demsley
Raspberry Pi B+ with AdaFruit Screen
Thu Sep 18, 2014 2:12 pm
Hi there,
I have a, hopefully, small issue with the B+ and AdaFruit screen which I'm sure others have as well. The screen's socket is shorter than the GPIO pins. Looking at photos on web I cannot find exactly where to start - judging by the comment of the 5mm overhang I'm assuming I connect the screen to the pins starting with the furthest from the USB sockets.
However all I get is a white screen although I can see the Pi is going through its normal startup.
Any ideas anyone?
Cheers
Dave
All thoughts and comments are my own......
.... of course they are; who else would think like this?
Re: Raspberry Pi B+ with AdaFruit Screen
Thu Sep 18, 2014 2:16 pm
Which Adafruit screen, there's at least five of them that I know of (including http://adafruit.com/products/1770 which is my screen)?
BMS Doug
Thu Sep 18, 2014 3:53 pm
demsley wrote:Hi there,
yes, the first 26 pins (furthest from the USB) are what you should be connecting to.
demsley wrote:Any ideas anyone?
Cheers
Dave
Have you put in the corresponding software? (It's not plug and play).
Doug.
Building Management Systems Engineer.
demsley
Fri Sep 19, 2014 3:55 pm
Hi there, thanks for the replies.
I have installed the software as per - https://learn.adafruit.com/adafruit-pit ... sy-install
The model is a 1601B.
I've reinstalled the s/w just incase but still white screen.
Any ideas?
Cheers
Dave
demsley
Fri Sep 19, 2014 5:20 pm
OK I have found it to be erroring when loading the driver software so I've done a full install from scratch using the Raspbian B+ image from here: https://learn.adafruit.com/adafruit-pit ... sy-install
Thanks for all help
Cheers
Dave
