mcgyver83
Raspberry disconnected from wifi randomly
Sat Aug 23, 2014 7:58 am
I have a raspberry with wifi usb dongle.
I use open wifi with mac address access control.
Everything works fine for 1 day, 3 days, 5 hours, after the rasp loose wifi signal. Sometimes it reconnect itself again, other times I have to unplug power cord.
Where can I look for info in logs?
Signal is around 80% ( I checked when I configured the wifi from a panel in lxde env).
Re: Raspberry disconnected from wifi randomly
Sat Aug 23, 2014 9:51 am
There are some USB WiFi Adaptors which have "Power Save" Mode, you will need to check the settings...
RPi 4B 4GB (SSD Boot)..
mcgyver83
Sat Aug 23, 2014 11:25 am
Were can I check?There is a config file somewhere?
If my wifi can go to Power save mode, it will wake up itself when someone try to access it?
mahjongg
Sat Aug 23, 2014 1:22 pm
not config.txt!
search the forum using google
use
site:http://www.raspberrypi.org/forums power save mode
Sat Aug 23, 2014 1:48 pm
mcgyver83 wrote:Were can I check?There is a config file somewhere?
https://www.google.co.uk/search?q=site% ... wifi+dmesg
mcgyver83
Mon Aug 25, 2014 5:44 am
Thanks.
If I run
iwconfig wlan0
wlan0     IEEE 802.11bgn  ESSID:"Vodafone-mcg"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:24:89:E6:B8:3C
          Bit Rate:72.2 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=100/100  Signal level=57/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
So Power management is off :(
DirkS
Mon Aug 25, 2014 10:21 am
From another post I gather that you're using the same dongle as mentioned in http://www.raspberrypi.org/forums/viewt ... 36&t=81259.
If you follow the link there (http://www.raspberrypi.org/forums/viewt ... 28&t=61665) you'll get to some more (driver specific) settings to disable power management.
The poster does not say if it helped him, though...
Gr.
Dirk.
mcgyver83
Fri Aug 29, 2014 11:37 pm
Strange thing happens: I'm connected via wifi to my home network, raspberry was not reacheable by ssh and local ip address but I can access Webmin instance on the raspberry using the dynamic dns hostname :o :o :o
Router admin panel displays the raspberry as connected to the wifi but not "active" :geek:
