xiait
B+ Berryterminal no sound
Fri Nov 07, 2014 6:12 am
Putting together a school computer lab using Raspberry Pi B+s running Berryterminal, with Edubuntu 12.04 on the server. I can't get sound out of the headphone jack. We don't have HDMI monitors, so we're using a HDMI-to-VGA adaptors on them. The adaptors also have an audio out port and I can't get sound out of it either.
I ran Raspbian on one of the units and confirmed that I can get sound out of the headphone jack that way. So: there's no hardware problem.
When logged into the server using a Pi, PulseAudio Volume Control (pavucontrol) shows that Pulse Audio thinks the sound is going to a Broadcom card, like it should be.
I've seen forum posts about running amixer commands ("cset numid=3 1" to force headphone output). The problem is, when I'm logged into the server, that command would run on the server, not the Pi. And when I'm not logged into the server (e.g., if I boot up with the network cable disconnected), amixer isn't installed.
What I think I'd like to do is: install amixer onto the Pi, and have it run the cset command before the Pi tries to connect to LTSP. I don't know how to do this.
Can anyone provide instructions for adding packages to the Berryterminal install? Or any other ideas how I can figure out why sound isn't working?
Re: B+ Berryterminal no sound
Sat Nov 08, 2014 12:33 pm
Whilst I do not have an answer, it would appear BerryTerminal was released 12 months ago, which is prior to the RPi B+ release.
Maybe take a look at the newer LTSP
http://gbaman.github.io/RaspberryPi-LTSP
http://www.raspberrypi.org/forums/viewt ... 99&t=79831
xiait
Tue Nov 11, 2014 12:08 pm
Thanks for the suggestion. Pi-LTSP is a very nice system, and the maintainer was really helpful when I got stuck with something, but I've learned that I need a thin client system, so it looks like I'm back to BerryTerminal.
I'll post again if I get it working, and I'll keep watching this thread in case anyone has any advice for this setup.
LakesideRob
Thu Jan 01, 2015 12:20 pm
Happy New Year,
Have you found a solution to this? I am getting ready to start a similar project, and in my studies for a HDMI to VGA adapter that would fit the bill, I came across this... http://www.amazon.com /Ableconn-HDMI2VGAD-Converter-1920x1200-1920x1080/dp/B00JLRHMZE/ref=sr_1_6?ie=UTF8&qid=20114604&sr=8-6&keywords=HDMI+to+VGA+CONVERTER which specifically states that it leaves the audio on the source side. Hopefully that helps you out.
mahjongg
Thu Jan 01, 2015 2:58 pm
leaving audio on the source side is simply an euphemism for not supporting the conversion of HDMI audio to analog audio, a disadvantage advertised as an advantage... nothing to do with this problem either, as you can simply ignore the availability of HDMI audio conversion in other adapters.
Reeks as advertising, so I disabled the link. we don't want to encourage rampant advertising here. Anyone that still thinks this adapter is anything special can repair the link.
LakesideRob
Sun Jan 04, 2015 12:38 pm
I certainly wasn't advertising, and I'm REALLY struggling with this problem right now myself. I've got a Pi B (not plus) hooked up through an HDMI to VGA adapter (not the one that I linked to, just a cheap one I picked up from Amazon) and I can not get sound from headphones. Would love any support or ideas anyone has to solve this!
Thanks.
Sun Jan 04, 2015 12:57 pm
LakesideRob wrote:I certainly wasn't advertising, and I'm REALLY struggling with this problem right now myself. I've got a Pi B (not plus) hooked up through an HDMI to VGA adapter (not the one that I linked to, just a cheap one I picked up from Amazon) and I can not get sound from headphones. Would love any support or ideas anyone has to solve this!
Thanks.
Yes even the £5.00 HDMi to VGA adaptors do not appear to have audio output on the RPi
Best to use a HDMi TV and use the TV Audio Out
It is the Adaptors which are crap not the RPi ;)
LakesideRob
Sun Jan 04, 2015 1:14 pm
thanks fruitoftheloom...
So is there really no work around? These piterminals would be going into an existing computer lab with existing vga monitors... swapping out the displays isn't in the cards right now financially. There must be a way to point the sound to the output jack, no? Is there a known good HDMI > VGA + Sound adapter that someone can point me to? Using Berryterminal here, just in case that wasn't clear.
Sun Jan 04, 2015 1:19 pm
Two things.
1. If these are A+ or B+ pis how about using Gert's VGA adapter that sits on the GPIO pins.
2. If the monitors are new do they have DVI-D. DVI-D is electrically identical to HDMI with a different connector. A straight through no adapter needed cable costs less than £5.
Sun Jan 04, 2015 1:21 pm
LakesideRob wrote:thanks fruitoftheloom...
As stated you will need to find an Adaptor which works, it is nothing to do with the OS, maybe use a USB Powered Adaptor and see if that makes a difference :?:
http://www.ebay.co.uk/itm/HDMI-to-VGA-R ... 5d52f01f5f
