thetitanium08 wrote:Guys. Hi. I am like stuck in this situation since many days. I've set a static ip for rpi in cmdline.txt. it's set to 169.254.1.1 I've set up tightvncserver properly. Also, ive allowed My note 3 tether to be shared with the windows 7 laptop which is connected with rpi via lan cable. But, i can't use the same 169.254.1.1 with AndroidVNC viewer. It shows connection timed out. I tried using port 1, and 5901. But no results.
Please help....
Just so I'm clear, you've got a Note3 connected to some network somewhere, tethered to your Windows7 machine and your Pi connected by a cable to your Win7 machine and you are running a VNCviewer on the Note3? I don't think that is going to work without considerable messing about. Do you have a router? That would make this a lot simpler. Also normally the .1 addresses are used by your router or gateway. You've got two networks here, one between the Note and the Win7 machine and the other between the Win7 machine and the Pi.
Simpler might be to use your note as a portable hotspot and access everything via wireless. Then the Pi and the Win7 machine would be in the same network and on the same address block as the Note3.
My setup at home is a router, with a wireless access point connected by wire. My Pi is connected by wire to the router. My phone is using the WiFi through the wireless access point. It is a snap to use my phone to VNC into my Pi. I'm using RealVNC software on the phone and TightVncserver on the Pi.
