rdohmen
problem installing Lazarus
Thu Sep 18, 2014 5:16 pm
I used to install Lazrus with:
sudo apt-get install fpc lazarus libfbclient2
But since a week or so the following message occures:
fpc : Depends: fpc-2.6.0 (= 2.6.0-9+rpi1) but it is not going to be installed
lazarus : Depends: lazarus-0.9.30.4 (= 0.9.30.4-6) but it is not goning to be installed
E: unable to correct problem, you have broken packages
I have no idea how to solve or work around this.
thanks for any help,
René
arnoldb
Re: problem installing Lazarus
Fri Sep 19, 2014 5:30 pm
I ran into the same problem today (just got my B+ this morning), and after digging through things, found it's because the binutils-gold dependency for fpc is not satisfied after I did an apt-get update and apt-get upgrade.
The fpc package is looking for an older version than is now on the Pi...
For now, I forced a roll-back to the required version of binutils-gold and got fpc/lazarus to run - but that won't play well with other things in future, so someone must look at the fpc package dependencies and sort it out.
Kind regards, Arnold
rdohmen
Sat Sep 20, 2014 11:05 am
Thanks Arnold,
Can you give me some instruction on how to do that?
I guess 'sudo aptitude' with some parameters?
thank in advance,
René
rdohmen
Sat Oct 25, 2014 7:02 pm
Thank you, this works!
After adding
deb http://plugwash.raspbian.org/wsf wheezy-wsf main
to
/etc/apt/sources.list
with
sudo nano /etc/apt/sources.list
I updated and upgraded with:
sudo apt-get update
sudo apt-get upgrade
After this a usual install was possible with:
Kind regards,
Rene
hkemsw
Thu Jan 22, 2015 3:56 am
Hi
I tried all of the above but I still get the broken packages error.
Are there any updated suggestions?
plugwash
Thu Jan 22, 2015 4:30 pm
can you post the complete output of
apt-get install lazarus fp-compiler binutils
and
apt-cache policy fp-compiler
otani
Thu Jan 22, 2015 7:28 pm
Don't use "apt-get install". Just try as follows:
$sudo aptitude install fpc
----fpc not installed ---
---leave the following dependencies unresolved----
Accept this solutions [Y/n/q] n [Enter] == Important==
The following actions will resolve these dependencies:
Downgrade the following packages:
binutils 2.24.5 --> 2.22.8
Accept this solution [Y/n/q] y [Enter]
Start to download and install..
BlaiseP
Tue Feb 10, 2015 10:38 pm
I tried
http://www.raspberrypi.org/forums/viewt ... 48&t=88145
first but no success...this worked, thanks.
hkemsw
Mon Feb 23, 2015 1:11 am
Many thanks - I apologise for my incredibly slow response. I got dragged into working on other things.
I just followed your instructions and all went well.
Who is online
Users browsing this forum: geffers and 45 guests
