelay(cycle_time_us);
		dma_reg[DMA_CS] = DMA_RESET;
		udelay(10);
	if (restore_gpio_modes) {
				gpio_set_mode(servo2gpio[i], gpiomode[i]);
	unlink(DEVFILE);
	unlink(CFGFILE);
	exit(1);
static void
fatal(char *fmt, ...)
	va_list ap;
	va_start(ap, fmt);
	vfprintf(stderr, fmt, ap);
	va_end(ap);
	terminate(0);
static void
init_idle_timers(void)
	servo_kill_time = calloc(MAX_SERVOS, sizeof(struct timeval));
	if (!servo_kill_time)
		fatal("servod: calloc() failed\n");
static void
update_idle_time(int servo)
	if (idle_timeout == 0)
		return;
	gettimeofday(servo_kill_time + servo, NULL);
	servo_kill_time[servo].tv_sec += idle_timeout / 1000;
	servo_kill_time[servo].tv_usec += (idle_timeout % 1000) * 1000;
	while (servo_kill_time[servo].tv_usec >= 1000000) {
		servo_kill_time[servo].tv_usec -= 1000000;
		servo_kill_time[servo].tv_sec++;
static void
get_next_idle_timeout(struct timeval *tv)
	int i;
	struct timeval now;
	struct timeval min = { 60, 0 };
	long this_diff, min_diff;
	gettimeofday(&now, NULL);
		if (servo2gpio[i] == DMY || servo_kill_time[i].tv_sec == 0)
			continue;
		else if (servo_kill_time[i].tv_sec < now.tv_sec ||
			(servo_kill_time[i].tv_sec == now.tv_sec &&
			 servo_kill_time[i].tv_usec <= now.tv_usec)) {
			servo_kill_time[i].tv_sec = 0;
			set_servo_idle(i);
		} else {
			this_diff = (servo_kill_time[i].tv_sec - now.tv_sec) * 1000000
				+ servo_kill_time[i].tv_usec - now.tv_usec;
			min_diff = min.tv_sec * 1000000 + min.tv_usec;
			if (this_diff < min_diff) {
				min.tv_sec = this_diff / 1000000;
				min.tv_usec = this_diff % 1000000;
	*tv = min;
static uint32_t gpio_get_mode(uint32_t gpio)
	uint32_t fsel = gpio_reg[GPIO_FSEL0 + gpio/10];
	return (fsel >> ((gpio % 10) * 3)) & 7;
static void
	fsel &= ~(7 << ((gpio % 10) * 3));
	fsel |= mode << ((gpio % 10) * 3);
	gpio_reg[GPIO_FSEL0 + gpio/10] = fsel;
static void
gpio_set(int gpio, int level)
	if (level)
		gpio_reg[GPIO_SET0] = 1 << gpio;
	else
		gpio_reg[GPIO_CLR0] = 1 << gpio;
static uint32_t
mem_virt_to_phys(void *virt)
	uint32_t offset = (uint8_t *)virt - virtbase;
	return page_map[offset >> PAGE_SHIFT].physaddr + (offset % PAGE_SIZE);
static void *
map_peripheral(uint32_t base, uint32_t len)
	int fd = open("/dev/mem", O_RDWR);
	void * vaddr;
	if (fd < 0)
		fatal("servod: Failed to open /dev/mem: %m\n");
	vaddr = mmap(NULL, len, PROT_READ|PROT_WRITE, MAP_SHARED, fd, base);
	if (vaddr == MAP_FAILED)
		fatal("servod: Failed to map peripheral at 0x%08x: %m\n", base);
	close(fd);
	return vaddr;
static void
	/* Just remove the 'turn-on' action and allow the 'turn-off' action at
	 * the end of the current pulse to turn it off.  Special case if
	 * current width is 100%; in that case there will be no 'turn-off'
	 * action, so we will need to force the output off here.  We must not
	 * force the output in other cases, because that might lead to
	 * truncated pulses which would make a servo change position.
	turnon_mask[servo] = 0;
	if (servowidth[servo] == num_samples)
		gpio_set(servo2gpio[servo], invert ? 1 : 0);
/* Carefully add or remove bits from the turnoff_mask such that regardless
 * of where the DMA controller is in its cycle, and whether we are increasing
 * or decreasing the pulse width, the generated pulse will only ever be the
 * old width or the new width.  If we don't take such care then there could be
 * a cycle with some pulse width between the two requested ones.  That doesn't
 * really matter for servos, but when driving LEDs some odd intensity for one
 * cycle can be noticeable.  It may be that the servo output has been turned
 * off via the inactivity timer, which is handled by always setting the turnon
 * mask appropriately at the end of this function.
static void
	volatile uint32_t *dp;
	int i;
	uint32_t mask = 1 << servo2gpio[servo];
	if (width > servowidth[servo]) {
		dp = turnoff_mask + servostart[servo] + width;
		if (dp >= turnoff_mask + num_samples)
			dp -= num_samples;
		for (i = width; i > servowidth[servo]; i--) {
			dp--;
			if (dp < turnoff_mask)
				dp = turnoff_mask + num_samples - 1;
			//printf("%5d, clearing at %p\n", dp - ctl->turnoff, dp);
			*dp &= ~mask;
	} else if (width < servowidth[servo]) {
			dp -= num_samples;
		for (i = width; i < servowidth[servo]; i++) {
			//printf("%5d, setting at %p\n", dp - ctl->turnoff, dp);
			*dp++ |= mask;
				dp = turnoff_mask;
	servowidth[servo] = width;
	if (width == 0) {
	} else {
		turnon_mask[servo] = mask;
	update_idle_time(servo);
static void
make_pagemap(void)
	int i, fd, memfd, pid;
	char pagemap_fn[64];
	page_map = malloc(num_pages * sizeof(*page_map));
	if (page_map == 0)
		fatal("servod: Failed to malloc page_map: %m\n");
	memfd = open("/dev/mem", O_RDWR);
	if (memfd < 0)
	pid = getpid();
	sprintf(pagemap_fn, "/proc/%d/pagemap", pid);
	fd = open(pagemap_fn, O_RDONLY);
	if (fd < 0)
		fatal("servod: Failed to open %s: %m\n", pagemap_fn);
	if (lseek(fd, (uint32_t)(size_t)virtcached >> 9, SEEK_SET) !=
						(uint32_t)(size_t)virtcached >> 9) {
		fatal("servod: Failed to seek on %s: %m\n", pagemap_fn);
	for (i = 0; i < num_pages; i++) {
		uint64_t pfn;
		if (read(fd, &pfn, sizeof(pfn)) != sizeof(pfn))
			fatal("servod: Failed to read %s: %m\n", pagemap_fn);
		if (((pfn >> 55) & 0x1bf) != 0x10c)
			fatal("servod: Page %d not present (pfn 0x%016llx)\n", i, pfn);
		page_map[i].physaddr = (uint32_t)pfn << PAGE_SHIFT | BUS_OFFSET_1;
		if (mmap(virtbase + i * PAGE_SIZE, PAGE_SIZE, PROT_READ|PROT_WRITE,
			MAP_SHARED|MAP_FIXED|MAP_LOCKED|MAP_NORESERVE,
			memfd, (uint32_t)pfn << PAGE_SHIFT | BUS_OFFSET_2) !=
				virtbase + i * PAGE_SIZE) {
			fatal("Failed to create uncached map of page %d at %p\n",
				i,  virtbase + i * PAGE_SIZE);
	close(fd);
	close(memfd);
	memset(virtbase, 0, num_pages * PAGE_SIZE);
static void
setup_sighandlers(void)
	int i;
	// Catch all signals possible - it is vital we kill the DMA engine
	// on process exit!
	for (i = 0; i < 64; i++) {
		struct sigaction sa;
		memset(&sa, 0, sizeof(sa));
		sa.sa_handler = terminate;
		sigaction(i, &sa, NULL);
static void
init_ctrl_data(void)
	dma_cb_t *cbp = cb_base;
	uint32_t phys_fifo_addr, cbinfo;
	uint32_t phys_gpclr0;
	uint32_t phys_gpset0;
	int servo, i, numservos = 0, curstart = 0;
	uint32_t maskall = 0;
	if (invert) {
		phys_gpclr0 = 0x7e200000 + 0x1c;
		phys_gpset0 = 0x7e200000 + 0x28;
	} else {
		phys_gpclr0 = 0x7e200000 + 0x28;
		phys_gpset0 = 0x7e200000 + 0x1c;
	if (delay_hw == DELAY_VIA_PWM) {
		phys_fifo_addr = (PWM_BASE | 0x7e000000) + 0x18;
		cbinfo = DMA_NO_WIDE_BURSTS | DMA_WAIT_RESP | DMA_D_DREQ | DMA_PER_MAP(5);
	} else {
		phys_fifo_addr = (PCM_BASE | 0x7e000000) + 0x04;
		cbinfo = DMA_NO_WIDE_BURSTS | DMA_WAIT_RESP | DMA_D_DREQ | DMA_PER_MAP(2);
	memset(turnon_mask, 0, MAX_SERVOS * sizeof(*turnon_mask));
	for (servo = 0 ; servo < MAX_SERVOS; servo++) {
		servowidth[servo] = 0;
		if (servo2gpio[servo] != DMY) {
			numservos++;
			maskall |= 1 << servo2gpio[servo];
	for (i = 0; i < num_samples; i++)
		turnoff_mask[i] = maskall;
	for (servo = 0; servo < MAX_SERVOS; servo++) {
			servostart[servo] = curstart;
			curstart += num_samples / num_servos;
	servo = 0;
	while (servo < MAX_SERVOS && servo2gpio[servo] == DMY)
		servo++;
	for (i = 0; i < num_samples; i++) {
		cbp->info = DMA_NO_WIDE_BURSTS | DMA_WAIT_RESP;
		cbp->src = mem_virt_to_phys(turnoff_mask + i);
		cbp->dst = phys_gpclr0;
		cbp->length = 4;
		cbp->stride = 0;
		cbp->next = mem_virt_to_phys(cbp + 1);
		cbp++;
		if (i == servostart[servo]) {
			cbp->src = mem_virt_to_phys(turnon_mask + servo);
			cbp->dst = phys_gpset0;
			cbp->length = 4;
			cbp->stride = 0;
			cbp++;
			servo++;
				servo++;
		// Delay
		cbp->info = cbinfo;
		cbp->src = mem_virt_to_phys(turnoff_mask);	// Any data will do
		cbp->dst = phys_fifo_addr;
		cbp->length = 4;
		cbp->stride = 0;
		cbp++;
	cbp--;
	cbp->next = mem_virt_to_phys(cb_base);
static void
init_hardware(void)
		// Initialise PWM
		pwm_reg[PWM_CTL] = 0;
		udelay(10);
		clk_reg[PWMCLK_CNTL] = 0x5A000006;		// Source=PLLD (500MHz)
		udelay(100);
		clk_reg[PWMCLK_DIV] = 0x5A000000 | (500<<12);	// set pwm div to 500, giving 1MHz
		udelay(100);
		clk_reg[PWMCLK_CNTL] = 0x5A000016;		// Source=PLLD and enable
		udelay(100);
		pwm_reg[PWM_RNG1] = step_time_us;
		udelay(10);
		pwm_reg[PWM_DMAC] = PWMDMAC_ENAB | PWMDMAC_THRSHLD;
		udelay(10);
		pwm_reg[PWM_CTL] = PWMCTL_CLRF;
		udelay(10);
		pwm_reg[PWM_CTL] = PWMCTL_USEF1 | PWMCTL_PWEN1;
		udelay(10);
	} else {
		// Initialise PCM
		pcm_reg[PCM_CS_A] = 1;				// Disable Rx+Tx, Enable PCM block
		udelay(100);
		clk_reg[PCMCLK_CNTL] = 0x5A000006;		// Source=PLLD (500MHz)
		udelay(100);
		clk_reg[PCMCLK_DIV] = 0x5A000000 | (500<<12);	// Set pcm div to 500, giving 1MHz
		udelay(100);
		clk_reg[PCMCLK_CNTL] = 0x5A000016;		// Source=PLLD and enable
		udelay(100);
		pcm_reg[PCM_TXC_A] = 0<<31 | 1<<30 | 0<<20 | 0<<16; // 1 channel, 8 bits
		udelay(100);
		pcm_reg[PCM_MODE_A] = (step_time_us - 1) << 10;
		udelay(100);
		pcm_reg[PCM_CS_A] |= 1<<4 | 1<<3;		// Clear FIFOs
		udelay(100);
		pcm_reg[PCM_DREQ_A] = 64<<24 | 64<<8;		// DMA Req when one slot is free?
		udelay(100);
		pcm_reg[PCM_CS_A] |= 1<<9;			// Enable DMA
		udelay(100);
	// Initialise the DMA
	udelay(10);
	dma_reg[DMA_CS] = DMA_INT | DMA_END;
	dma_reg[DMA_CONBLK_AD] = mem_virt_to_phys(cb_base);
	dma_reg[DMA_DEBUG] = 7; // clear debug error flags
	dma_reg[DMA_CS] = 0x10880001;	// go, mid priority, wait for outstanding writes
	if (delay_hw == DELAY_VIA_PCM) {
		pcm_reg[PCM_CS_A] |= 1<<2;			// Enable Tx
static void
do_debug(void)
	int i;
	uint32_t mask = 0;
	uint32_t last = 0xffffffff;
	printf("---------------------------\n");
	printf("Servo  Start  Width  TurnOn\n");
		if (servo2gpio[i] != DMY) {
			printf("%3d: %6d %6d %6d\n", i, servostart[i],
					servowidth[i], !!turnon_mask[i]);
			mask |= 1 << servo2gpio[i];
	printf("\nData:\n");
		uint32_t curr = turnoff_mask[i] & mask;
		if (curr != last)
			printf("@%5d: %08x\n", i, curr);
		last = curr;
static int
parse_width(int servo, char *width_arg)
	char *p;
	char *digits = width_arg;
	double width;
	if (*width_arg == '-' || *width_arg == '+') {
		digits++;
	if (*digits < '0' || *digits > '9') {
		return -1;
	width = strtod(digits, &p);
	if (*p == '\0') {
		/* Specified in steps */
	} else if (!strcmp(p, "us")) {
		width /= step_time_us;
	} else if (!strcmp(p, "%")) {
		width = width * (servo_max_ticks - servo_min_ticks) / 100.0 + servo_min_ticks;
	} else {
		return -1;
	width = floor(width);
	if (*width_arg == '+') {
		width = servowidth[servo] + width;
		if (width > servo_max_ticks)
			width = servo_max_ticks;
	} else if (*width_arg == '-') {
		width = servowidth[servo] - width;
		if (width < servo_min_ticks)
			width = servo_min_ticks;
	if (width == 0) {
		return (int)width;
	} else if (width < servo_min_ticks || width > servo_max_ticks) {
		return -1;
	} else {
		return (int)width;
static void
go_go_go(void)
	int fd;
	struct timeval tv;
	static char line[128];
	int nchars = 0;
	if ((fd = open(DEVFILE, O_RDWR|O_NONBLOCK)) == -1)
		fatal("servod: Failed to open %s: %m\n", DEVFILE);
	for (;;) {
		int n, width, servo;
		fd_set ifds;
		char width_arg[64];
		FD_ZERO(&ifds);
		FD_SET(fd, &ifds);
		get_next_idle_timeout(&tv);
		if ((n = select(fd+1, &ifds, NULL, NULL, &tv)) != 1)
			continue;
		while (read(fd, line+nchars, 1) == 1) {
			if (line[nchars] == '\n') {
				line[++nchars] = '\0';
				nchars = 0;
				if (line[0] == 'p' || line[0] == 'P') {
					int hdr, pin, width;
					n = sscanf(line+1, "%d-%d=%s", &hdr, &pin, width_arg);
					if (n != 3) {
						fprintf(stderr, "Bad input: %s", line);
					} else if (hdr != 1 && hdr != 5) {
						fprintf(stderr, "Invalid header P%d\n", hdr);
					} else if (pin < 1 ||
							(hdr == 1 && pin > NUM_P1PINS) ||
							(hdr == 5 && pin > NUM_P5PINS)) {
						fprintf(stderr, "Invalid pin number P%d-%d\n", hdr, pin);
					} else if ((hdr == 1 && p1pin2servo[pin] == DMY) ||
						   (hdr == 5 && p5pin2servo[pin] == DMY)) {
							fprintf(stderr, "P%d-%d is not mapped to a servo\n", hdr, pin);
					} else {
						if (hdr == 1) {
							servo = p1pin2servo[pin];
						} else {
							servo = p5pin2servo[pin];
						if ((width = parse_width(servo, width_arg)) < 0) {
							fprintf(stderr, "Invalid width specified\n");
						} else {
							set_servo(servo, width);
				} else {
					n = sscanf(line, "%d=%s", &servo, width_arg);
					if (!strcmp(line, "debug\n")) {
						do_debug();
					} else if (n != 2) {
					} else if (servo < 0 || servo >= MAX_SERVOS) {
						fprintf(stderr, "Invalid servo number %d\n", servo);
					} else if (servo2gpio[servo] == DMY) {
						fprintf(stderr, "Servo %d is not mapped to a GPIO pin\n", servo);
					} else if ((width = parse_width(servo, width_arg)) < 0) {
					} else {
			} else {
				if (++nchars >= 126) {
					fprintf(stderr, "Input too long\n");
					nchars = 0;
/* Determining the board revision is a lot more complicated than it should be
 * (see comments in wiringPi for details).  We will just look at the last two
 * digits of the Revision string and treat '00' and '01' as errors, '02' and
 * '03' as rev 1, and any other hex value as rev 2.
static int
board_rev(void)
	char buf[128];
	char *ptr, *end, *res;
	static int rev = 0;
	FILE *fp;
	if (rev)
		return rev;
	fp = fopen("/proc/cpuinfo", "r");
	if (!fp)
		fatal("Unable to open /proc/cpuinfo: %m\n");
	while ((res = fgets(buf, 128, fp))) {
		if (!strncmp(buf, "Revision", 8))
			break;
	fclose(fp);
	if (!res)
		fatal("servod: No 'Revision' record in /proc/cpuinfo\n");
	ptr = buf + strlen(buf) - 3;
	rev = strtol(ptr, &end, 16);
	if (end != ptr + 2)
		fatal("servod: Failed to parse Revision string\n");
	if (rev < 1)
		fatal("servod: Invalid board Revision\n");
	else if (rev < 4)
		rev = 1;
	else
		rev = 2;
	return rev;
static void
parse_pin_lists(int p1first, char *p1pins, char*p5pins)
	char *name, *pins;
	int i, mapcnt;
	uint8_t *map, *pNpin2servo;
	int lst, servo = 0;
	FILE *fp;
	memset(servo2gpio, DMY, sizeof(servo2gpio));
	memset(p1pin2servo, DMY, sizeof(p1pin2servo));
	memset(p5pin2servo, DMY, sizeof(p5pin2servo));
	for (lst = 0; lst < 2; lst++) {
		if (lst == 0 && p1first) {
			name = "P1";
			pins = p1pins;
			if (board_rev() == 1) {
				map = rev1_p1pin2gpio_map;
				mapcnt = sizeof(rev1_p1pin2gpio_map);
			} else {
				map = rev2_p1pin2gpio_map;
				mapcnt = sizeof(rev2_p1pin2gpio_map);
			pNpin2servo = p1pin2servo;
		} else {
			name = "P5";
			pins = p5pins;
				map = rev1_p5pin2gpio_map;
				mapcnt = sizeof(rev1_p5pin2gpio_map);
			} else {
				map = rev2_p5pin2gpio_map;
				mapcnt = sizeof(rev2_p5pin2gpio_map);
			pNpin2servo = p5pin2servo;
		while (*pins) {
			char *end;
			long pin = strtol(pins, &end, 0);
			if (*end && (end == pins || *end != ','))
				fatal("Invalid character '%c' in %s pin list\n", *end, name);
			if (pin < 0 || pin > mapcnt)
				fatal("Invalid pin number %d in %s pin list\n", pin, name);
			if (servo == MAX_SERVOS)
				fatal("Too many servos specified\n");
			if (pin == 0) {
				servo++;
			} else {
				if (map[pin-1] == DMY)
					fatal("Pin %d on header %s cannot be used for a servo output\n", pin, name);
				pNpin2servo[pin] = servo;
				servo2gpio[servo++] = map[pin-1];
				num_servos++;
			pins = end;
			if (*pins == ',')
				pins++;
	/* Write a cfg file so can tell which pins are used for servos */
	fp = fopen(CFGFILE, "w");
	if (fp) {
		if (p1first)
			fprintf(fp, "p1pins=%s\np5pins=%s\n", p1pins, p5pins);
		else
			fprintf(fp, "p5pins=%s\np1pins=%s\n", p5pins, p1pins);
		fprintf(fp, "\nServo mapping:\n");
			if (servo2gpio[i] == DMY)
				continue;
			fprintf(fp, "    %2d on %-5s          GPIO-%d\n", i, gpio2pinname(servo2gpio[i]), servo2gpio[i]);
		fclose(fp);
static uint8_t
gpiosearch(uint8_t gpio, uint8_t *map, int len)
	while (--len) {
		if (map[len] == gpio)
			return len+1;
	return 0;
static char *
	static char res[16];
	uint8_t pin;
		if ((pin = gpiosearch(gpio, rev1_p1pin2gpio_map, sizeof(rev1_p1pin2gpio_map))))
			sprintf(res, "P1-%d", pin);
		else if ((pin = gpiosearch(gpio, rev1_p5pin2gpio_map, sizeof(rev1_p5pin2gpio_map))))
			sprintf(res, "P5-%d", pin);
		else
			fatal("Cannot map GPIO %d to a header pin\n", gpio);
	} else {
		if ((pin = gpiosearch(gpio, rev2_p1pin2gpio_map, sizeof(rev2_p1pin2gpio_map))))
		else if ((pin = gpiosearch(gpio, rev2_p5pin2gpio_map, sizeof(rev2_p5pin2gpio_map))))
		else
	return res;
static int
parse_min_max_arg(char *arg, char *name)
	char *p;
	double val = strtod(arg, &p);
	if (*arg < '0' || *arg > '9' || val < 0) {
		fatal("Invalid %s value specified\n", name);
	} else if (*p == '\0') {
		if (val != floor(val)) {
		return (int)val;
		if ((int)val % step_time_us) {
			fatal("%s value is not a multiple of step-time\n", name);
		return val / step_time_us;
		if (val < 0 || val > 100.0) {
			fatal("%s value must be between 0% and 100% inclusive\n", name);
		return (int)(val * (double)cycle_time_us / 100.0 / step_time_us);
	} else {
	return -1;	/* Never reached */
int
main(int argc, char **argv)
	int i;
	char *p1pins = default_p1_pins;
	char *p5pins = default_p5_pins;
	int p1first = 1, hadp1 = 0, hadp5 = 0;
	char *servo_min_arg = NULL;
	char *servo_max_arg = NULL;
	char *idle_timeout_arg = NULL;
	char *cycle_time_arg = NULL;
	char *step_time_arg = NULL;
	char *dma_chan_arg = NULL;
	char *p;
	int daemonize = 1;
	setvbuf(stdout, NULL, _IOLBF, 0);
	while (1) {
		int c;
		int option_index;
		static struct option long_options[] = {
			{ "pcm",          no_argument,       0, 'p' },
			{ "idle-timeout", required_argument, 0, 't' },
			{ "help",         no_argument,       0, 'h' },
			{ "p1pins",       required_argument, 0, '1' },
			{ "p5pins",       required_argument, 0, '5' },
			{ "min",          required_argument, 0, 'm' },
			{ "max",          required_argument, 0, 'x' },
			{ "invert",       no_argument,       0, 'i' },
			{ "cycle-time",   required_argument, 0, 'c' },
			{ "step-size",    required_argument, 0, 's' },
			{ "debug",        no_argument,       0, 'f' },
			{ "dma-chan",     required_argument, 0, 'd' },
			{ 0,              0,                 0, 0   }
		c = getopt_long(argc, argv, "mxhnt:15icsfd", long_options, &option_index);
		if (c == -1) {
			break;
		} else if (c =='d') {
			dma_chan_arg = optarg;
		} else if (c == 'f') {
			daemonize = 0;
		} else if (c == 'p') {
			delay_hw = DELAY_VIA_PCM;
		} else if (c == 't') {
			idle_timeout_arg = optarg;
		} else if (c == 'c') {
			cycle_time_arg = optarg;
		} else if (c == 's') {
			step_time_arg = optarg;
		} else if (c == 'm') {
			servo_min_arg = optarg;
		} else if (c == 'x') {
			servo_max_arg = optarg;
		} else if (c == 'i') {
			invert = 1;
		} else if (c == 'h') {
			printf("\nUsage: %s <options>\n\n"
				"Options:\n"
                                "  --pcm               tells servod to use PCM rather than PWM hardware\n"
                                "                      to implement delays\n"
				"  --idle-timeout=Nms  tells servod to stop sending servo pulses for a\n"
				"                      given output N milliseconds after the last update\n"
				"  --cycle-time=Nus    Control pulse cycle time in microseconds, default\n"
				"                      %dus\n"
				"  --step-size=Nus     Pulse width increment step size in microseconds,\n"
				"                      default %dus\n"
				"  --min={N|Nus|N%%}    specifies the minimum allowed pulse width, default\n"
				"                      %d steps or %dus\n"
				"  --max={N|Nus|N%%}    specifies the maximum allowed pulse width, default\n"
				"  --invert            Inverts outputs\n"
				"  --dma-chan=N        tells servod which dma channel to use, default %d\n"
				"  --p1pins=<list>     tells servod which pins on the P1 header to use\n"
				"  --p5pins=<list>     tells servod which pins on the P5 header to use\n"
				"\nwhere <list> defaults to \"%s\" for p1pins and\n"
				"\"%s\" for p5pins.  p5pins is only valid on rev 2 boards.\n\n"
				"min and max values can be specified in units of steps, in microseconds,\n"
				"or as a percentage of the cycle time.  So, for example, if cycle time is\n"
				"20000us and step size is 10us then the following are equivalent:\n\n"
				"          --min=50   --min=500us    --min=2.5%%\n\n"
				"For the default configuration, example commands to set the first servo\n"
				"to the mid position would be any of:\n\n"
				"  echo 0=150 > /dev/servoblaster        # Specify as a number of steps\n"
				"  echo 0=50%% > /dev/servoblaster        # Specify as a percentage\n"
				"  echo 0=1500us > /dev/servoblaster     # Specify as microseconds\n"
				"  echo P1-7=150 > /dev/servoblaster     # Using P1 pin number rather\n"
				"  echo P1-7=50%% > /dev/servoblaster     # ... than servo number\n"
				"  echo P1-7=1500us > /dev/servoblaster\n\n"
				"Servo adjustments may also be specified relative to the current\n"
				"position by adding a '+' or '-' prefix to the width as follows:\n\n"
				"  echo 0=+10 > /dev/servoblaster\n"
				"  echo 0=-20 > /dev/servoblaster\n\n",
				argv[0],
				DEFAULT_CYCLE_TIME_US,
				DEFAULT_STEP_TIME_US,
				DEFAULT_SERVO_MIN_US/DEFAULT_STEP_TIME_US, DEFAULT_SERVO_MIN_US,
				DEFAULT_SERVO_MAX_US/DEFAULT_STEP_TIME_US, DEFAULT_SERVO_MAX_US,
				DMA_CHAN_DEFAULT, default_p1_pins, default_p5_pins);
			exit(0);
		} else if (c == '1') {
			p1pins = optarg;
			hadp1 = 1;
			if (!hadp5)
				p1first = 1;
		} else if (c == '5') {
			p5pins = optarg;
			hadp5 = 1;
			if (!hadp1)
				p1first = 0;
		} else {
			fatal("Invalid parameter\n");
	if (board_rev() == 1 && p5pins[0])
		fatal("Board rev 1 does not have a P5 header\n");
	parse_pin_lists(p1first, p1pins, p5pins);
	if (dma_chan_arg) {
		dma_chan = strtol(dma_chan_arg, &p, 10);
		if (*dma_chan_arg < '0' || *dma_chan_arg > '9' ||
				*p || dma_chan < DMA_CHAN_MIN || dma_chan > DMA_CHAN_MAX)
			fatal("Invalid dma-chan specified\n");
	} else {
		dma_chan = DMA_CHAN_DEFAULT;
	if (idle_timeout_arg) {
		idle_timeout = strtol(idle_timeout_arg, &p, 10);
		if (*idle_timeout_arg < '0' || *idle_timeout_arg > '9' ||
				(*p && strcmp(p, "ms")) ||
				idle_timeout < 10 || idle_timeout > 3600000)
			fatal("Invalid idle-timeout specified\n");
	} else {
		idle_timeout = 0;
	if (cycle_time_arg) {
		cycle_time_us = strtol(cycle_time_arg, &p, 10);
		if (*cycle_time_arg < '0' || *cycle_time_arg > '9' ||
				(*p && strcmp(p, "us")) ||
				cycle_time_us < 1000 || cycle_time_us > 1000000)
			fatal("Invalid cycle-time specified\n");
	} else {
		cycle_time_us = DEFAULT_CYCLE_TIME_US;
	if (step_time_arg) {
		step_time_us = strtol(step_time_arg, &p, 10);
		if (*step_time_arg < '0' || *step_time_arg > '9' ||
				step_time_us < 2 || step_time_us > 1000) {
			fatal("Invalid step-size specified\n");
	} else {
		step_time_us = DEFAULT_STEP_TIME_US;
	if (cycle_time_us % step_time_us) {
		fatal("cycle-time is not a multiple of step-size\n");
	if (cycle_time_us / step_time_us < 100) {
		fatal("cycle-time must be at least 100 * step-size\n");
	if (servo_min_arg) {
		servo_min_ticks = parse_min_max_arg(servo_min_arg, "min");
	} else {
		servo_min_ticks = DEFAULT_SERVO_MIN_US / step_time_us;
	if (servo_max_arg) {
		servo_max_ticks = parse_min_max_arg(servo_max_arg, "max");
	} else {
		servo_max_ticks = DEFAULT_SERVO_MAX_US / step_time_us;
	num_samples = cycle_time_us / step_time_us;
	num_cbs =     num_samples * 2 + MAX_SERVOS;
	num_pages =   (num_cbs * sizeof(dma_cb_t) + num_samples * 4 +
				MAX_SERVOS * 4 + PAGE_SIZE - 1) >> PAGE_SHIFT;
	if (num_pages > MAX_MEMORY_USAGE / PAGE_SIZE) {
		fatal("Using too much memory; reduce cycle-time or increase step-size\n");
	if (servo_max_ticks > num_samples) {
		fatal("max value is larger than cycle time\n");
	if (servo_min_ticks >= servo_max_ticks) {
		fatal("min value is >= max value\n");
	printf("\nBoard revision:            %7d\n", board_rev());
	printf("Using hardware:                %s\n", delay_hw == DELAY_VIA_PWM ? "PWM" : "PCM");
	printf("Using DMA channel:         %7d\n", dma_chan);
	if (idle_timeout)
		printf("Idle timeout:              %7dms\n", idle_timeout);
	else
		printf("Idle timeout:             Disabled\n");
	printf("Number of servos:          %7d\n", num_servos);
	printf("Servo cycle time:          %7dus\n", cycle_time_us);
	printf("Pulse increment step size: %7dus\n", step_time_us);
	printf("Minimum width value:       %7d (%dus)\n", servo_min_ticks,
						servo_min_ticks * step_time_us);
	printf("Maximum width value:       %7d (%dus)\n", servo_max_ticks,
						servo_max_ticks * step_time_us);
	printf("Output levels:            %s\n", invert ? "Inverted" : "  Normal");
	printf("\nUsing P1 pins:               %s\n", p1pins);
	if (board_rev() > 1)
		printf("Using P5 pins:               %s\n", p5pins);
	printf("\nServo mapping:\n");
			continue;
		printf("    %2d on %-5s          GPIO-%d\n", i, gpio2pinname(servo2gpio[i]), servo2gpio[i]);
	printf("\n");
	init_idle_timers();
	setup_sighandlers();
	dma_reg = map_peripheral(DMA_BASE, DMA_LEN);
	dma_reg += dma_chan * DMA_CHAN_SIZE / sizeof(uint32_t);
	pwm_reg = map_peripheral(PWM_BASE, PWM_LEN);
	pcm_reg = map_peripheral(PCM_BASE, PCM_LEN);
	clk_reg = map_peripheral(CLK_BASE, CLK_LEN);
	gpio_reg = map_peripheral(GPIO_BASE, GPIO_LEN);
	 * Map the pages to our virtual address space; this reserves them and
	 * locks them in memory.  However, these are L1 & L2 non-coherent
	 * cached pages and we want coherent access to them so the DMA
	 * controller sees our changes immediately.  To get that, we create a
	 * second mapping of the same size and immediately free it.  This gives
	 * us an address in our virtual address space where we can map in a
	 * coherent view of the physical pages that were allocated by the first
	 * mmap(). This coherent mapping happens in make_pagemap().  All
	 * accesses to our memory that is shared with the DMA controller are
	 * via this second coherent mapping.  The memset() below forces the
	 * pages to be allocated.
	virtcached = mmap(NULL, num_pages * PAGE_SIZE, PROT_READ|PROT_WRITE,
			MAP_SHARED|MAP_ANONYMOUS|MAP_NORESERVE|MAP_LOCKED,
			-1, 0);
	if (virtcached == MAP_FAILED)
		fatal("servod: Failed to mmap for cached pages: %m\n");
	if ((unsigned long)virtcached & (PAGE_SIZE-1))
		fatal("servod: Virtual address is not page aligned\n");
	memset(virtcached, 0, num_pages * PAGE_SIZE);
	virtbase = mmap(NULL, num_pages * PAGE_SIZE, PROT_READ|PROT_WRITE,
			-1, 0);
	if (virtbase == MAP_FAILED)
		fatal("servod: Failed to mmap uncached pages: %m\n");
	if ((unsigned long)virtbase & (PAGE_SIZE-1))
	munmap(virtbase, num_pages * PAGE_SIZE);
	make_pagemap();
	 * Now the memory is all mapped, we can set up the pointers to the
	 * bit masks used to turn outputs on and off, and to the DMA control
	 * blocks.  The control blocks must be 32 byte aligned (so round up
	 * to multiple of 8, as we're then multiplying by 4).
	turnoff_mask = (uint32_t *)virtbase;
	turnon_mask = (uint32_t *)(virtbase + num_samples * sizeof(uint32_t));
	cb_base = (dma_cb_t *)(virtbase +
		ROUNDUP(num_samples + MAX_SERVOS, 8) * sizeof(uint32_t));
			continue;
		gpiomode[i] = gpio_get_mode(servo2gpio[i]);
		gpio_set(servo2gpio[i], invert ? 1 : 0);
		gpio_set_mode(servo2gpio[i], GPIO_MODE_OUT);
	restore_gpio_modes = 1;
	init_ctrl_data();
	init_hardware();
	unlink(DEVFILE);
	if (mkfifo(DEVFILE, 0666) < 0)
		fatal("servod: Failed to create %s: %m\n", DEVFILE);
	if (chmod(DEVFILE, 0666) < 0)
		fatal("servod: Failed to set permissions on %s: %m\n", DEVFILE);
	if (daemonize && daemon(0,1) < 0)
		fatal("servod: Failed to daemonize process: %m\n");
	go_go_go();
	return 0;
