Raspberry Pi not showing on Laptop
Posted: Sun Feb 01, 2015 9:38 am
by emirahmed1
Recently I got a raspberry pi and want to use it via a laptop. So, I used a hdmi, plugged it into pi and laptop, however nothing appeared. Can anyone help me on how I can fix this or I need a different cable?
Re: Raspberry Pi not showing on Laptop
Posted: Sun Feb 01, 2015 9:46 am
by ame
emirahmed1 wrote:Recently I got a raspberry pi and want to use it via a laptop. So, I used a hdmi, plugged it into pi and laptop, however nothing appeared. Can anyone help me on how I can fix this or I need a different cable?
You plugged the Pi HDMI socket into the laptop HDMI socket? Usually laptops have HDMI outputs. You have connected an output to an output. It can not work unless your laptop HDMI socket can be configured as an input.
Posted: Sun Feb 01, 2015 10:29 am
by fruitoftheloom
:roll: :roll: :roll:
You need to run the Pi Headless see http://www.raspberrypi.org/documentatio ... /README.md
Posted: Sun Feb 01, 2015 10:39 am
by emirahmed1
Guys, I understand what u are saying but what monitor should I use to connect my raspberry pi to my laptop?
Posted: Sun Feb 01, 2015 10:47 am
by fruitoftheloom
emirahmed1 wrote:Guys, I understand what u are saying but what monitor should I use to connect my raspberry pi to my laptop?
Read the link I posted which applies to the Raspbian Operating System
Posted: Sun Feb 01, 2015 10:57 am
by emirahmed1
Yea, the link really helped but just one question. If I go into ssh, scroll down and click the windows link, it will transfer me to a page about putty. It will say to type an ip adress. What IP address should I use?
Posted: Sun Feb 01, 2015 11:16 am
by ghans
1) Learn how to enable internet connection sharing (ICS)
on Windows. Google has lots of tutorials on this.
2) Connect the Pi and the Laptop with an Ethernet cable ,
no crossover cable necessary.
3) Enter the IP address of the Pi assigned by ICS into PuTTY.
Refer to your googled guide on how to get that one.
ghans
Posted: Sun Feb 01, 2015 11:48 am
by emirahmed1
Cool, I will do that way, on the other hand can u use a usb cable or a hdmi cable instead of a Ethernet cable?
Posted: Sun Feb 01, 2015 11:53 am
by Laurens-wuyts
The micro-usb input is only for power. And if you use HDMI you'll need an HDMI input.
Laurens
Posted: Sun Feb 01, 2015 12:43 pm
by fruitoftheloom
emirahmed1 wrote:Cool, I will do that way, on the other hand can u use a usb cable or a hdmi cable instead of a Ethernet cable?
HDMi no as already explained
USB no as you need a Master and Slave Device to communicate, both the RPi and Laptops are Master
All this and more covered in this forum and google ;)
Posted: Sun Feb 01, 2015 2:56 pm
by emirahmed1
Oh no, raspberry pi is not identified through Ethernet cable. Can anyone help?
Posted: Sun Feb 01, 2015 3:02 pm
by fruitoftheloom
emirahmed1 wrote:Oh no, raspberry pi is not identified through Ethernet cable. Can anyone help?
Have you set up Internet Connection Sharing on you Windows Laptop :?:
You need to inform what you have done as no one can actually see what you are doing, my Crystal Ball is broken today :!:
Posted: Sun Feb 01, 2015 4:28 pm
by emirahmed1
Yea, mate, how do u enable internet connection sharing?
P.S: It says the Ethernet is an unidentified network. This could have a link to the internet connection sharing process. :roll:
Posted: Sun Feb 01, 2015 4:38 pm
by Joe Schmoe
Have we established that ICS is even necessary? Wouldn't it be easier to connect the Pi directly to your router?
BTW, if you want this "tethering" thing to really work, you might be better off with the BeagleBoneBlack, which has a nifty tethering thing built right in.
Posted: Sun Feb 01, 2015 4:41 pm
by emirahmed1
What would I do once I've connected the pi to the router?
Posted: Sun Feb 01, 2015 5:22 pm
by B.Goode
emirahmed1 wrote:What would I do once I've connected the pi to the router?
Could we go right back to the beginning a moment? I don't see anything to say that you have installed an Operating System on your RPi. Presumably Raspbian if you want to do general projects from The MagPi.
Once you have Raspbian installed and running on your RPi, turn your attention to your PC. I can't see whether you said it is a Windows PC or a Mac? If it is Windows, install an all-in-one package like XMing. Once it is installed, fire it up and make a connection to your RPi. The IP address you need can be found by looking at the network configuration page of your home router (if you have connected that way), or by looking at the ICS status page if that is what you have done.
Posted: Sun Feb 01, 2015 5:24 pm
by B.Goode
[duplicate deleted]
Posted: Sun Feb 01, 2015 5:26 pm
by B.Goode
[duplicate deleted]
Posted: Sun Feb 01, 2015 5:33 pm
by B.Goode
[duplicate deleted]
Posted: Sun Feb 01, 2015 5:36 pm
by Joe Schmoe
So good you posted it 5 times!
Posted: Sun Feb 01, 2015 8:06 pm
by B.Goode
Joe Schmoe wrote:So good you posted it 5 times!
Indeed! And there isn't an option to delete them.
(Forum software anomaly: if I press submit and the system responds 'error, try again later' guess what I did: tried again of course... I didn't think my message had been posted! Apologies for the 'noise'.)
Posted: Sun Feb 01, 2015 11:26 pm
by Joe Schmoe
Yeah. I'd be curious to know what caused the forum to go haywire earlier today (of course, we can all be glad it didn't do the chocolate nonsense again - we'll be happy if that never happens again…).
But I guess one has to be aware that on posting, it does go through, it is just the "re-painting" of the screen that fails. FWIW, my browser warned me when I tried to send it again - it said "Are you sure you want to send this form again - doing so could result in duplicate purchases or worse…"
