Palmcrack
Troubles with 3.2" tft vs Raspbian
Mon Oct 13, 2014 6:01 am
Colleagues good day!
Please help: bought a small screen http://www.wvshare.com/product/3.2inch-RPi-LCD-B.htm, anywhere in the manual says that there are no problems with connecting and setting no. However, I am the third day I bet that this device has earned. As I understand it, before you had to download the modified firmware image rasbian and pumps a driver. Now like latest firmware supports such displays, just something where you have to uncomment it in the configuration files. Help please, I beg you!
Palmcrack
Re: Troubles with 3.2" tft vs Raspbian
Mon Oct 13, 2014 8:42 am
Anybody can help me?
joan
Mon Oct 13, 2014 8:44 am
What connections have you made between the Pi and the screen?
What software are you using to control the screen?
Palmcrack
Mon Oct 13, 2014 8:49 am
Use a standard connector Raspberry pin 26. In the picture my device. The program is no. Firmware - raspbian from this site.
DirkS
Mon Oct 13, 2014 9:13 am
Where did you get this information?
Unless something changed while I was asleep you will still need the image / driver provided by the manufacturer / distributor...
Gr.
Dirk.
Palmcrack
Mon Oct 13, 2014 9:24 am
DirkS , Thanks for the help! I was never able to install these drivers, it's a pity spent on display money. Have a good day and the mood you!
DirkS
Mon Oct 13, 2014 9:46 am
Palmcrack wrote:DirkS , Thanks for the help! I was never able to install these drivers
Did they provide you with a full Raspbian image? What problems did you have with the installation?
Gr.
Dirk.
Palmcrack
Mon Oct 13, 2014 10:18 am
The seller from ebay sent me a link to the image, I downloaded and found out that the archive is damaged. Here is his letter to me:
Hello Friend
Thanks for your mail
Sorry it is my mistake,
Exact link address is http://www.gsdcdn.com/3.2inch%20RPi%20LCD.zip
Please check it again.
- gadgetsdeal
I will try to find in the Internet is a good image for TFT, here is probably: https://github.com/notro/fbtft/wiki
Mon Oct 13, 2014 10:24 am
They're a bunch of Chinese crooks. There's no sign of any downloadable SD card image for that pile of junk.
The board has an SPI interface so if we can discover what the driver chip is then it may be possible to drive it with Notro's FBTFT kernel drivers.
Palmcrack
Mon Oct 13, 2014 10:32 am
DougieLawson, This is the best news today! Thank you from all my heart! Today I have the opportunity to try this solution, but I'll let you know the result. Best wishes!
Palmcrack
Tue Oct 14, 2014 7:46 pm
Won him away. I have found the firmware, which the Chinese hid. Tomorrow I will lay out on Yandex drive and throw a link here, so that others are not obsessed like me. TFT earned immediately. By the way from 2.8 German, too, must go, there is the same pinout.
Colleagues, thank you for your help!
Igor Soudakevitch
Wed Nov 05, 2014 7:35 pm
Hello all,
The image file for 3.2" TFT touch screen LCD for Raspberry B/B+ by WaveShare Electronics is here:
http://yun.baidu.com/wap/link?uk=236627 ... 77&third=0
Click the link on the right (the one that says 下载(3.75GB), these characters mean "download").
Basically, this is it.
That Chinese server is bitchy so be persistent; it took me 45 (yes, forty five) hours to download the file. No Windows-based tools couldn't handle it (because of constant dropouts) so I used Epiphany on Raspi.
And this is the proof: the picture of my Raspi B+ with the 3.2" RPi LCD up and running.
http://stm6671350.narod.ru/Raspi/Raspi_with_LCD.jpg
You may also want to look here; they have a good lead (I'm referring to the image file for the Eleduino kit; LCD is the same):
http://www.raspberrypi.org/forums/viewt ... 00&t=87818
And, of course, here https://github.com/notro/fbtft/wiki (Image Download section) because this is what I found inside issue.txt file on my microSD after flashing it:
FBTFT image reference 2014-07-25
Raspberry Pi reference 2014-06-20 (armhf)
So it seems Notro's images should work, too. I'll post my findings on some other date.
Last edited by Igor Soudakevitch on Sun Nov 09, 2014 1:29 pm, edited 1 time in total.
Igor Soudakevitch
Thu Nov 06, 2014 8:28 pm
This is the follow-up to my previous post related to the image files to be used for Raspberry Pi B/B+ with 3.2" TFT LCD by Waveshare Electronics
DVD_DVK512_CN_EN ( https://yadi.sk/d/YfnDLbaXcYGzH, ~1GB ) is the official image file from Waveshare Electronics; it is a part of their DVK512 kit; I've received the disk from my re-seller this morning - finally!
It contains image file itself (DVK512-LCD32(V3)-140817.img, ~4GB when uncompressed) and a bunch of extras (such as User's Guide in Chinese and English, some source code, schematic drawings, SD Formatter, Win32 DiskImager, and some other more or less useful stuff.) Works like magic; no installation problems to report; this LCD is truly a Plug-n-Play device.
DVD_DVK512_CN_EN_Without_Image.rar ( https://yadi.sk/d/3yhgNwsxcYGcM, ~70MB ) contains these extra files only. You may want to look at them before starting a gigabyte download.
I also checked out the Eleduino-related image file which I had mentioned in my previous post. It works *exactly* as the one supplied with DVK512, even the switching between HDMI and LCD output modes responds correctly to the DVK512 commands (ref.to DVK512 User's Guide). In short, you can use the Eleduino image, too. The only difference that I noticed is that they bundled Midori and not Epiphany.
This is the end of good news: I still have no go on the Notro's images... :(
jvrpi
Fri Nov 14, 2014 11:26 pm
I also have the waveshare tft lcd, but I do not want to use the image provided by the supplier (which in my case did come with the product) and I do not want to use the screen as a replacement for HDMI. I want to be able to send images to the screen.
Has someone found out how to send data such as an image via SPI to the screen? What LCD controller does it use?
japius
Sun Nov 23, 2014 9:41 am
I also bought this screen but i am having trouble getting it to work. I have a Model B, revision 1. Could that be the problem?
gpio version: 2.21
Copyright (c) 2012-2014 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details:
  Type: Model B, Revision: 1, Memory: 256MB, Maker: Egoman
Or should it work? The Pi displays to HDMI like it should, after I run the HDMI-show. If I run the LCD32-v3-how, the LCD stays white though.
Igor Soudakevitch
Thu Nov 27, 2014 3:03 pm
+japius
Have you checked the voltage?
It might sound silly (after all, the screen is full of white light so power must be ON) but in fact...
In this video tutorial http://www.youtube.com/watch?v=dUZjzQuTNX4 , for example, Ben is trying to find the voltage threshold where his display goes down. For a split second @ 4:59, one can see that there is no image against a completely white background. The perfectly operational LCD simply browned out...
timolein
Thu Dec 18, 2014 11:07 am
@japius:
I managed to get it working on a rev 1 board.
Because of the change of 3 pin mappings between rev1 and rev2 you have to change the GPIO signal used for the reset of the display. With version 3 of the display the pin 13 is used for reset. On rev2 boards this pin is routed to GPIO27 but on rev1 boards to GPIO21 (see http://elinux.org/RPi_Low-level_periphe ... .28GPIO.29).
That's why you have to change the reset signal for the display in /etc/modules. Edit line 10 such that it reads:
btft_device name=flexfb gpios=dc:22,reset:21 speed=48000000
In order for the display switch script (LCD32-show-sys-v3) to copy a corrected config file change the respective file in the subdirectory of the switch script (in my case: /home/pi/DVK512/LCD32-v3-show/etc/modules).
japius
Thu Dec 25, 2014 8:59 am
@igor: I did not manage to make time to check the voltage. I planned on doing so these holidays. But now, @timolein posted a solution that seemed to make sense. And guess what: i now have a working screen! Thank you all!
bezo88
Fri Jan 09, 2015 7:32 pm
I need help. I have the 3,2" touch screen tft display rev.A from ebay. I tried everything to get it to work. The seller does not respond to my messages.
I have a model B pi.I tried the DVD_DVK512_CN_EN and it only displays a rainbow sort of screen on the hdmi out.Can anyone help?
DirkS
Fri Jan 09, 2015 11:24 pm
bezo88 wrote:I need help. I have the 3,2" touch screen tft display rev.A from ebay. I tried everything to get it to work. The seller does not respond to my messages.
'The' display? The same as linked in the top post?
If not, please start a new topic and provide links to screen / software.
Gr.
Dirk.
cslinux
Mon Jan 19, 2015 1:19 am
The same here, I have a model B pi. I tried the DVD_DVK512_CN_EN and the mentioned images on this thread, always it only displays a rainbow sort of screen on the hdmi out.
Can anyone help?
Scottyc
Thu Feb 05, 2015 9:18 am
If you want to install the LCDs on a clean version of Raspbian or Rasbmc, I have written up a step by step guide with a beginner in mind on how to do it. It took several days of research to find out exactly how to install the drivers and get the touchscreen configured and calibrated correctly, but I have it working nicely. If you want to save some time and headaches, check out the article here: http://www.circuitbasics.com/setup-lcd- ... pberry-pi/
Circuit Basics blog - Arduino, Raspberry Pi, and DIY Electronics Projects, Articles, and Tutorials... http://www.circuitbasics.com
AndyChen
Wed Feb 11, 2015 3:07 am
maybe you had downloaded the inappropriate firmware, so you must make sure that the firmware you have is appropriate for the corresponding version of the screen.
good luck!
marked
Sat Mar 07, 2015 3:19 pm
Scottyc wrote:If you want to save some time and headaches, check out the article here: http://www.circuitbasics.com/setup-lcd- ... pberry-pi/
This has moved and is now at http://www.circuitbasics.com/setup-lcd- ... 015-02-04/ with the touch calibration information at http://www.circuitbasics.com/raspberry- ... 015-02-04/
reddriver
Tue Mar 17, 2015 10:04 am
Is it possible to make backlight turned off on this display?
