Pilsener
Cannot connect to xrdp (remote desktop)
Mon Dec 29, 2014 6:34 pm
I installed xrdp, which should be a walk in the park, according to this page: http://www.raspberrypiblog.com/2012/10/ ... -from.html
When I try to login from my Win7 PC, I get a log window saying:
"connecting to sesman ip 127.0.0.1 port 3350"
That's all.
Nothing more happens.
Restarting xrdp returns no errors.
Reinstalling didn't help either.
Any ideas?
Re: Cannot connect to xrdp (remote desktop)
Mon Dec 29, 2014 7:49 pm
On ANY machine any IP address from the block 127.0.0.1 to 127.255.255.254 is the localhost, the machine you're using at the time trying to talk to itself.
Your RPi (if it's connected to your network) will have an address like 192.168.xxx.xxx as assigned by your home router.
mad-hatter
Mon Dec 29, 2014 11:11 pm
Windows 7, When you have the main rdp screen showing, enter the Pi's IP address then select show options.
You will then get
Check your Pi's IP address and enter your user name (Pi or whatever), then select Edit and enter you password, then save, then connect.I then see "connecting to sesman ip 127.0.0.1 port 3350" and it carries on. Maybe you are not setting your password or user name correctly and saving.
Regards
Mon Dec 29, 2014 11:17 pm
Pilsener wrote:I installed xrdp, which should be a walk in the park, according to this page: http://www.raspberrypiblog.com/2012/10/ ... -from.html
That's all.
Any ideas?
http://www.raspberrypi.org/documentatio ... /README.md
Retired disgracefully.....
Pilsener
Tue Dec 30, 2014 1:04 am
My Rpi has an address of 192.168.1.219, which I also have tried to force to connect to port 3389 in Windows Remote Desktop Client (192.168.1.219:3389).
Still the same result.
As the window shows the login screen from xrdp, and hence the message previously described, I am quite sure that I have the right address.
Restarting the xrdp service on the Rpi causes the PC to close the RDP-window, so this is not as simple as a wrong address.
mad-hatter
Tue Dec 30, 2014 8:58 am
How did you find out the IP address of the Pi?
Why that particular port?
Can you ping the Pi from windows?
Can you ping windows from the Pi?
Can you connect to the internet from the Pi?
You might have to temporally connect a keyboard, mouse and monitor/tv to the Pi.
Have a look here.
http://www.instructables.com/id/Configu ... t-for-rem/
Regards
Pilsener
Tue Dec 30, 2014 1:35 pm
ifconfig.
Default rdp port for Windows. Port 3350 was also tried, just to be sure.
Yes.
Yes.
Yes.
It's all there.
mad-hatter
Tue Dec 30, 2014 1:58 pm
One possible issue might be your windows firewall.
http://windows.microsoft.com/en-gb/wind ... wall-is-on
I don't use windows firewall, its turned off. I use AVG's firewall, I seem to remember I had to allow the Pi
in the firewall rules to have access to get a reply.
You could disconnect from the internet and turn off your firewall and see if you can get through.
If this doesn't work, you've got me stumped.
Maybe someone else can offer some assistance?
Regards
klricks
Tue Dec 30, 2014 3:18 pm
Why are you trying to force port at all? For me RDP just works using only the IP of the RPi.
mad-hatter
Tue Dec 30, 2014 7:26 pm
I just put the IP address in and let xrdp sort it out
klricks wrote:Why are you trying to force port at all? For me RDP just works using only the IP of the RPi.
"klricks" is right.
Just a thought have you run xrdp (is it running) on the Pi?
In a terminal type xrdp, what do you get? I get "xrdp is already running".
Regards
tbrady8
Wed Mar 11, 2015 12:22 am
I ran into the exact same issue. Not sure if this will be helpful for anyone else, but here is what corrected it for me.
It was hanging on "connecting to sesman ip 127.0.0.1 port 3350." I finally thought to run an ifconfig and found the the loopback wasn't even showing up. The interface was not active...
I re-configured my interfaces and it fixed my problem. Basically what I was missing was the "auto lo" line.
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.1.75
netmask 255.255.255.0
gateway 192.168.1.1
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
dotoole
Mon Jul 20, 2015 6:13 pm
tbrady8 wrote:I ran into the exact same issue. Not sure if this will be helpful for anyone else, but here is what corrected it for me.
auto lo
auto wlan0
allow-hotplug wlan0
gateway 192.168.1.1
Thanks, worked perfectly.
RobotModel67
Mon Oct 10, 2016 9:09 pm
I have the same issue with Raspberry Pi 1 and Raspbiam Pixel.
This solve for me: https://ubuntuforums.org/showthread.php?t=1314336
lenzi5
Wed Oct 26, 2016 6:22 pm
I'm new to the raspberry pi and linux. What fixed the error problem connecting and the 127.0.0.1 issue? I'm having the same issue with windows 10 to raspberry pi with 127.0.0.1 5910 error problem connecting
namanam1994
Sun Nov 13, 2016 6:47 pm
i have auto lo, still gives the same error
namanam1994
Mon Nov 14, 2016 4:16 am
auto lo
auto wlan0
allow-hotplug wlan0
gateway 192.168.1.1
my port is default port 5910 with sesman-xvnc :
source-directory /etc/network/interfaces.d
auto lo
ifaces lo inet loopback
ifaces eth0 inet manual
allow-hotplug wlan0
ifaces wlan0 inet manual
wpa-conf /etc/wpa_suppliacant/wpa_suppliacant.conf
allow-hotplug wlan1
iface wlan1 inet manual
anyone...anything ?
PerryD65
Wed Apr 12, 2017 4:11 am
sudo apt-get remove xrdp vnc4server tightvncserver
sudo apt-get install tightvncserver
sudo apt-get install xrdp
klricks
Wed Apr 12, 2017 12:56 pm
PerryD65 wrote:sudo apt-get remove xrdp vnc4server tightvncserver
This is not necessary as it gets installed by xrdp if not present.
fafa92
Mon May 22, 2017 8:02 am
I'm trying to connect to my raspberry zero, but I got this error, I removed and installed xrdp and vnc but it didn't work. Has anyone had this experience before?
WolfReaper
Thu Aug 08, 2019 6:02 pm
Hey,
I was having this issue too. I was updating the rdp and something happened to the shell during the update process and caused the rdp to not present an interface. Any workaround for this issue? I ended up having to contact an IT person running the rdp; however, is there a way myself as the user can get around this if it happens again?
