a5sk4s
How to avoid 2min delay for direct ethernet cable setup?
Mon Oct 20, 2014 5:42 pm
I am using a direct ethernet cable as a fallback option to be able to administer the RPi. There is no dhcp server, both sides have static ips.
The delay occurs, when there is no cable connected.
At the moment, I have the ip address for the RPi hardcoded at the end of /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait ip=192.168.2.2
When I remove it and use /etc/network/interfaces as follows
auto wlan0
iface lo inet loopback
iface eth0 inet static
        address 192.168.2.2
        netmask 255.255.255.0
        gateway 192.168.2.1
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
the lo (loopback) interface disappears from ifconfig, and the postgresql server fails to start up as a result.
I can later correct the situation by manually invoking 'sudo ifup lo' and '/etc/init.d/postgresql start', but i would prefer not to - maybe other things failed as well.
What can I do to correct the situation?
pluggy
Re: How to avoid 2min delay for direct ethernet cable setup?
Mon Oct 20, 2014 5:57 pm
Remove anything you changed in the FAT partition
Adjust to suit
auto lo
auto eth0
  address 192.168.1.246
  network 192.168.1.0
  broadcast 192.168.1.255
  gateway 192.168.1.1
It fires up straight away cable or not, and if its started without, it just works when you plug it in.
a5sk4s
Mon Oct 20, 2014 7:03 pm
Not sure what to do with this statement. The rest worked like a charm. I assume that I was basically missing the 'auto lo'.
Thank you.
Mon Oct 20, 2014 7:53 pm
if you add ip=xxx.xxx.xxx.xxx to /boot/cmdline.txt and the eth0 isn't wired to an active connection you WILL get the 120 second delay.
Two options to fix it
1. Connect a cable to a router/switch or laptop
2. Drop the ip= parm
a5sk4s
Tue Oct 21, 2014 7:35 pm
Yes, the following configuration in /etc/network/interfaces allowed me to do that (no need to plug in a cable to avoid the delay):
auto wlan0
auto eth0
auto lo
	address 192.168.2.2
	network 192.168.2.0
allow-hotplug wlan0
