ThomasDr
no ssh after reboot.
Mon Dec 29, 2014 9:02 am
after a reboot my Rpi do not accept a ssh connection.
For a Test i try the Rpi-monitor, the startpage is viewing, but rpi can't access the json datei.
The Pi is unfortunately far away, is there a way to revive him again?
The voltage I have already switched off and on, without success.
regards
Thomas
Re: no ssh after reboot.
Mon Dec 29, 2014 11:20 am
I'll do your homework for you for a suitable fee.
ThomasDr
Mon Dec 29, 2014 12:13 pm
my problem is, i cut off the power supply and the Pi reboot.
But SSH still not working.
"ssh: connect to host 192.168.0.112 port 22: Connection refused"
regards
Thomas
Mon Dec 29, 2014 6:03 pm
ThomasDr wrote:my problem is, i cut off the power supply and the Pi reboot.
In that case, I see in my crystal ball that you will soon be making a journey.
B.Goode
Mon Dec 29, 2014 6:16 pm
ThomasDr wrote: "ssh: connect to host 192.168.0.112 port 22: Connection refused"
You say your RPi is 'far away', but you are attempting to connect to it with an 192.168.0.* 'private' IP address. Is that something that has worked for you in the past?
ThomasDr
Mon Dec 29, 2014 7:09 pm
The Pi is in range, but difficulties accessing, but I need to make it.
Here I have found the error.
I have an Error in the fstab, after i try to mount a extern Folder.
regards
Thomas
