simonm1970
No protocol specified
Sat Jun 30, 2012 5:52 pm
Hi
I hope someone can help me!
Ive had the Pi a couple of days, have been signing in and using startx have been loadng linux with no problems at all. now however after startx the screen goes black for about 5 minutes and then get the following message:
No Protocol specified
this repeats numerous times the get the following message
giving up
xinit: resource temprarily unavailible
(errno11): unable to connect to xserver
waiting for x server to shut down
xinit: server error
nothing then happens!
help!!!! :cry: :cry:
mahjongg
Re: No protocol specified
Sat Jun 30, 2012 5:56 pm
I assume you have not cleanly shut down the PI, and given OS and SD-card the opportunity to flush open files to the card, which might have damaged an essential file.
Simply re-flash the card.
rocketero
Sat Jul 14, 2012 6:32 pm
I got this same problem. After removing Samba package that I had installed, then I rebooted normally with 'sudo reboot', and then tried to StartX and only thing I see is:
it repeats over and over for 5 minutes and then it gives up and back to $ prompt
I deleted the /home/pi .Xauthority, then launched StartX, it created a new .Xauthority but not a Go, it came out saying PRIMARY DEVICE IS NOT PCI (was using /usr/share/X11/xorg.conf.d file)
So I guess at this point it means RE-FLASH, and RE-SIZE PARTITIONS (using Gparted in another PC)
wolfmech
Fri Sep 18, 2020 4:11 am
Hello, I have the same problem of my raspberry. Let ask if Raspian have some option for desinstall the last modification of the the file system? I don't know why the Xorg was damage.
