WazzaBMSCE
Webcam to capture videos on Raspberry Pi
Sat Feb 07, 2015 4:31 pm
Hi everyone,
I have installed OpenCV on my raspberry pi and am trying to capture videos using my Logitech C170 USB webcam.
I have installed:
1) guvcview
2) fswebcam
3) motion
The command "fswebcam -r 640x480 -S 10 -d /dev/video0 webcam2.png" is working correctly and is capturing images from my webcam.
However, I am not able to use guvcview because the image appears blank. Here is a screenshot of how it looks to me when i open guvcview-
Screenshot of guvcview in my raspberry pi
The guvcview screen looks like this-
The guvciew blank screen
What packages do I need to install to make this work ?
How else can I capture videos with ease in Raspberry Pi using my logitech camera ? If you would like to know other details then please let me know. I shall post it here.
Thank you !
mirak123
Re: Webcam to capture videos on Raspberry Pi
Sat Feb 07, 2015 7:06 pm
Which version of kernel do you have?
$ uname -a
WazzaBMSCE
Sun Feb 08, 2015 3:44 am
mirak123 wrote:Which version of kernel do you have?
$ uname -a
This is the output of "uname -a"-
Linux raspberrypi 3.18.5+ #748 PREEMPT Wed Feb 4 21:24:41 GMT 2015 armv6l GNU/Linux
mirak123
Sun Feb 08, 2015 8:50 am
You can install qv4l2 instead of guvcview, because it is not working with kernel 3.18 (3.16+) due to a bug in guvcview. There shouldn't be a problem with motion if you use YUYV mode (or other mode than MJPG). Another program is mjpg_streamer that works either in MJPG mode or YUYV mode, however you need to apply a patch for MJPG mode with kernel 3.18 as mentioned http://www.raspberrypi.org/forums/viewt ... 28&t=97983.
ganesh1901
Mon Feb 09, 2015 6:40 pm
Hai ...these options are very cool and can i save it in array until we interrupt the command.If done how to do
