acel
Cannot dial ADSL via PPPOE
Fri Nov 14, 2014 2:40 pm
I installed the latest raspbian on raspberry B+, and also installed ppp, pppoe, pppoeconf. Then I set up PPPOE via pppoeconf, and start PPPOE by sudo pon dsl-provider, but raspberry always complains the below message. I tried add the current user (pi) to dip group (I checked /etc/group and it seemed succeeded), logout, reboot, but none of these can fix the below error and make pon executable. Has someone else got this issue before? How can I make it work?
[email protected] ~ $ sudo pon
Error: only members of the 'dip' group can use this command.
[email protected] ~ $ pon
topguy
Re: Cannot dial ADSL via PPPOE
Fri Nov 14, 2014 2:45 pm
Type "groups" , this will list all the groups the currect user belong to. Then you should be sure that the user is properly added to the "dip" group.
acel
Fri Nov 14, 2014 2:49 pm
topguy wrote:Type "groups" , this will list all the groups the currect user belong to. Then you should be sure that the user is properly added to the "dip" group.
Thanks. Yep, I also tried this, groups shows both pi and root are member of "dip".
JPelletier
Wed Nov 02, 2016 2:16 pm
I have the same issue, I'm root and I can't use pon! I always get the error:
