Hi there!
I'm trying to connect to an USB device (it is a RFID reader) that needs to receive up to 500 mA of current. I am using a Raspberry B+ model with (up-to-date) Raspbian. When the USB device is idle, it is happy with just 100mA and I can interact with it, but when it has to do some RF operation it requires more current and it simply disconnects. I think the problem is that the device, when attaching to the USB port, "negotiates" a maximum current of 100 mA. I've checked this with "lsusb -v" command. I have also tried connecting the device through an externally powered USB Hub and it simply works, but I need to connect the device directly to the raspberry and get rid of the external hub. Considering the B+ model can provide that current without problems (am I correct?), how can I override the max current limit for the device and provide up to 500 mA? Any ideas?
Just in case it is relevant, when attached, the device uses ACMx ports (as if it were a modem).
Thanks!
