[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.28+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #709 PREEMPT Mon Sep 8 15:28:00 BST 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c061dd90, node_mem_map c06cf000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708.boardrev=0xe bcm2708.serial=0x8865610c smsc95xx.macaddr=B8:27:EB:65:61:0C sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439532K/458752K available (4498K kernel code, 242K rwdata, 1344K rodata, 143K init, 701K bss, 19220K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05bca24 (5843 kB)
[ 0.000000] .init : 0xc05bd000 - 0xc05e0eac ( 144 kB)
[ 0.000000] .data : 0xc05e2000 - 0xc061e8a0 ( 243 kB)
[ 0.000000] .bss : 0xc061e8ac - 0xc06ce080 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001176] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001237] pid_max: default: 32768 minimum: 301
[ 0.001754] Mount-cache hash table entries: 512
[ 0.002571] Initializing cgroup subsys memory
[ 0.002682] Initializing cgroup subsys devices
[ 0.002720] Initializing cgroup subsys freezer
[ 0.002751] Initializing cgroup subsys blkio
[ 0.002900] CPU: Testing write buffer coherency: ok
[ 0.003367] Setting up static identity map for 0xc04487f8 - 0xc0448854
[ 0.005299] devtmpfs: initialized
[ 0.021282] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.022859] NET: Registered protocol family 16
[ 0.028193] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.028879] cpuidle: using governor ladder
[ 0.028927] cpuidle: using governor menu
[ 0.029356] bcm2708.uart_clock = 0
[ 0.031435] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.031496] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.031530] mailbox: Broadcom VideoCore Mailbox driver
[ 0.031627] bcm2708_vcio: mailbox at f200b880
[ 0.031732] bcm_power: Broadcom power driver
[ 0.031771] bcm_power_open() -> 0
[ 0.031794] bcm_power_request(0, 8)
[ 0.532514] bcm_mailbox_read -> 00000080, 0
[ 0.532552] bcm_power_request -> 0
[ 0.532808] Serial: AMBA PL011 UART driver
[ 0.532982] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.893536] console [ttyAMA0] enabled
[ 0.920672] bio: create slab <bio-0> at 0
[ 0.926199] SCSI subsystem initialized
[ 0.930197] usbcore: registered new interface driver usbfs
[ 0.935900] usbcore: registered new interface driver hub
[ 0.941456] usbcore: registered new device driver usb
[ 0.948056] Switched to clocksource stc
[ 0.952327] FS-Cache: Loaded
[ 0.955494] CacheFiles: Loaded
[ 0.971377] NET: Registered protocol family 2
[ 0.977182] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.984593] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.991181] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.997628] TCP: reno registered
[ 1.000924] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.006795] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.013569] NET: Registered protocol family 1
[ 1.018554] RPC: Registered named UNIX socket transport module.
[ 1.024512] RPC: Registered udp transport module.
[ 1.029315] RPC: Registered tcp transport module.
[ 1.034037] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.041392] bcm2708_dma: DMA manager at f2007000
[ 1.046134] bcm2708_gpio: bcm2708_gpio_probe c05efef0
[ 1.051702] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.061279] audit: initializing netlink socket (disabled)
[ 1.066789] type=2000 audit(0.910:1): initialized
[ 1.236561] VFS: Disk quotas dquot_6.5.2
[ 1.240921] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.249916] FS-Cache: Netfs 'nfs' registered for caching
[ 1.256822] NFS: Registering the id_resolver key type
[ 1.262107] Key type id_resolver registered
[ 1.266315] Key type id_legacy registered
[ 1.271123] msgmni has been set to 874
[ 1.276863] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.284724] io scheduler noop registered
[ 1.288799] io scheduler deadline registered (default)
[ 1.294277] io scheduler cfq registered
[ 1.299487] BCM2708FB: allocated DMA memory 5bc00000
[ 1.304532] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.315917] bcm2708_fb_pan_display(0,0) returns=0
[ 1.330079] Console: switching to colour frame buffer device 210x65
[ 1.330836] bcm2708_fb_pan_display(0,0) returns=0
[ 1.361499] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.369363] uart-pl011 dev:f1: no DMA platform data
[ 1.374388] kgdb: Registered I/O driver kgdboc.
[ 1.379755] vc-cma: Videocore CMA driver
[ 1.383781] vc-cma: vc_cma_base = 0x00000000
[ 1.388645] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.394144] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.409759] brd: module loaded
[ 1.418499] loop: module loaded
[ 1.422050] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.430259] Loading iSCSI transport class v2.0-870.
[ 1.436404] usbcore: registered new interface driver smsc95xx
[ 1.442633] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.648789] Core Release: 2.80a
[ 1.652030] Setting default values for core params
[ 1.656939] Finished setting default values for core params
[ 1.862775] Using Buffer DMA mode
[ 1.866180] Periodic Transfer Interrupt Enhancement - disabled
[ 1.872151] Multiprocessor Interrupt Enhancement - disabled
[ 1.877831] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.882309] Dedicated Tx FIFOs mode
[ 1.886226] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 1.896307] FIQ FSM acceleration enabled for :
[ 1.896307] Non-periodic Split Transactions
[ 1.896307] Periodic Split Transactions
[ 1.896307] High-Speed Isochronous Endpoints
[ 1.913376] dwc_otg: Microframe scheduler enabled
[ 1.913472] WARN::hcd_init:473: FIQ at 0xc0321550
[ 1.918327] WARN::hcd_init:474: FIQ ASM at 0xc0321800 length 36
[ 1.928919] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[ 1.939124] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.948549] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.960356] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.970355] Init: Port Power? op_state=1
[ 1.978767] Init: Power Port (0)
[ 1.986777] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.998167] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.009979] usb usb1: Product: DWC OTG Controller
[ 2.019186] usb usb1: Manufacturer: Linux 3.12.28+ dwc_otg_hcd
[ 2.029571] usb usb1: SerialNumber: bcm2708_usb
[ 2.039533] hub 1-0:1.0: USB hub found
[ 2.047893] hub 1-0:1.0: 1 port detected
[ 2.056869] dwc_otg: FIQ enabled
[ 2.056892] dwc_otg: NAK holdoff enabled
[ 2.056902] dwc_otg: FIQ split-transaction FSM enabled
[ 2.056924] Module dwc_common_port init
[ 2.057409] usbcore: registered new interface driver usb-storage
[ 2.068496] mousedev: PS/2 mouse device common for all mice
[ 2.079427] bcm2835-cpufreq: min=700000 max=1000000 cur=700000
[ 2.090036] bcm2835-cpufreq: switching to governor powersave
[ 2.100149] bcm2835-cpufreq: switching to governor powersave
[ 2.110390] sdhci: Secure Digital Host Controller Interface driver
[ 2.121003] sdhci: Copyright(c) Pierre Ossman
[ 2.129868] sdhci: Enable low-latency mode
[ 2.178138] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.190760] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.201382] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.213693] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.231702] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.242007] usbcore: registered new interface driver usbhid
[ 2.254439] Indeed it is in host mode hprt0 = 00021501
[ 2.266288] usbhid: USB HID core driver
[ 2.279840] TCP: cubic registered
[ 2.301855] Initializing XFRM netlink socket
[ 2.328177] NET: Registered protocol family 17
[ 2.338307] Key type dns_resolver registered
[ 2.378604] registered taskstats version 1
[ 2.399431] Waiting for root device /dev/mmcblk0p6...
[ 2.409313] mmc0: read SD Status register (SSR) after 3 attempts
[ 2.432672] mmc0: new high speed SDHC card at address 0002
[ 2.443682] mmcblk0: mmc0:0002 00000 7.32 GiB
[ 2.456402] mmcblk0: p1 p2 < p5 p6 >
[ 2.538277] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.550573] Indeed it is in host mode hprt0 = 00001101
[ 2.768549] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.793219] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.818831] hub 1-1:1.0: USB hub found
[ 2.827430] hub 1-1:1.0: 3 ports detected
[ 3.128248] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.248526] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.264484] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.291011] smsc95xx v1.0.4
[ 3.378464] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:61:0c
[ 3.488240] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.613200] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=1001
[ 3.625319] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.637705] usb 1-1.2: Product: Hub in Apple USB Keyboard
[ 3.658102] usb 1-1.2: Manufacturer: Alps Electric
[ 3.671847] hub 1-1.2:1.0: USB hub found
[ 3.688146] hub 1-1.2:1.0: 3 ports detected
[ 3.756099] EXT4-fs (mmcblk0p6): recovery complete
[ 3.767451] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.780435] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 3.791374] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ 3.803860] devtmpfs: mounted
[ 3.812992] Freeing unused kernel memory: 140K (c05bd000 - c05e0000)
[ 3.888409] usb 1-1.3: device descriptor read/64, error -32
[ 4.124413] usb 1-1.3: New USB device found, idVendor=03eb, idProduct=2fef
[ 4.137428] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.149811] usb 1-1.3: Product: ATmega16u2 DFU
[ 4.160200] usb 1-1.3: Manufacturer: ATMEL
[ 4.248570] usb 1-1.2.1: new low-speed USB device number 6 using dwc_otg
[ 4.384744] usb 1-1.2.1: New USB device found, idVendor=05ac, idProduct=0201
[ 4.406873] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.419539] usb 1-1.2.1: Product: Apple USB Keyboard
[ 4.429432] usb 1-1.2.1: Manufacturer: Alps Electric
[ 4.465153] input: Alps Electric Apple USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/input/input0
[ 4.482943] hid-generic 0003:05AC:0201.0001: input,hidraw0: USB HID v1.00 Keyboard [Alps Electric Apple USB Keyboard] on usb-bcm2708_usb-1.2.1/input0
[ 5.464706] udevd[156]: starting version 175
[ 7.794591] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 12.373802] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 12.899519] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 19.022195] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 22.345171] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 23.861751] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 25.031089] bcm2835-cpufreq: switching to governor ondemand
[ 25.031124] bcm2835-cpufreq: switching to governor ondemand
[ 27.149783] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 146.988480] bcm2708_fb_pan_display(0,0) returns=0
[ 147.052335] bcm2708_fb_blank(1) returns=1 p[1]=0x80000000
[ 147.059248] bcm2708_fb_pan_display(0,0) returns=0
[ 147.813011] bcm2708_fb_blank(0) returns=0 p[1]=0x80000000
[ 154.622675] usb 1-1.3: USB disconnect, device number 5
[ 159.722890] usb 1-1.3: new low-speed USB device number 7 using dwc_otg
[ 159.827574] usb 1-1.3: New USB device found, idVendor=192f, idProduct=0916
[ 159.827615] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 159.827632] usb 1-1.3: Product: USB Optical Mouse
[ 159.851630] input: USB Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
[ 159.853793] hid-generic 0003:192F:0916.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-bcm2708_usb-1.3/input0
[ 203.525282] usb 1-1.3: USB disconnect, device number 7
[ 216.814728] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
[ 216.929327] usb 1-1.3: New USB device found, idVendor=03eb, idProduct=2fef
[ 216.929367] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 216.929383] usb 1-1.3: Product: ATmega16u2 DFU
[ 216.929396] usb 1-1.3: Manufacturer: ATMEL
