Hi!
Im new to this.
Im trying to install a raspbmc with no luck. Currently without an internet connection thats why im using the standalone image. I have a sd card 8 gb and a 2gb transcend SD-card. On 3 different computers with their own sdcard-reader.
Different displays and HDMI-cables.
I also tried with NOOBs standalone, Openelec network install, wheezy raspian and so on.
Still the same 4 green flashes. Nothing more.
So i eventually found this: 3 flashes: loader.bin not found 4 flashes: loader.bin not launched 5 flashes: start.elf not found 6 flashes: start.elf not launched 7 flashes: kernel.img not found Firmware since 20th October 2012 no longer requires loader.bin, and the flashes mean: 3 flashes: start.elf not found 4 flashes: start.elf not launched 7 flashes: kernel.img not found 8 flashes: SDRAM not recognised. You need newer bootcode.bin/start.elf firmware.
Tried to google a different start.elf-file, just found this one: https://github.com/raspberrypi/firmware ... /start.elf replaced the one on the sdcard but still with no luck.
Does anybody have an idea how to fix it?
Is it something wrong with my Pi?
Thank you!
