Dalmango
Re: Mouse issue after rpi-update
Sat Aug 05, 2017 5:24 pm
gkreidl wrote:
Wed Aug 20, 2014 4:04 pm
add
usbhid.mousepoll=0
to /boot/cmdline.txt
in the same line separated from the other stuff by spaces
Thanks gkreidl, this fixed it for me too. :D
Antaresr
Re: Mouse slow and lagging after rpi-update [solved]
Thu Dec 07, 2017 5:03 pm
I cant save the file, ctrl-0 and enter does not work for me. Thank you
tyherbz
Sat Dec 09, 2017 9:04 am
I gave this a try:
sudo leafpad /boot/cmdline.txt
Which opened up the code in leaf pad. So I added "usbhid.mousepoll=0" at the very end of the line. Saved it (ctrl + S) and rebooted.
Mouse works like a pro now. Hope this helps anyone in need.
o_kante
Thu Mar 01, 2018 9:33 pm
Thanks, that was very useful ;)
RaTTuS
Fri Mar 02, 2018 7:48 am
don't use rpi-update
unless you are following very specific instructions dated after 2018 here off this board
as rpi-update will in most cases make it not do what your expecting and you'll have to start again from a backup
Covfefe
gkreidl
Fri Mar 02, 2018 8:22 am
The problem itself is not related to the use of rpi-update at all. It just showed up for the first time in 2014 when updating the kernel. The reduced mouse polling rate has been in the official kernel releases for a long time now. Although it's fine by itself, it produces problems with most wireless keyboard/mouse combos. The command line option was added for people who run into this problem.
Minimal Kiosk Browser (kweb)
mattg31
Mon Apr 23, 2018 9:53 am
Hi everyone,
This solved my problem on my raspberry pi 3 with a raspbian image from 2017. Now I have a Raspberry pi 3 b+, and running the latest image from April 18th.
The /boot/cmdline.text is empty? I added the usbhid.mousepoll=0 anyway but it didn't solve the issue.
Any tips for the new version of raspian?
B.Goode
Mon Apr 23, 2018 10:03 am
Maybe the same solution is still applicable?
That would involve modifying /boot/cmdline.txt
mattg31
Mon Apr 23, 2018 10:20 am
Yes I modified the text file (even though it was empty). Still no change, my mouse is still very slow and laggy...
B.Goode
Mon Apr 23, 2018 10:28 am
Although it is nearly 4 years since this solution was first posted, I would not expect /boot/cmdline.txt to be an empty file with a fresh installation of Raspbian Stretch.
To be sure you are not missing my point: although it contains readable text, the file is not named /boot/cmdline.text.
Edit: Disclaimer - I am not in front of a Raspbian system to check right now. But a change in this area would break so many tutorials, and has not been mentioned in release notes, so I am pretty sure it remains unchanged.
Mon Apr 23, 2018 10:31 am
No, cmdline.txt should never be an empty file. I suspect the poster has edited the wrong filename.
mattg31
Mon Apr 23, 2018 10:50 pm
When I type into the terminal: sudo nano /boot/cmdline.text OR sudo leafpad /boot/cmdline.text
an empty file is loaded.
On my raspberry pi 3 model B, using Raspian from sometime in 2017, I get a populated text file.
Maybe the image is corrupt?
gkreidl
Mon Apr 23, 2018 11:16 pm
/boot/cmdline.txt, not /boot/cmdline.text.
mattg31
Tue Apr 24, 2018 1:48 am
#embarrassed..
Thanks for the correction. That fixed it.
jkwilborn
Sun May 06, 2018 4:25 pm
I have a Pi 3, model B, Raspbian 9.4. The mouse is very lagging. I have tried the fix in the cmdline.txt file. The 0 produced no change but 1 though 15 do speed the movements up when increased. By the response, it would seem that maybe it's the lower 4 bits? It doesn't speed it up fast enough to be useful.
I've run this OS (pure Debian) on numerous, slow, machines and have not had this problem before. Does anyone know where this problem is rooted, hardware, software? I'm still pretty knew with this guy...
Keyboard/mouse Targus Model AKB214. I did see the short piece on the mouse polling too often. Can I check that some way? Any suggestions would be nice.
LPJ25
Mon Jun 25, 2018 5:21 pm
add
usbhid.mousepoll=0
tried this and the pi freezes on reboot. Any tips?
gkreidl
Tue Jun 26, 2018 4:28 am
add
usbhid.mousepoll=0
Check your edits again.
learner21
Thu Sep 20, 2018 8:39 pm
so I opened the terminal and added the line of code. My mouse works fine now (not laggy anymore) but now I have two config.txt files. One that says config.txt and the other config.txt.save this is because I didnt know how to save the addition after adding the line, so I opened another terminal and hit sudo reboot.
Is it okay for me to delete the other config.txt file or should I just keep both?
learner21
Thu Sep 20, 2018 11:30 pm
CaptDan wrote:
Fri Jun 05, 2015 6:29 pm
This worked GREAT but I'm a Pi and Linux noob and needed some research before I could get this to work. Here's the cheat sheet for all the other noobs out there:
-Type this into a terminal: sudo nano /boot/cmdline.text
- sudo, short for 'Super User Do' runs commands at supervisor or 'root' privilege level
- nano starts Nano which is a Linux command-line text editor installed with Pi
- /boot/cmdline.text opens the appropriate boot file in the editor
- Add this at the end of the text file content as gkreidl said: usbhid.mousepoll=0
- To save hit Ctrl-O and then hit Enter (ignore options)
- If you open the file you can see that it has now been modified
-To reboot enter the following command: sudo shutdown -r now
- sudo runs as supervisor or 'root' privilege
- r stands for reboot
- now tells it to reboot now.
THIS is GREAT!! it worked for me!!!
JCB
Sun Oct 21, 2018 3:06 am
Thank you gkreidl for your solution!
I am a total noob that just bought a Raspberry Pi 3 B+ and a new wireless keyboard with mouse. I thought I would have to buy another mouse but your code saved the day!
I typed:
Then I added a space to the end of the line and typed: usbhid.mousepoll=0 then I hit Ctrl O and ENTER and finally I rebooted.
My mouse now works like a charm! :D
ramseyrt
Mon Apr 08, 2019 8:37 pm
This fix worked for me! I'm running a Raspberry Pi 2 connected to a Avocent Cybex KVM which is connected to a Logitech K360 wireless keyboard and mouse.
8 Apr 2019
Thanks!
Rob
add
usbhid.mousepoll=0
Philmanwho1
Tue May 14, 2019 8:12 pm
Tried for like 20 mins to get this working, it turns out some how, there was an extra return press before the text.
The row of text needs to be on the very first row of the file.
I'll be honest, I don't think I caused the extra row, but it is a new install of the os, and it's already been covered above that that file hasn't changed on the build, so it must have been me.
Thanks for this, worked a treat on the end
seandex
Tue Jun 25, 2019 10:27 am
#1. copy the code below. (or click 'Select all' below and then CTRL+C)
sudo sed -i 's/$/ usbhid.mousepoll=0&/p' /boot/cmdline.txt
#2. CTRL + ALT + T
#3. then paste the code from #1. (or CTRL+SHIFT+V then ENTER)
reboot. (or restart raspberry pi)
HKey_Root
Wed Aug 28, 2019 2:27 pm
Just a PS on this thread from another noobie...
I followed the:
usbhid.mousepoll=0
and it worked fine until I changed my wireless mouse/keyboard to new replacements and the mouse pointer became sluggish again.
I solved the problem by editing cmdline.txt by removing usbhid.mousepoll=0, saving, rebooting then adding it back in followed by another reboot.
All's well again. Thanks for the previous advice given.
JumpZero
Mon Sep 30, 2019 5:15 pm
Hi
Even if it's an old post it worked for me on a Pi4 4Gb with Buster up to date.
I changed my mouse to an noname wireless keyboard/mouse combo then mouse was weird.
Mouse isn't lagging anymore after this setting in /boot/cmdline.txt:
usbhid.mousepoll=0
