hawkyhawk14
Raspberry Pi Poor Allocation of Disk Space
Sat Jun 16, 2012 8:49 pm
I am using the debian squeeze distro for my raspberry pi (As the fedora one is pathetically bad, and virtually unusable).
Why does the debian distro allocate disk space so poorly? It gave me just 4gb for the root fs and I frequently run out of room. I use an 8gb SD card and had 5.5gb free and unallocated! Is there an easy way to fix this without booting up gparted on my desktop to move the swap partition and expand the root fs?
Thanks!
SN
Re: Raspberry Pi Poor Allocation of Disk Space
Sat Jun 16, 2012 8:58 pm
Please search the forums for your issue before complaining. There is a simple set of instructions to fix this. And no I'm not being your search provider
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
bredman
Sat Jun 16, 2012 9:02 pm
I will be a bit kinder in case you have trouble searching. See the end of this page.
http://elinux.org/RPi_Easy_SD_Card_Setup
There is no point-and-click solution. This is a developer release, you have to put up with a few rough edges.
rocketero
Fri Jul 13, 2012 3:24 am
I'm gonna have to agree with hawkyhawk14 on this one. After researching on the website http://elinux.org/RPi_Easy_SD_Card_Setup none of those methods will do anything to change the size of the main partition (partition /).
And the only way I got it increased to 14GB from 1.5GB was using the second method on this website:
http://elinux.org/RPi_Resize_Flash_Partitions
witch was pretty easy as of matter of fact, I do recommend to anyone to use the Gparted (You have to plug the SD card on another PC running Linux, mine was running Ubuntu 12.0). It's pretty graphic, all one have to do is drag the edges of the partitions to resize them/move them.
I won't recommend the command line with 'parted' as the creator himself make a notice once you're trying to move a partition with this method to not use it as it is pretty much unsecured and a guessing work.
Now I'm happy with more than 14GB to use in the / partition. Previously with the 1.5GB I had installed only like 5 apps and it was telling me that it won't install any other app as it was running out of space. (tried to install KmPlayer and refused to do it).
