alex27riva
Raspberry Pi B+ doesn't turn off
Mon Aug 18, 2014 8:37 am
Hi, i have a Raspberry Pi B+, with the command "sudo halt" via SSH, my PI shut down, but after a few seconds it restarts...
how can I turn off my PI properly without unplugging the power supply?
ShiftPlusOne
Re: Raspberry Pi B+ doesn't turn off
Mon Aug 18, 2014 8:39 am
I believe rpi-update will fix that.
alex27riva
Mon Aug 18, 2014 8:56 am
ShiftPlusOne wrote:I believe rpi-update will fix that.
It's a command "built in" or I have to download some files?
ShiftPlusOne
Mon Aug 18, 2014 8:57 am
Depends on how you installed your OS. Just try running 'sudo rpi-update' and if it's not there, we can go about installing it.
_abo_
Mon Aug 18, 2014 8:58 am
sudo shutdown -h 0
sudo shutdown -h now
_abo_
mahjongg
Mon Aug 18, 2014 8:59 am
its a built in command.
from the command-line simply give the command:
sudo rpi-update
and the pi will download and install the latest pi-specific updates.
Mon Aug 18, 2014 9:02 am
_abo_ wrote:sudo shutdown -h 0
+1
I regularly run on Raspbian Wheezy
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
sudo reboot
RPi 4B 4GB (SSD Boot)..
alex27riva
Mon Aug 18, 2014 9:30 am
+1
sudo apt-get update
sudo rpi-update
sudo reboot
Thank you, now "sudo halt" works!
But "rpi-update" upgrades the firmware on sd card or the firmware in the usb/ ethernet chip of the pi?
SteveSpencer
Mon Aug 18, 2014 9:44 am
On the micro-SD card, so if you have more than one card, you may want to boot that and update it too.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
Mon Aug 18, 2014 2:39 pm
alex27riva wrote:But "rpi-update" upgrades the firmware on sd card or the firmware in the usb/ ethernet chip of the pi?
That will only update the firmware in the SD Card residing in the Bootloader Partition (unlike "standard" PC's the Pi has no BIOS Chip, so those functions are in the software)
http://thekandyancode.wordpress.com/201 ... i-boots-up
AndrewS
Mon Aug 18, 2014 6:12 pm
fruitoftheloom wrote:I regularly run on Raspbian Wheezy
sudo apt-get update
sudo rpi-update
sudo reboot
To be on the safe side, you ought to do a 'sudo reboot' between running apt-get and rpi-update. On the off-chance that apt-get installs a new kernel, rpi-update will 'break' if you don't reboot (to activate the new kernel) first.
mahjongg
Tue Aug 19, 2014 5:22 pm
alex27riva wrote: But "rpi-update" upgrades the firmware on sd card or the firmware in the usb/ ethernet chip of the pi?
The LAN9512/4 chip has no built in firmware.
beta-tester
Wed Oct 29, 2014 9:28 am
alex27riva wrote:Hi, i have a Raspberry Pi B+, with the command "sudo halt" via SSH, my PI shut down, but after a few seconds it restarts...
you mean like this?
http://www.youtube.com/watch?v=PV8P-KnGXGg
( found here: http://www.raspberrypi.org/forums/viewt ... 63&t=82188 )
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
