This is driving me nuts. I have 2 sets of SD cards and have successfully installed Scratch GPIO on my 8Gb cards but when I try to install it on my 4Gb cards I get errors.
I download the files OK then when running the install script I get:-
line 1: --2014-12-07: command not found
line 2: syntax error near unexpected token `('
line 2: `Resolving goo.gl (goo.gl)... 74.125.230.65, 74.125.230.64, 74.125.230.68, ...'
I'm typing this post from my Pi so do have an Internet connection.
I've used the instructions from Cymplecy to do this.
Help much appreciated before I go totally insane
Kim
- Raspberry Pi Certified Educator
- Contact: Website
Re: Problem Installing Scratch GPIO
Hi - is this ScratchGPIO5 or 6beta?
Is there space enough on the card I wonder?
Simon
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
- FTrevorGowen
- Forum Moderator
- Contact: Website
It may be simply that you're running out of space on your 4Gb cards, especially if Raspbian was installed with NOOBS. You can check this via the df command (compare the result for both card sizes).MrsKSayers wrote:This is driving me nuts. I have 2 sets of SD cards and have successfully installed Scratch GPIO on my 8Gb cards but when I try to install it on my 4Gb cards I get errors.
Kim
Trev.
Edit: I see that Simon has cross-posted with a similar suggestion.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
I've tried 4 and 5 same errorsimplesi wrote:Hi - is this ScratchGPIO5 or 6beta?
Simon
I have 214Mb free apparently! is this enough? I'll scream if that's all it is!FTrevorGowen wrote:It may be simply that you're running out of space on your 4Gb cards, especially if Raspbian was installed with NOOBS. You can check this via the df command (compare the result for both card sizes).MrsKSayers wrote:This is driving me nuts. I have 2 sets of SD cards and have successfully installed Scratch GPIO on my 8Gb cards but when I try to install it on my 4Gb cards I get errors.
Kim
Trev.
- Contact: Website
For some reason - your download could be being corrupted
try this (corrected) link instead
and then
Simon
sudo wget https://www.dropbox.com/s/56ohstul6g0nsem/install_scratchgpio5.sh?dl=0 -O isgh5.sh
sudo bash isgh5.sh
- Contact: Website
Hold - on - wrong link!!
- Contact: Website
I've corrected the link in the post 2 above
- Contact: Website
Well - the file is 200Kb so there is enough room for it but that's might not be a lot working headroom for your Pi - try the new link and see how it goesI have 214Mb free apparently! is this enough? I'll scream if that's all it is!
Thanks will give it a go
