Garbage output USB to Serial cable
Posted: Tue Jan 27, 2015 9:04 pm
Hi All,
I've sucessfully used a USB to Serial cable before using SSH through Putty to send commands to my raspberry Pi. However this week I decided to start a new project and I have found a problem that I haven't come across before. When I start Putty and turn on the Pi I get the standard boot up messages but the whole thing stalls and spews garbage nonsense characters (I've noticed it spews them out just before the boot up sequence too) see screenshots via dropbox link below;
Pictures
https://www.dropbox.com/sh/kegrwnsy5oek ... 1Jmoa?dl=0
I've googled the problem and the closest problem seems to be the following link --> http://www.raspberrypi.org/forums/viewt ... 3&p=564260
I am using Adafruit's Occidentalis for the SD card image and I have the correct work around drivers through Windows 8.1. I have connected the USB cable to the GPIO pins GND, TX, RX. Powering the Pi from a power supply or by connecting the 5v GPIO pin or 3.3v Pin yields the same results. At Baud rate 115200 I get no output whatsoever, but I can edit the cmd.txt on the SD card to use 9600 Baud which gives me something, other than that I'm still stuck. Can anyone help?
Pictures
