It seems that distortion is present at any audio level in high frequencies using the following test files:
MP4 video with 192kbs AAC audio
MVK video with 384kbs Dolby Digital
I'm not sure if this is being caused by any of the following at present:
Bad screening with the audio jack/board being placed close to the monitor/screen.
5v power issue where the board is running at extreme minimum voltage input.
Codec issue which is causing peeks/clipping (however its present at all volumes).
Any audiofiles out there done any testing of analog audio quality in debian/arch finding the same???
I'm currently powering my Pi via a Motorola lapdock - and will be doing futher testing with 5v 1amp charger today to see if its a voltage thing and will feedback.
Any guidance/knowledge in the meantime would be most apreciated
Update : Just fed the board with 5volts @ 1 amp - same results - Its deffo not power related
Justin
