The Russian
error when starting the graphical interface
Sat Nov 01, 2014 4:57 pm
I get:Errors from xkbcomp are not fatal to the x server.
What´s wrong?
DirkS
Re: error when starting the graphical interface
Sat Nov 01, 2014 5:43 pm
It says 'errors are not fatal' so apparently there's nothing wrong, really...
Gr.
Dirk.
Sat Nov 01, 2014 5:46 pm
Start by looking at /var/log/Xorg.0.log search that file for any lines that have "(EE)" as they document the errors that have been fatal to the Xwindows server.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
The Russian
Sat Nov 01, 2014 9:31 pm
Don´t know how to check the:/var/log/Xorg.0.log (Newbie).....
But it say on the prompt : (WW) Warning, (EE) error, (NI) not implemented (??) Unknown.
Sat Nov 01, 2014 9:38 pm
In a command window use sudo less /var/log/Xorg.0.log
The Russian
Sat Nov 01, 2014 10:04 pm
I get the same line there to:
Sat Nov 01, 2014 10:13 pm
And no other lines with (EE)?
In that case you have nothing wrong with your X windows server. Look elsewhere for the problem.
PeterO
Sun Nov 02, 2014 7:59 am
DougieLawson wrote:Start by looking at /var/log/Xorg.0.log search that file for any lines that have "(EE)" as they document the errors that have been fatal to the Xwindows server.
Not strictly true as lines tagged with "EE" may also tag non-fatal errors.....
[    18.073] (==) Matched fglrx as autoconfigured driver 0
[    18.073] (==) Matched ati as autoconfigured driver 1
[    18.073] (==) Matched fglrx as autoconfigured driver 2
[    18.073] (==) Matched ati as autoconfigured driver 3
[    18.073] (==) Matched modesetting as autoconfigured driver 4
[    18.073] (==) Matched fbdev as autoconfigured driver 5
[    18.073] (==) Matched vesa as autoconfigured driver 6
[    18.073] (==) Assigned the driver to the xf86ConfigLayout
[    18.073] (II) LoadModule: "fglrx"
[    18.074] (WW) Warning, couldn't open module fglrx
[    18.074] (II) UnloadModule: "fglrx"
[    18.074] (II) Unloading fglrx
[    18.074] (EE) Failed to load module "fglrx" (module does not exist, 0)
[    18.074] (II) LoadModule: "ati"
[    18.074] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    18.075] (II) Module ati: vendor="X.Org Foundation"
[    18.075]    compiled for 1.15.0, module version = 7.3.0
[    18.075]    Module class: X.Org Video Driver
[    18.075]    ABI class: X.Org Video Driver, version 15.0
Note that after not finding the fglrx module it carries on and ultimately it is not fatal if another alternative driver module is available.....
PeterO
The Russian
Sun Nov 02, 2014 6:01 pm
login as: pi
[email protected]'s password:
Linux raspy 3.10.33+ #656 PREEMPT Fri Mar 14 18:19:28 GMT 2014 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Nov  1 22:23:11 2014 from 192.168.0.106
[email protected]:~$ config parameter "music_directory" is first defined on line 13 and redefined on line 441
[1]-  Exit 1                  mpd
[2]+  Exit 1                  mpd
[email protected]:~$ sudo less /var/log/Xorg.0.log
[    38.734]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[    38.735] X Protocol Version 11, Revision 0
[    38.735] Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
[    38.735] Current Operating System: Linux raspy 3.10.33+ #656 PREEMPT Fri Mar 14 18:19:28 GMT 2014 armv6l
[    38.736] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708.boardrev=0xd bcm2708.serial=0x903814e6 smsc95xx.macaddr=B8:27:EB:38:14:E6 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[    38.736] Build Date: 20 April 2013  05:19:09AM
[    38.737] xorg-server 2:1.12.4-6 (Julien Cristau <[email protected]>)
[    38.737] Current version of pixman: 0.29.3
[    38.737]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    38.737] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    38.739] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun  3 00:17:28 2014
/var/log/Xorg.0.log
Here is all of it...
DirkS
Sun Nov 02, 2014 6:08 pm
Does the GUI actually start or not?
If it starts, can you use it as you would expect?
Gr.
Dirk.
The Russian
Sun Nov 02, 2014 6:11 pm
No it does not start.
DirkS
Sun Nov 02, 2014 6:14 pm
Are you logged in directly or with remotely (e.g. using SSH)?
Gr.
Dirk.
The Russian
Sun Nov 02, 2014 6:23 pm
I use SSH,but I maybe should mention that it does load when using it direct.. but with SSH it does not not load,
DirkS
Sun Nov 02, 2014 7:02 pm
The Russian wrote:I use SSH,but I maybe should mention that it does load when using it direct.. but with SSH it does not not load,
You can't use the GUI through vanilla SSH.
You'll either need something like VNC or an X server on your client machine...
What messages do you get when you start the GUI locally?
if you post it also give more details about your setup (hardware / software).
Gr.
Dirk.
Sun Nov 02, 2014 7:43 pm
ON THE FIRST PAGE.
Now press PgDn to scroll to the next page.
