1. I tried testing A Link To The Past on the Pi, and it was running at a very slow rate. I've heard that running a High Overclock (950 Mhz) should get most games running at a good speed, but SA-1 and Super FX won't work. If I were to use a 3.7V Li-Pol Battery, and use a voltage booster (PowerBoost500C from Adafruit), would I be able to provide enough power to use a High Overclock?
2. Would I require a heatsink/fan for this level of OC when it is in a 3D printed case?
3. I also heard that it isn't safe to OC when your OS in on a SD card, as it can ruin the Card. Is this true? I am using a Lexar Platinum II 16GB SDHC card. Im not sure it matters but it also says 60x.
Thanks for taking the time to answer!
