Composite video out issue
Posted: Fri Jan 30, 2015 4:44 am
I have a Raspberry Pi B+ (512Mb) powered via USB 5V wall power supply. I'm looking to wire up to some screens for in-car video. The screens are 480x324 (aka 1440x234 16:9).
Here is a picture of the video signal: http://imgur.com/QnhfQyt
This smells like a config problem.
I've tried:
1. 2 different distros (Raspbmc and Rasbian)
2. Tried several combos of config.txt settings:
sdtv_mode=0
sdtv_aspect=3
--and--
sdtv_mode=2 (the screen supports PAL and NTSC)
sdtv_aspect=3
--and--
sdtv_mode=0
sdtv_aspect=1 (the screen supports 4:3 and 16:9)
3. Tried connecting to a 50" Samsung LCD TV via composite video.
Result: Same issue
4. Tried 4 different 3.5mm mini-plug to composite cables
5. Tried all three (white, red and yellow) lines as video out
6. Tried a replacement Raspberry Pi-- same result.
Any thoughts, suggestions or next steps would be greatly appreciated.
Thanks!
I've tried:
sdtv_mode=0
sdtv_aspect=3
--and--
sdtv_aspect=3
--and--
sdtv_mode=0
Result: Same issue
Thanks!
