sssemil
Raspberry Pi Into an FM Transmitter
Fri Nov 07, 2014 3:56 pm
Hi, I was trying to make an FM transmitter but I get only some constant beep. Used this - http://www.icrobotics.co.uk/wiki/index. ... ransmitter .
And used this to start
sudo ./pifm sound.wav 100.0
Am I doing anything wrong? Thanks
beta-tester
Re: Raspberry Pi Into an FM Transmitter
Fri Nov 07, 2014 5:08 pm
what RPi you are using A, B rev.1, B rev.2, B++?
is the frequency free, you try to use?
what format has your sound file (mono/stereo, 8/16bit, bit per second)?
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B, RPi3B, RPi3B+, RPiZeroW, ...
sssemil
Fri Nov 07, 2014 6:23 pm
Used model B, sound file was in the project files(star wars song, 16 bit, mono, 44.1kHz), yes frequency is free(also tried different frequencies)
Fri Nov 07, 2014 6:33 pm
sssemil wrote:Am I doing anything wrong? Thanks
If your country has a licensed radio spectrum then you WILL be violating your local broadcasting laws on 100MHz and a number of frequencies near that one (due to the harmonics when broadcasting a square wave).
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Joe Schmoe
Fri Nov 07, 2014 6:39 pm
That doesn't answer the question asked (yes, see sig).
The question asked was "Am I doing anything wrong?", which is very different from the question you chose to answer ("Am I doing anything illegal?").
I believe the phrase to put into your Google is "legal positivism".
MrBunsy
Fri Nov 07, 2014 6:49 pm
I'm not sure encouraging polluting the spectrum can really be seen as a 'good' thing.
