geep999
Bought powered hub - now no USB works!
Wed Jun 27, 2012 5:42 pm
Having seen that it's recommended to use a powered hub I bought one from Argos - Mikomi 4 port hub USB 2.0. It has a 5v 2A PSU.
Now my Microsoft Wireless Keyboard 800 and Wireless Mouse, also my old fashioned PS2 keyboard and mouse (via PS2 to USB converter lead) don't work at all. Previously the wireless keyboard had sticky keys, and I had hoped that using a powered hub would cure this.
There are nasty messags from dmesg | grep usb , listed below.
Does anybody know what it all means?
Cheers,
Peter
[ 4.750006] usbcore: registered new interface driver usbfs
[ 4.755681] usbcore: registered new interface driver hub
[ 4.761405] usbcore: registered new device driver usb
[ 5.203835] usbcore: registered new interface driver smsc95xx
[ 5.213360] usbcore: registered new interface driver cdc_ncm
[ 5.461508] dwc_otg bcm2708_usb: DWC OTG Controller
[ 5.466686] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 5.480257] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
[ 5.511268] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.524226] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.537510] usb usb1: Product: DWC OTG Controller
[ 5.548217] usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
[ 5.559949] usb usb1: SerialNumber: bcm2708_usb
[ 5.592478] usbcore: registered new interface driver uas
[ 5.614754] usbcore: registered new interface driver usb-storage
[ 5.637681] usbcore: registered new interface driver libusual
[ 5.754857] usbcore: registered new interface driver usbhid
[ 5.766464] usbhid: USB HID core driver
[ 6.081741] usb 1-1: new high speed USB device number 2 using dwc_otg
[ 6.322392] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 6.337495] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.661861] usb 1-1.1: new high speed USB device number 3 using dwc_otg
[ 6.772145] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 6.784977] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.867269] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a3:d1:84
[ 6.961709] usb 1-1.3: new high speed USB device number 4 using dwc_otg
[ 7.071983] usb 1-1.3: New USB device found, idVendor=058f, idProduct=6254
[ 7.085271] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.411716] usb 1-1.3.1: new full speed USB device number 5 using dwc_otg
[ 7.521889] usb 1-1.3.1: device descriptor read/64, error -71
[ 7.741710] usb 1-1.3.1: device descriptor read/64, error -71
[ 7.941714] usb 1-1.3.1: new full speed USB device number 6 using dwc_otg
[ 8.051716] usb 1-1.3.1: device descriptor read/64, error -71
[ 8.271720] usb 1-1.3.1: device descriptor read/64, error -71
[ 8.491719] usb 1-1.3.1: new full speed USB device number 7 using dwc_otg
[ 8.921614] usb 1-1.3.1: device not accepting address 7, error -71
[ 9.257806] usb 1-1.3.1: new full speed USB device number 8 using dwc_otg
[ 9.681687] usb 1-1.3.1: device not accepting address 8, error -71
[ 9.941723] usb 1-1.3.4: new low speed USB device number 9 using dwc_otg
[ 10.051715] usb 1-1.3.4: device descriptor read/64, error -71
[ 10.271724] usb 1-1.3.4: device descriptor read/64, error -71
[ 10.471717] usb 1-1.3.4: new low speed USB device number 10 using dwc_otg
[ 10.581750] usb 1-1.3.4: device descriptor read/64, error -71
[ 10.805060] usb 1-1.3.4: device descriptor read/64, error -71
[ 11.011878] usb 1-1.3.4: new low speed USB device number 11 using dwc_otg
[ 11.441609] usb 1-1.3.4: device not accepting address 11, error -71
[ 11.551882] usb 1-1.3.4: new low speed USB device number 12 using dwc_otg
[ 11.981612] usb 1-1.3.4: device not accepting address 12, error -71
elatllat
Re: Bought powered hub - now no USB works!
Sun Aug 12, 2012 7:24 pm
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
elatllat
Sun Aug 12, 2012 8:11 pm
