Motion raspberry pi B+
Posted: Thu Jan 29, 2015 6:26 pm
by alphawere
I have two Raspberry Pi one the model B and the other is B+ i had motion install on both then had to do a re-install of the B+ now motion wont run even though its states its running both are Raspbian and fully update. also the webcams are both logitec one C300 and the other C270 both work on on the modle B but nothing on the the B+
Any ideas?
Re: Motion raspberry pi B+
Posted: Thu Jan 29, 2015 11:54 pm
by mirak123
Do you have same version of kernel and firmware on both Raspberry Pi?
$ uname -a
$ vcgencmd version
It might be the same issue as my problem http://www.raspberrypi.org/forums/viewt ... 28&t=97983
Posted: Fri Jan 30, 2015 2:21 pm
by alphawere
Hi thanks for the reply the out come on both pi's was
the model B
uname -a
Linux MiPi 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l GNU/Linux
vcgencmd version
Dec 19 2014 18:44:06
Copyright (c) 2012 Broadcom
version 5abd572e2ed1811283443387af09377b95501c50 (clean) (release)
B+
uname -a
Linux newberrypi 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l GNU/Linux
vcgencmd version
Dec 19 2014 18:40:20
if i am reading this right i have the same kernel and firmware running on both
Posted: Fri Jan 30, 2015 3:36 pm
by mirak123
Well, you have still kernel 3.12, so it seems to be a different issue. Is your webcam working with other software, such as guvcview or mjpg_streamer? Which kernel messages can you see after attaching your webcam and then after running motion?
$ dmesg
SOLVED Re: Motion raspberry pi B+
Posted: Fri Jan 30, 2015 10:29 pm
by alphawere
Sorry for delay i have had a mad day the issue seams to be fixed beleve it or not i pluged in a cheap £5 no driver webcam i got from amazon and now motion is behaving itself.
Thanks for the help
