Omxplayer Error - Raspberry Pi B+
Posted: Tue Jan 27, 2015 10:50 pm
by jayemm96
Hi
I have set up a schedule to play videos using omxplayer/cron/c++ (using system() calls) on the raspberry pi (B+). The videos launch fine for around 1 day and then after that omxplayer doesn't play the videos ("* failed to add service- already in use?") and i need to restart the pi to make it work again. Here are the details:
omxplayer -v :
Build date: Fri, 24 Oct 2014 00:48:49 +0000
Version : 98982df [master]
Repository: https://github.com/popcornmix/omxplayer.git
uname -a
Linux raspberrypi 3.12.36+ #737 PREEMPT Wed Jan 14 19:40:07 GMT 2015 armv6l GNU/Linux
I have attached omxplayer.log, according to this it is an audio problem but I am unsure how to fix.
22:33:19 T:1112340559   DEBUG: DllBcm: Using omx system library
22:33:19 T:1112345728   DEBUG: DllOMX: Using omx system library
22:33:19 T:1112349298   DEBUG: DllAvFormat: Using libavformat system library
22:33:19 T:1112362743 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
22:33:19 T:1112364967 WARNING: DBus connection failed, trying alternate
22:33:19 T:1112374841   DEBUG: DBus connection succeeded
22:33:19 T:1112385886   DEBUG: Keyboard: DBus connection succeeded
22:33:19 T:1112386712   DEBUG: OMXThread::Create - Thread with id -1303616448 started
22:33:19 T:1112387180   DEBUG: DllAvUtilBase: Using libavutil system library
22:33:19 T:1112387389   DEBUG: DllAvCodec: Using libavcodec system library
22:33:19 T:1112387554   DEBUG: DllAvFormat: Using libavformat system library
22:33:19 T:1112392689   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1112894865   DEBUG: Previous line repeats 24 times.
22:33:20 T:1112894865   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x45ec20
22:33:20 T:1112896615   DEBUG: OMXClock::OMXStop
22:33:20 T:1112897367   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
22:33:20 T:1112898730   DEBUG: DllAvUtilBase: Using libavutil system library
22:33:20 T:1112898993   DEBUG: DllAvCodec: Using libavcodec system library
22:33:20 T:1112899151   DEBUG: DllAvFormat: Using libavformat system library
22:33:20 T:1112902245   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1112907134   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x45ebb0
22:33:20 T:1112912213   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(60), nBufferSize(81920), nBufferAlignmen(16)
22:33:20 T:1112922808   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1112946943   DEBUG: Previous line repeats 1 times.
22:33:20 T:1112946943   DEBUG: COMXVideo::Open - decoder_component(0x0x45ebb0), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 0
22:33:20 T:1112948768   DEBUG: OMXThread::Create - Thread with id -1317014464 started
22:33:20 T:1112949320   DEBUG: OMXThread::Create - Thread with id -1325403072 started
22:33:20 T:1112949745   DEBUG: DllAvUtilBase: Using libavutil system library
22:33:20 T:1112949937   DEBUG: DllAvCodec: Using libavcodec system library
22:33:20 T:1112950094   DEBUG: DllAvFormat: Using libavformat system library
22:33:20 T:1112950364   DEBUG: DllAvUtilBase: Using libavutil system library
22:33:20 T:1112950532   DEBUG: DllAvCodec: Using libavcodec system library
22:33:20 T:1112950688   DEBUG: DllAvFormat: Using libswresample system library
22:33:20 T:1112970805   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113005216   DEBUG: Previous line repeats 1 times.
22:33:20 T:1113005216   DEBUG: DllAvUtilBase: Using libavutil system library
22:33:20 T:1113005907   DEBUG: COMXAudio::SetCodingType OMX_AUDIO_CodingPCM
22:33:20 T:1113006306    INFO: CPCMRemap: I channel map: FL,FR
22:33:20 T:1113006619    INFO: CPCMRemap: O channel map: FL,FR
22:33:20 T:1113006800   DEBUG: CPCMRemap: Downmix normalization is disabled
22:33:20 T:1113007056   DEBUG: CPCMRemap: FL = FL(1.000000*)
22:33:20 T:1113007351   DEBUG: CPCMRemap: FR = FR(1.000000*)
22:33:20 T:1113013254   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113023082   DEBUG: OMXThread::StopThread - Thread stopped
22:33:20 T:1113024791   ERROR: COMXCoreComponent::FlushInput - Error on component OMX.broadcom.audio_decode omx_err(0x8000101b)
22:33:20 T:1113025720   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_decode input port 120 output port 121 m_handle 0x5a5ff0
22:33:20 T:1113033794   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113045747   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_decode) - port(120), nBufferCountMin(4), nBufferCountActual(16), nBufferSize(65536), nBufferAlignmen(16)
22:33:20 T:1113054408   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113072835   DEBUG: COMXAudio::Initialize Input bps 32 samplerate 44100 channels 2 buffer size 529200 bytes per second 352800
22:33:20 T:1113073632   DEBUG: pcm->direction      : input
22:33:20 T:1113073874   DEBUG: pcm->nPortIndex     : 0
22:33:20 T:1113074048   DEBUG: pcm->eNumData       : 0
22:33:20 T:1113074290   DEBUG: pcm->eEndian        : 1
22:33:20 T:1113074489   DEBUG: pcm->bInterleaved   : 1
22:33:20 T:1113074669   DEBUG: pcm->nBitPerSample  : 32
22:33:20 T:1113082298   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113082730   DEBUG: pcm->ePCMMode       : 0
22:33:20 T:1113082939   DEBUG: pcm->nChannels      : 2
22:33:20 T:1113083102   DEBUG: pcm->nSamplingRate  : 44100
22:33:20 T:1113083262   DEBUG: OMX_AUDIO_ChannelLF
22:33:20 T:1113083475   DEBUG: OMX_AUDIO_ChannelRF
22:33:20 T:1113084635   DEBUG: COMXAudio::Initialize device omx:hdmi passthrough 0 hwdecode 0
22:33:20 T:1113086154   DEBUG: OMXThread::Create - Thread with id -1333791680 started
22:33:20 T:1113087764  NOTICE: OMXClock using audio as reference
22:33:20 T:1113088735   DEBUG: OMXThread::Run - Exited thread with  id -1333791680
22:33:20 T:1113092261   DEBUG: OMXClock::OMXReset audio / video : 1 / 1 wait mask 0->3 state : 2->1
22:33:20 T:1113102859   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113103900   DEBUG: Popped message member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
22:33:20 T:1113104248 WARNING: Unhandled dbus message, member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
22:33:20 T:1113107794   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:1 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113123490   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113129407   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:1 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113129864   DEBUG: Resume 0.00,0.00 (0,0,0,0) EOF:0 PKT:0x59b728
22:33:20 T:1113130095   DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
22:33:20 T:1113144069   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113152199   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113164628   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113173800   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113185161   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113195257   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113205771   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113217601   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113226458   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113239068   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113247051   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113261334   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113267690   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113283066   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113288265   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113305286   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113308850   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113327383   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113329423   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113349558   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113350500   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113371778   DEBUG: Previous line repeats 1 times.
22:33:20 T:1113371778   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113391377   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113393390   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113412124   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113415093   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113432697   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113436855   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113453247   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113458359   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113473850   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113491721   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113494729   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113505906   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113515233   DEBUG: Keyboard: Process() m_bStop 0
22:33:20 T:1113527388   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:20 T:1113535799   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113548889   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113556377   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113570394   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113576967   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113592855   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113597551   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113614243   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113618663   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113636388   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113639456   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113657830   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113660089   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113679265   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113680629   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113700734   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113701310   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113722619   DEBUG: Previous line repeats 1 times.
22:33:21 T:1113722619   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113742078   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113744252   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113762711   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113765520   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113783486   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113786801   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113804084   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113808389   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113824746   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113829733   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113845331   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113851047   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113865885   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113872442   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113886861   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113893760   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113907505   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113915059   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113928025   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113936358   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113948550   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113957661   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113969039   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1113978991   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1113989589   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114001204   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114010149   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114022603   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114030704   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114043936   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114052449   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114065247   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114072992   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114087017   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114093565   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114108437   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114114094   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114129777   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114134662   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114151151   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114155207   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114172699   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114175697   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114194047   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114196413   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114215452   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114216939   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114236865   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114237481   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114258524   DEBUG: Previous line repeats 1 times.
22:33:21 T:1114258524   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114278158   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114280119   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114298762   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114301398   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114319251   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114322834   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114339810   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114344205   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114360328   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114365468   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114380841   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114396625   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114401620   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114407938   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114422150   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114429256   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114442808   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114450592   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114463352   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114473474   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114486825   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114498616   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114516329   DEBUG: Keyboard: Process() m_bStop 0
22:33:21 T:1114523434   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:21 T:1114537083   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114544730   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114557845   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114565950   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114578706   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114587227   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114599527   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114608514   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114620298   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114629757   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114641074   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114651002   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114662979   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114674915   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114683725   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114699708   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114704217   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114721213   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114724731   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114742711   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114745270   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114764104   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114765744   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114785452   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114786189   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114807313   DEBUG: Previous line repeats 1 times.
22:33:22 T:1114807313   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114826974   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114828786   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114847533   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114850040   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114868466   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114871391   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114889031   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114892837   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114909700   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114914211   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114930242   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114935636   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114950850   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114957025   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114971396   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114978335   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1114991946   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1114999859   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1115012596   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1115021179   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.34)
22:33:22 T:1115025474   ERROR: COMXCoreComponent::WaitForCommand OMX.broadcom.audio_decode wait timeout event.eEvent 0x00000000 event.command 0x00000001 event.nData2 0
22:33:22 T:1115025817   ERROR: COMXCoreComponent::FlushInput - OMX.broadcom.audio_decode WaitForCommand omx_err(0x80001011)
22:33:22 T:1115033203   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1115047810   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,3.37)
22:33:22 T:1115048641   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_decode handle 0x5a5ff0
22:33:22 T:1115048916   ERROR: COMXCoreComponent::Deinitialize - failed to free handle for component OMX.broadcom.audio_decode omx_err(0x0006370c)
22:33:22 T:1115050138   DEBUG: OMXThread::Run - Exited thread with  id -1317014464
22:33:22 T:1115050824   DEBUG: OMXThread::StopThread - Thread stopped
22:33:22 T:1115053704   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1115074140   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,0.00)
22:33:22 T:1115079130   DEBUG: Keyboard: Process() m_bStop 0
22:33:22 T:1115089989   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.video_decode handle 0x45ebb0
22:33:22 T:1115099737   DEBUG: OMXThread::Run - Exited thread with  id -1303616448
22:33:22 T:1115101422   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:0 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,0.00)
22:33:22 T:1115102291   DEBUG: OMXThread::StopThread - Thread stopped
Please help. I have Googled the error and none of the solutions worked for me. I have also tried
killall omxplayer.bin
before launching the video.
