Is my RPi dead?
Posted: Sun Oct 12, 2014 1:48 pm
by faksy
My new model B+ has been working fine for over a month, however since today it fails to boot. Both the LEDs (Red-power and Green-ACT) are constantly on as soon as I power it on. The LEDs have same behavior even if I don't insert the microSD. I checked the microSD on another RPi and that seems to be working fine.
What does it mean when both the green and red LEDs are constantly on? Should I consider my RPi dead?
Thanks,
Re: Is my RPi dead?
Posted: Sun Oct 12, 2014 3:32 pm
by rpdom
Have you checked the Boot Problem sticky post? http://www.raspberrypi.org/forums/viewt ... 28&t=58151
Red light on solid = Power Good. :)
Green light on solid = Can't read SD card.
Try another card/check the contents/clean the contacts/make sure it is seated correctly.
Re: Is my RPi dead?
Posted: Sun Oct 12, 2014 3:37 pm
by fruitoftheloom
faksy wrote:Hi,
Thanks,
I was under the impression that both lights solid denotes it is not finding the required information to boot ;)
Re: Is my RPi dead?
Posted: Sun Oct 12, 2014 4:34 pm
by elatllat
Re: Is my RPi dead?
Posted: Sun Oct 12, 2014 5:14 pm
by DougieLawson
That hasn't been updated for the B+ where the meaning of the LED status changes.
Re: Is my RPi dead?
Posted: Sun Oct 12, 2014 9:17 pm
by mahjongg
The wiki not being updated is one reason its being deprecated.
Re: Is my RPi dead?
Posted: Mon Oct 13, 2014 6:21 am
by faksy
Thanks all for the help/inputs. It indeed was a card problem. I checked with a brand new card and the pi seems to be booting (at least the LEDs blink, will check thoroughly later). Interestingly, the earlier 'bad' card works fine on my model B (it was a fresh NOOBS 1.3.9 card).
Thanks anyways for the help.
