PhilE
Re: STICKY:I2C, SPI, I2S, LIRC, PPS, stopped working? Read this.
Thu Nov 30, 2017 5:20 pm
We'll need a bit more information:
1. Which AD device is it?
2. Which application/script is reading it? A link to the source would help.
3. What were you upgrading from?
4. Can you show spidev_test output before and after the upgrade? You can download previous Raspbian releases here.
monkijohnni
Thu Nov 30, 2017 8:06 pm
Thank you for the fast reply!
1. I'm just using an MCP3008 AD chip, so nothing too complicated. A PT100 thermistor is talking to it on CH0.
2. Here is my code:
#!/usr/bin/python3
import spidev
import time
import os
spi = spidev.SpiDev()
spi.open(0,0)
# Function to read SPI data from MCP3008 chip
# Channel must be an integer 0-7
def ReadChannel(channel):
  adc = spi.xfer2([1,(8+channel)<<4,0])
  data = ((adc[1]&3) << 8) + adc[2]
  return data
def ConvertVolts(data,places):
  volts = (data * 3.3) / float(1023)
  volts = round(volts,places)
  return volts
def ConvertTemp(data,places):
  temp = (0.972*(data))-359
  temp = round(temp,places)
  return temp
temp_channel  = 0
delay = 5
while True:
  temp_level = ReadChannel(temp_channel)
  temp_volts = ConvertVolts(temp_level,6)
  temp       = ConvertTemp(temp_level,6)
  print "--------------------------------------------"
  print("Temp : {} ({}V) {} deg C".format(temp_level,temp_volts,temp))
  time.sleep(delay)
3. I was apt-get upgrade(ing) from the 2017-09-07 RASPBIAN STRETCH WITH DESKTOP image (still most current). Very little had been changed to the image since downloading and flashing it to the SD card EXCEPT that I had set up some localization preferences, and I apt-get update(d) prior to running apt-get upgrade.
4. I'll do this when I get home tonight (sorry)...
PhilE
Thu Nov 30, 2017 8:59 pm
You can hold off on 4 for a bit until we've ruled out the obvious cause (or not).
A recent change to the SPI subsystem was to increase the maximum bus speed (it was artificially low before). Unfortunately, the default bus speed for transfers is set to the maximum allowed, so applications that don't set a speed will likely end up with something unusable.
Try setting the max_speed_hz property to something sensible:
      spi.open(0,0)
      spi.max_speed_hz=1000000
monkijohnni
Thu Nov 30, 2017 11:36 pm
EDITED: lowering bus speed fixed it.
Increasing the bus speed seem to fix it. I included the spi.max_speed_hz=1000000 in my code, and got feedback from SPI.
#!/usr/bin/python3
import spidev
import time
import os
spi.open(0,0)
Seems that going over 10,000,000 started to interfere with the readings I got back. I'm going to stick with 1,000,000.
PhilE
Fri Dec 01, 2017 9:21 am
Apart from dropping the speed right down - 100000 or lower, for example - I'm not sure what to suggest.
monkijohnni
Fri Dec 01, 2017 4:10 pm
My last post was incorrect. Setting the bus speed DID fix the SPI problem, I just was getting incorrect results because of a wiring error (was working remotely).
Seems that any bus speed under 10,000,000 works well. Thank you so much for your help, PhilE! I really appreciate it.
-John
#!/usr/bin/python3
import spidev
import time
import os
spi.open(0,0)
Who is online
Users browsing this forum: Zombigamer02 and 55 guests
