Noise on audio
Posted: Tue Dec 09, 2014 11:03 am
Hi! I am trying to make a WiFi speaker using Volumino. Currently I have a lot of noise on the sound output and you can also hear beeping when the WiFi dongle is accessing. I know that the built in sound option is not really good for HiFi level sound, if I install say the HiFiBerry DAC should that solve my problems?
I am powering the system via 12V which is directly fed into the amp and then I take off from that and supply a SMPS to get 5V for the RPi and inject it into the 5V pins. Don't know if that could cause any issues as well?
