I tried and tried to get some good sampling from piscope but I always get some strange plots. No matter how slow or fast I sample the gpios, some steps are always missing in the clock output.
I tried with SSH from linux.
I tried directly on the Pi with a HDMI monitor and a USB keyboard. Even with no connection to the Ethernet port.
What I am trying to do is a direct connection to an ADC0804 converter.
At this time, I am only testing the clock to at least feed a proper signal to the converter. I cannot get to that stage yet. The maximum speed I want is around 100kHz, which is trivial in this case. Even 100Hz don't give a clean signal for the output pin.
This is on a B+ with a 40 pin cable connection around 30 cm long normally. If I remove the cable, I get the same result.
Can I assumed that the signal is good even if piscope does no show it? I don't want to buy a real analyser just for this.
Is there an image of a good signal trace somewhere that I can compare with and try to replicate? I may have a bad Pi
