tpbholm
Pi2 Error message on startup
Thu Feb 05, 2015 4:44 pm
Help - When I boot my Pi2 into the GUI I get the following error message:
GDBUS.Error.org.Freedesktop.PolicyKit1.Error.Failed:Cannot determine user of subject
What does this mean and what do I need to do?
texy
Re: Pi2 Error message on startup
Thu Feb 05, 2015 6:06 pm
Please ignore the message, this causes no harm and will be addressed in a later software release. Just hit the OK button and continue.
Texy
Pheonix
Thu Feb 12, 2015 3:16 pm
I'm new to the world of linux, but I had the same error and found that this piece of code worked in getting rid of that message.
sudo /etc/init.d/dbus restart
I'm running the latest version of Raspbian from the NOOBS installation, but I found that if I ran a safe boot into noobs to make changes/install a different os, the error message returned and I had to run the command again.
Hope this helps :)
texy
Thu Feb 12, 2015 3:59 pm
Nah - if I remember correctly, it only happens once per boot. That restart command will not alter the image, so reloading, burn to SD card, etc was a red herring.
Hitting OK is a lot easier...
Texy
Pheonix
Fri Feb 13, 2015 12:41 am
texy wrote:Nah - if I remember correctly, it only happens once per boot. That restart command will not alter the image, so reloading, burn to SD card, etc was a red herring.
Texy
Oh ok. Thanks :D
hobbsy
Thu Feb 26, 2015 2:45 pm
This solution by Buda worked for me:
http://www.raspberrypi.org/forums/viewt ... 29#p700029
