Montala
Re: Board versions/revisions, or different assembly lines?
Thu Jul 05, 2012 7:06 pm
Mortimer wrote: So the board code is YYWW and sticker YYMM.
Agreed!
Sorry, but I thought you were referring to the sticker code before.
On my (Farnell) Pi, the Board code is 1218 and the Sticker code is 1205 which ties in also.
I wonder what the RS one will say... when it arrives!
antijn
Thu Jul 05, 2012 9:28 pm
I've added the details for my cards on the wiki.
It seems that our misbehaving boards match up pretty well.
dukla2000
Thu Jul 05, 2012 11:20 pm
My Pi from RS seems to be near to the one antijn has problems with - I haven't had any issues with mine running arm_freq=850 at otherwise standard settings. Apologies not very good at wiki editing so all details below - happy for someone else to add them.
BH1218
Hynix H9TKNNN2GDMP LRNDM 217A
SMSC LAN9512-JZX B1215-A1817 BR1494828
C6 2E 220 16H
F1/F2 14/14 6.1/5.6 ohm
RG2 SE8117T33 1213-LF
Ethernet HR901110A 1211
From RS, sticker E2112RSV1.0B1.1
Daily driver: Pi3B, 64GB Samsung Evo+ @100MHz, DVB-T, onboard WiFi for internet, BT/USB dongle for KB/mouse, 250GB HDD via USB for media, Raspbian Jessie Lite with Openbox desktop.
Museum: Pi B
marcoalexcampos
Fri Jul 06, 2012 1:04 pm
@dukla2000: Done. If you get pictures just email them to me. Thanks.
marcoalexcampos
Mon Jul 09, 2012 3:01 pm
FYI: So far 25 entries, and we start to see more feedback witch is very important.
genothomas
Sat Aug 25, 2012 10:30 am
I got mine from Farnell, I haven't had any issues with it yet. :D
BS1222
Sticker FN120804931
Samsung 222 K4P2G324ED-AGC1 GAD0238K
SMSC LAN9512-JZX B1220-A1B17 8R150479B
C6 2F 220 16H
F1/F2/F3 ?/?/T075 0/0/0 ohm, I think all three are same
RG2 SE8117T33 1220-LF
Ethernet HanRun HR901110A 1225
d4lamar
Tue Aug 28, 2012 5:31 pm
I've got a board with the same SMSC chip as marcoalexcampos, and I've got lots of problems with USB HUBs and USB peripherals in general.
I wrote the details of my board here: http://elinux.org/RaspberryPi_Boards
I tested different power supplies and there's no problem with them , the board is always in the right range.
I tested different peripherals, and I bought a new USB HUB among those that are sponsored as "verified" in this list: http://elinux.org/RPi_VerifiedPeripherals
Last test was with Belkin F5U706ea USB HUB and I've got this error on eth0 even without any cable connected to it.
 smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000...
With another USB HUB (Dlink DUB-H7) I had other kinds of problems with the Wifi USB dongle and the sticky keys from the keyboard.
This is the list of my USB peripherals I've got for my tests:
  • * USB HUB Belkin F5U706ea
    * USB HUB Dlink DUB-H7
    * USB Keyboard Logitech K400
    * USB WiFi dongle Dlink DWL-G122
I'm gonna give up on this board, do you think there's a way to receive a new one as replacement ?
Is there anyone with this SMSC chip and no issues? (I saw a "certain" Mortimer on the list)
LAN9512-JZX
B1215-A1B17
8R150188B
ASE-TW
(e3)
Thanks In Advance,
d4lamar
Tue Aug 28, 2012 6:22 pm
Can you check out the 'USB elephant' thread - this has some fixes for the problem you are seeing - not completely but should improve USB a lot.
d4lamar
Wed Sep 05, 2012 5:16 am
jamesh wrote:Can you check out the 'USB elephant' thread - this has some fixes for the problem you are seeing - not completely but should improve USB a lot.
Thanks,
I knew the thread, but I still need some hint to do something more rational than testing any component configuration I imagine.
I updated to the latest firmware and debian wheezy image, and USB problems seem to be gone.
# uname -a
Linux raspberrypi 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l GNU/Linux
# /opt/vc/bin/vcgencmd version
Aug 25 2012 01:10:05
Copyright (c) 2012 Broadcom
version 333347 (release)
I deleted the problems notification for my board on the wiki page: http://elinux.org/RaspberryPi_Boards
I hope to be full operational now.
d4lamar
Wed Sep 05, 2012 8:35 am
Great - hope its all working fine now.
skammah
Thu Jan 10, 2013 7:16 am
I just got 2 R-Pi's from Element 14 (one for me and one for my son).
Sticker Number(s): FNXM1212xxxxx
silk screened board number 1248
Ethernet: HanRun HR901110a - 1241
Proc (IC2): Samsung
RAM (IC3): SMSC
I could not get HDMI output until I forced hdmi with
hdmi_safe=1
I have used 3 different USB connectors, each providing 1A. When probed with my multimeter at TP1 and TP2, I get around 4.80 - 4.87V with each.
I have been unable to get the network to come up at all.
USB is working.
I have tried to get networking started with ifup eth0 both at the command line and within Xwindows.
I never see any of the LEDs for the NIC light at all, even when doing an ifup eth0 and the NIC should be activated, listening for my DHCP server.
I have plugged my USB keyboard/mouse into a powered USB hub with no luck.
The only other posts that I have seen about lack of networking was from folks with bad power. I feel like my power should be sufficient, if not acceptable. At this point, I am unable to identify if this is a board issue, or PEBCAK / OSI Layer 8.
What tests can you suggest?
Thu Jan 10, 2013 8:24 am
This is the wrong place for you question - please repost in the trouble shooting section in a new thread. Thanks.
kevin34ct
Tue May 07, 2013 4:33 pm
My sticker says: E5012RS2V13B1.0
RAM Chip: SAMSUNG 246
K4P4G324EB - AGC1
GKI0479H
USB: SMSC
LAN9512-JZX
81239-A1817
8R1521008
CTI-TW
LAN HEADER: HanRun
HR901110A
1238
RG2: SE8117T33
1238-LF
DATE CODE: 1248
So far working fine. Haven't really tested thoroughly yet. I've run Raspbian no problems, and Raspbmc/OpenELEC, with some issues of constant buffering. Tried power from a iphone cube, will try from a powered hub next. Also tried running from Lan, WiFi adapter, and USB hard Drive with same stuttering.
grzegorzn
Sun Jul 14, 2013 2:08 pm
My board:
Board ver.: BS1318
RAM Chip: Samsung 316 K4P4G324EB-AGC1 GKD0M4GFU
USB Chip: SMSC LAN9512-JZX B1315-A1B17 315271A CTI-TW
C6: 220 CFP 3B4
RG2: 17-33G RLC16
Issues: http://www.raspberrypi.org/phpBB3/viewt ... 7&p=387576
Distributor: Farnell
can_o_pi
Mon Nov 11, 2013 11:19 pm
In Canada, I received a model B from Newark/element14, on 6 Oct 2013:
BS1314
(other info surrounding date stamp: KCE MC1 94V-0 F1 3F)
RAM = Samsung 325 K4P4G324EB-AGC1 GKDA79ZZU
USB = SMSC LAN9512-JZX 81319-A1B17 31966UA CTI-TW
C6 = 220 CFP. 3G6
F1/F2 = ?/?
RG2 = 17-33G REC18
(SD date stamp = 23/08)
Rock solid stable (for the most part) as long as the power supply has >1A current. :)
However, I do have one issue with it: the camera input/output quit working. "raspivid -d" would not produce any output, and the command window would hang until i typed ctrl-c. The camera light went on at command entry, but would stay on after ctrl-c. (Same behavior with "raspistill" command.)
[Edit: Having seen several posts from other users describing similar to identical issues, the general consensus seems to be that it is either the RPi board or a software/firmware issue that is the cause of the fault.]
Penthux
Thu Dec 05, 2013 11:00 am
Would it be very beneficial to have a cross reference of board version and hardware revision (and perhaps the hardware serial number too) on this list: http://elinux.org/RaspberryPi_Boards ?
I know my new Raspberry Pi (Micron RAM) board version is a "BM1329" but that doesn't tell me much. A lot of cross referencing and researching on Google is needed just to find out the fundamentals. A central core of more in-depth information would be easier. Although the screen printing on the underside of the board says "1329" there's also a tiny sticker which says 18/11 on it, which I'm not sure what that refers to.
Raspberry Pi model B revision 2 (BM1329) - RS Components (serial 756-8308) - Micron RAM
Processor : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 00000000b4db96e4
dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0xe bcm2708.serial=0xb4db96e4 smsc95xx.macaddr=B8:27:EB:DB:96:E4 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Penthux
Slackware ARM on a Raspberry Pi - SARPi
http://sarpi.co.uk
"Slackware ARM - it's not for NOOBS!"
proj964
Sun Dec 29, 2013 8:10 pm
Another sample:
Sticker: FNXM121225755
RAM: Samsung 246, K4P4G324EB AGC1, GKJF66HBU
NIC: SMSC, LAN9512-JZX, 8R152100A, CTI-TW
C6: 220, 16C, EE6
RG2: SE8117T33, 1238-LF
cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 2.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000f
Serial : 00000000a0ef3c1f
--Jon
Santigs
Tue Apr 01, 2014 4:23 pm
Got mine at element14 a week ago and so far no problems. Model B overclocked to 1ghz and tested this http://elinux.org/RPiconfig#Overclock_stability_test with no problems. Reading speed 18.9Mn/s and writting 6mb/s using the Noobs SD card that came with the Pi.
BS1327
RAM: Samsung 334 K4P4G324EB-AGC1 GKGX85GDU
USB CHIP: LAN9512-JZX 81321-A1B17 321JVGA CTI-TW
C6: 220 CFP-3G6
RG2: 17-33G RRC23
[email protected] ~ $ cat /proc/cpuinfo
processor : 0
BogoMIPS : 2.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 000000006c99f3c5
