I am learning a little javascript and using Epiphany as the browser on a RPi.
In the book i am using, 'Eloquent Javascript', most examples output with console.log() but I can't see how to see this output in Epiphany.
Is there no console output in Epiphany?
Any ideas?
Thanks,
Shane
- Contact: Website
Epiphany Javascript console.log()
Pi = too much fun!
Re: Epiphany Javascript console.log()
perhaps not you can allwats create the console object and create a log() function in it ...
or create a div and push the log content to that ...
Sorry cant be much help .
Real life is, to most, a long second-best, a perpetual compromise between the ideal and the possible.
Meanwhile, the sysadmin who accidentally nuked the data reckons "its best not run anything more with sudo today"
what about spike milligan?
- Contact: Website
Thanks for your reply. Objects are the next chapter, so this is a little beyond me at the moment.r3d4 wrote:create the console object and create a log() function in it ... or create a div and push the log content to that ...
Should try a different browser?
Thanks,
Shane
Pi = too much fun!
Well im no expertofey wrote:Thanks for your reply. Objects are the next chapter, so this is a little beyond me at the moment.r3d4 wrote:create the console object and create a log() function in it ... or create a div and push the log content to that ...
Thanks,
Shane
but i would just skip a head a chaper to read up on objects and or use this
var console = {} ; // <---- This is an object called console
console.log = function (str) { alert( str ) ; }
// you can write the above in a diffrent way like
var console = { "log" : function (str){ alert(str) ; } } ;
Realy it is up to you , when i was learning js console.log() was not avalable as a 'built in function' of the browser
so you can survive without it if need be , one alternative method would be to just use
alert('somthing happened') ;
- DougieLawson
- Contact: Website Twitter
Firefox with the web developer (on Windows) stuff is going to be much better.ofey wrote: Should try a different browser?
Develop & debug on Windows, deploy on Raspberry Pi.
- Contact: Website
r3d4 thanks i will just use alert() for the moment.
json.org does have very clear diagrams. Thanks for this.
Shane
Thanks Dougie, I think this the best option.Develop & debug on Windows, deploy on Raspberry Pi.
Shane
Pi = too much fun!
DougieLawson wrote: Firefox with the web developer (on Windows) stuff is going to be much better.
\r\n
- Contact: Website
and this means it is all the same?\r\n
Like carriage return / newline... probably a techie joke...
Pi = too much fun!
- DougieLawson
I'll see your carriage return & newline and raise your3d4 wrote:Code: Select all
\r\n
- Contact: Website
Glad to hear that!DougieLawson wrote:...some kind of poker bidding, ... it doesn't make any sense otherwise.
Pi = too much fun!
DougieLawson wrote:I'll see your carriage return & newline and raise your3d4 wrote:Code: Select all
\r\n
I assume it's some kind of poker bidding, because it doesn't make any sense otherwise.Code: Select all
Its the first thing i can remember about working between windows n other os that wiill trip up any one using default text editors ; that dont display chars you cant see .
Perhaps this is no longer a problem ??
i did not see the OP didnt mention windows ..
>> 'Develop & debug on Windows, deploy on Raspberry Pi.'
to me apperars like pointing some asking for directions the wrongway
- DougieLawson
The newline vs carriage return/newline is not a problem with Javascript.
If it ever is a problem then dos2unix is the simple tool to undo the \r\n stuff.
I'm launching epiphany from the command line using SSH using "epiphany-browser -a --profile ~/.config <URL>"
console.log() messages appear in the SSH terminal output
True but i would guess that the 'command line' tools ect is a bit further along the 'learning curve' for most who wander in off the web scripting js !DougieLawson wrote:If it ever is a problem then dos2unix is the simple tool to undo the \r\n stuff.
I hate to resurrect a dinosaur thread, but in this case I think it's warranted.
This thread turns up in searches about how to enable the JS debugger, so for the help of future JS tinkerers, I'd like to supply the answer:
Open up Terminal, and run Epiphany like so:
Developing and debugging on Windows/Chrome is not always the right answer, since you can very easily fall into traps set by ECMA Script 6 only features which are not supported in Epiphany. IE: Something can work absolutely *fine* on Windows/Chrome but fail in Epiphany 3.8.x on the Pi.
The magic words above will give you a clunky albeit functional debugger for catching any incompatibilities which slip through.
EPHY_ENABLE_INSPECTOR=true epiphany
Thanks!gadgetoid wrote:The magic words above will give you a clunky albeit functional debugger for catching any incompatibilities which slip through.Code: Select all
(from a current tinkerer)
